Datsunville's Commando PT 2
  • Replies 113
More cleaning and assembly of parts, it aint gunna build itself
280 zx struts shortened to fit VW rabbit inserts, new T3 camber plates and bearing top hats with ebay coilover kit.
14mm ball joints and steering knuckles with T3 bump steer spacers
I had some euro T/C rod bushings and NOS factory rubber, so went with euro drilled and rubber combo
This next step was a hard one, I have a bad ass trunk spare tire delete, but figured i would keep it stock. One of the last cars i bought had a clean spare tire well.
Blasting it inside and out getting it ready
Then this fucking guy came over and helped with cleaning up the engine bay harness. Wagon Jon to the rescue
  • Like 5
  • 3 weeks later...
Shes alive, Johnny came up and finished her out. Running Coupe, now on to other stuff, breaks, dash, etc
Wheels 14-7 staggered (thank you Jared)
out with the old, ended up using the rear sub-frame from Fauxbird, just redid breaks before pulling it. ran new lines
Went with a set of new ST springs cut half coil, need to order shocks, might upgrade to coilovers later. but thats ez
Found these bad boys in my stash haha, urethane top hat spring bushings
Front steering time new stuff, only old parts are the box and idealer arm
Welding time
  • Like 3
Want to see this bee---I--itch on his wheels
New Moog stuff, out of the box there raw. So time to clean and paint
Stuff that makes things pretty, like ur momma
These r new and look like shit after sitting outside and never getting used.
  • 1 month later...
WOW,
Hard as fuck finding good help
Back to the trunk welding, decided Sunday i was going to focus on nothing but this for few hours.
Sand blasted and sealed the truck spare tire pan this way while handling it, it don't rust from hand prints. Yes if something is blasted and you touch it with bare fingers it will rust from the oils in your hands.
Cleaned up the cut a got it set in to place with self tappers
Got a nice tight fit
On to the next step
  • Like 3
Primer time
On to the inside of the hood and doors
This hood is near perfect besides this rust WTF
However instead of welding it up i decided to use panel bond, " said to be better then welding" Clear it real good and squeeze it in there.
One door was blasted couple days ago the other blasted a year ago, hand print rust, my fav
Metal prep to the rescue
Sealed DP40LF epoxy primer sealer
  • 3 weeks later...
Got a bit carried away on the left door so back to priming stage
Been pushing the car by the wheels and it sucks, figured it was time to install steering. and sold the coilover built for this bird. but got a hold of some others and went with it.
49 minutes ago, the510keeper said:
Bought a sedan headliner and had the upholstery guy modify it
good to know I can do that when/if I finally ever buy a coupe.
LOOKS AMAZING JAMES!
Edited by five1oh
  • 2 months later...
Had a small party, pizza and beer in Datsunville
Worked on the Coupe and made some great progress.
Thanks everyone who showed up
Dav knocked out the trunk area and drivers door
Kieth took care of hood shocks and getting door hardware prepped
Jetta trunk shocks, and nipple hardware from a VW beetle
Complete dash disassembled and frame installed
New part door handles, rechomed  pillar vents, Hectors SSS emblems.
Thanks Carlos and Carol
Fender mirrors and new running lights, and emblems
Toward the end Gayleen and Keeny AKA peanutbuttercups and everyone else requested pic with fender on
  • Like 6
