Sunshine521 Posted May 7, 2018 Report Share Posted May 7, 2018 1969 521 with a L18 engine. Truck has been sitting for about 7 months due to other projects. Fired it up and it idled fine but as soon as I give it gas it dies almost instantly but sometimes it flutters before dying out. Any ideas on why this is happening. 1 Quote Link to comment
datzenmike Posted May 7, 2018 Report Share Posted May 7, 2018 Probably the gas got stale from sitting. Does your carb have those two tubes with the oval cut openings??? Spray a bunch of carb cleaner down one of them. This will mix carb cleaner with the gas in the float chamber. Try starting and running this to get it to circulate and dissolve and deposits inside. 1 Quote Link to comment
flatcat19 Posted May 7, 2018 Report Share Posted May 7, 2018 You could get it to stay running on carb cleaner too. If it stays running you have your answer that you have a fuel issue. 1 Quote Link to comment
mainer311 Posted May 7, 2018 Report Share Posted May 7, 2018 Accelerator pump could be clogged/not squirting any fuel. If you have a lean idle, it might be dying from fuel starvation. 1 Quote Link to comment
racerx Posted May 7, 2018 Report Share Posted May 7, 2018 How does ur filter look 1 Quote Link to comment
banzai510(hainz) Posted May 7, 2018 Report Share Posted May 7, 2018 main jet plugged Timming off. replace the filter more often on a 521. tank get dirty cause of fuel hose in wheelwell. Not hard to start a truck once a week. I dont think the fuel went bad. Im sure it fine I let mine go 1 yr easy 1 Quote Link to comment
datzenmike Posted May 7, 2018 Report Share Posted May 7, 2018 Our gas may be better up here. I have 5 year old gas mix for my weed eater. Fires up every spring. 1 Quote Link to comment
