flatcat19 Posted May 12, 2018 Report Share Posted May 12, 2018 Take a walk around video and pics. Bring them to datslocos and ask some people what they think. Datslocos is a friendly bunch, as are most people that are into Datsuns. You can get ideas by looking at all the vehicles there and interact with chill people. You take that back. We're pricks. 2 Quote Link to comment
KoHeartsGPA Posted May 12, 2018 Report Share Posted May 12, 2018 Every last one of us! 2 Quote Link to comment
Dolomite Posted May 12, 2018 Report Share Posted May 12, 2018 You take that back. We're pricks. Yeah, I mean we’re cox n dix Quote Link to comment
whitey01 Posted May 13, 2018 Author Report Share Posted May 13, 2018 It's alive it's running I even have a couple inches of the clutch I'm happy 1 Quote Link to comment
flatcat19 Posted May 13, 2018 Report Share Posted May 13, 2018 Now fix the brakes and go to your show. We expect burnout vids next. Quote Link to comment
whitey01 Posted May 13, 2018 Author Report Share Posted May 13, 2018 After I post my video I probably won't get more than two replies before someone says lower it 2 Quote Link to comment
flatcat19 Posted May 13, 2018 Report Share Posted May 13, 2018 Lower it before you take pics then. 3 Quote Link to comment
whitey01 Posted May 13, 2018 Author Report Share Posted May 13, 2018 Here is my short vid i wanted to get something up so every one wont think i am a douchebag wasting evey one time 2 Quote Link to comment
Dolomite Posted May 13, 2018 Report Share Posted May 13, 2018 That’s a pretty nice truck, sounds like it could use a valve adjustment. Other than that, bleed those brakes and bring it to Datslocos. 2 Quote Link to comment
whitey01 Posted May 14, 2018 Author Report Share Posted May 14, 2018 Thanks I think it looks better in the video than it does in person maybe the brakes are not that bad that's kind of why I want to bring it to the car show maybe even have someone drive it How to spend a lot of money on those breaks I even had a super professional fix them after someone installed them Maybe I'm just so used to these new braking system or this truck is a lemon when it comes to brakes Quote Link to comment
racerx Posted May 14, 2018 Report Share Posted May 14, 2018 Don't they have drum brakes? Maybe u are not use to drum brakes. Quote Link to comment
Dolomite Posted May 14, 2018 Report Share Posted May 14, 2018 His has a wilwood disc conversion on it. Quote Link to comment
flatcat19 Posted May 14, 2018 Report Share Posted May 14, 2018 Probably doesn't have e the right master cylinder der hooked up. Quote Link to comment
racerx Posted May 14, 2018 Report Share Posted May 14, 2018 So he had wilwood brakes installed, what's the issue? If the shop, didn't do it right take it back. Quote Link to comment
flatcat19 Posted May 14, 2018 Report Share Posted May 14, 2018 The guy needs to know why it wasn't installed properly to raise a case. Not their parts; not their concern. Which master cylinder was installed? Could be a matter of incorrect pushrod length. 1 Quote Link to comment
Rick-rat Posted May 14, 2018 Report Share Posted May 14, 2018 Says in the video it is a wilwood M/C 2 Quote Link to comment
racerx Posted May 14, 2018 Report Share Posted May 14, 2018 Seems like several folks worked on the breaks and OP is not satisfied. I say take it back to whoever installed or adjusted them, pretty sure he paid some money. 1 Quote Link to comment
racerx Posted May 14, 2018 Report Share Posted May 14, 2018 Give me a brake... 2 Quote Link to comment
Dolomite Posted May 14, 2018 Report Share Posted May 14, 2018 Brake me off a piece of that kit kat bar 1 Quote Link to comment
KoHeartsGPA Posted May 14, 2018 Report Share Posted May 14, 2018 I'm going with improper brake bleeding, bench bleed the MC, then go to the furthest brake, RR, RL, FR, FL, then do it again, again and again until the brakes feel strong and there are no more air bubbles coming out with the fluid nor coming up the MC reservoir, some times you'll get very lucky and brakes will be solid after two rounds, other times takes several more, that really depends, I've been involved in both cases. I understand your MC is already installed and you won't want to take it back off, so undo the lines and bleed them there, then when no more air bubbles show up in the reservoir, connect lines and proceed with RR, etc, etc....get someone to help you, it is a two person job. Oh, and most importantly, make sure all brake lines are tight and no leaks anywhere, else you're just wasting time. Quote Link to comment
flatcat19 Posted May 14, 2018 Report Share Posted May 14, 2018 Is the wilwood master set up as a disc/disc MC or disc/drum. Not shops fault, not their concern. Especially since the truck has sat how long now? Also, shop did not supply parts. They'll tell you to pound sand if you expect to get anything for free. So many variables. Unfortunately, OP can't answer any of the needed questions. GL; moving on. Quote Link to comment
Ranman72 Posted May 14, 2018 Report Share Posted May 14, 2018 in the video the first thing i noticed was a kinked upper radiator hose get this fixed before you drive it to far truck looks good as is drive it and enjoy it if you would have opened a new account and changed your name eventually we would figure out it was you anyway dont try to be someone else just be you if its not safe to drive to datsloco drive a reliable car and come talk about yours with pics videos etc or trailer it and park the trailer around the corner :poke: your 521 camper you used to have did you ever bring it do a dave pare swap meet ? it looks very familiar to me Quote Link to comment
banzai510(hainz) Posted May 14, 2018 Report Share Posted May 14, 2018 Be honest I dont know why you cant start it up in a resonable timeframe just to keep it soemwhat maintained. Its a simle truck brake and hydralics mayb get flat if you dont drive them. So start driving it 1 every 2 months will be ok if you get to let it sit Be honest you mentioned 53 yrs old a couple times. If you had these vehicles for while you should know how to maintain them somewhat by now. Bushmen in Africa can keep these going seeing old Datsns and Landcruisers there and Im sure you can read and watch YOu tube vids. this should be EZ. You have a basic L motor and they are very simple. As for WILWOOD BRAKES i HAVE A FEELING THEY JUST REBADGED TOKICOS MASTER CYLINDERS. Like Tilton gear Reduction statrters. Just 280zx Hitachis. as for the 1200 you took it apart you should be able to put it back together. I got a couple of people here with Mustangs they took apart 20years ago. They not together yet and it isnt going to happen . Why? cause it would have happen already! I alwasy ask why they take them apart. To restore. Its better to run them till they just rust out by then you wont be into cars that much anyways. I dont even go to Datsun meets anymore. Love the cars but dislike ALOT of the owners.. But then theyre are the ones that overly do it and do it good. If your willing to learn we can guide you thru some of these things but you have to read up also on the subject. Also have the tools ready also. otherwise its a NO-GO timming light metric tools .Jack Jackstands for safety test light and or mutimeter 1 Quote Link to comment
