Datsunville's Commando PT 2
Taillights next, I have 2 complete sets, both need a lot of love.  Pulled everything apart, rusted and fucked up. Got the frames sent off to the chrome shop.
A friend is making gaskets on his laser cutter
Quarter window time,  new latches and new rubber
Petal Assembly
One step closer to the edge AND.......
  • Like 6
  • Replies 113
  • 4 weeks later...
Baby steps,
Rear wheel well covering, thanks Todd (TMG upholstery ) for making some tan covers
1st off foam
Coupes have foam on the upper areas of the inner quarter panels
These little cardboard boxes go in before inner panel
On to door glass then back to the hell of quarter window play
Nissan OG factory inner window felt
I like to glue the window felt in then, install the window to set the glue in place
Finishing up quarter window left side
Had one more part to paint. Turned my soon to be shop living space into a booth, fan in the window and electric heaters on all night.
Now time to get the left side together.
Kenny came up and gave a hand with the dash and stuff. Bought a new repop pad and seems to be damn nice
Pulled this battery hold down out of the burnt 4 door
After installing the right door window i noticed it didn't fit
So pulled it back out and realized the metal frame was full of dirt and rot
Pulled a sedan window apart, frames are the same, and then really noticed what the coupe frame should of been
A killer weekend with my buddy Kenny getting shit done and slamming 4locos
Got that left door on and fender
T3 rear coilovers
Figured i would get the drive line installed
2 inches short or so she told me
Putting Left door together cleaning and greasing, oh my
Coming together
taillight frames came in, Shiny
  • Like 5
1 hour ago, the510keeper said:
No cuddle time, my lady wasn't in to sleeping in the middle
 takes the spirit out of the FOUR loko then. Kenny offered me a carpool to your place to lend a hand, once the snow clears.
Ali.
On 3/11/2019 at 5:31 PM, carterb said:
Chrome plating is so expensive up here in WA.
Is it cheaper in CA or is it sent across the boarder?
--carter
The CA government seems like they are trying to put chrome shops out of business here.
I worked on my car in a shop in San Diego, and some of the fellows tried a few places across the border.  Prices were decent, but the results were all over the place.
Edited by Duncan
  • 3 weeks later...
Always with the baby steps,
Every step is forward and backward, but still making progress
Epoxied in studs to the tailight frames most were rusted off
Once glued and dry, file and die
Door glass 101
this was fun, got weatherstripping at a glass shop in town and made one good door glass
Say cheese look up damn it
Door weather stripping
  • Like 4
And the race continues, getting pretty fucking excited
thanks to all the helpers
Batter tray, battery , and gas tank finished up and installed, blue tape in the bracket for the cover because it will cut the shit out of you
ran the positive cable down the inside of the tunnel, no worries on rad hazards
Shortened the fuel line and relocated it to the fire wall, cut the filter bracket and mounted, look clean
As I look around the shop i find surprises, new stuff
New hood release cable, from Thailand, i'll let ya know how they hold up $10.00
Wagon John came over to get more work done on the electrical.
Sanding connections and installing new bulbs to start
John spent some time fixing the flash to pass blinker switch
By days end, shes a runner
  • Like 3
Install a rubber o-ring to help center the insert. VW rabbit shortened 280zx struts
The welding shop uses all these parts to determine where to weld the collar, once gland nut is install everything is pushed together tight no slop
Cody Mould showed me this trick use the bolts to clamp it in a vise
