Power Steering pump
86720 ST
  • Replies 11
There is no fitting the hose screws into the threads on the pump.  Like a brake line into a brake master cylinder.
My 86 720 king cab steering gear.
If I get a chance on Friday I will run the steering box by Parker Hose and find out the thread sizes and also if there are AN hose fitting adapters available.
I am sorry I thought you were talking about the steering gear.  Yes it is a banjo fitting.  Do you have the banjo bolt
Banjo fitting is discontinued.  I might have one I will look.
You will also need 2 new copper crush washers 49155 Part # 49589-R8200 still available from Nissan
  • 3 years later...
