oukippy Posted May 2, 2018 Report Share Posted May 2, 2018 Hello, I'm still looking for a 620 but I'm already thinkig about changing rims and I have a question. French law is restrictive : wheel diameter must be stock or +1 inch => 14 or 15 inches ? wheel width must be stock or +/-1 cm => impact ? Consequently I want to know which size I must look after (I understood that the bolt pattern is 6 x 5,5") for the rim and the tire ? I was looking at autoanything.com (as an example, I don't know where to look at). Can I trust their database when they show me https://www.autoanything.com/wheels-rims/ion-alloy-71-wheels for a 620? Thank you for your help and patience ! oukippy 1 Quote Link to comment
datzenmike Posted May 3, 2018 Report Share Posted May 3, 2018 You're buying rims for a truck you don't have yet? You'd better wait. Spend the time and money on something more important like brakes, steering, suspension and eight other things. Depending on the build date on the tag on the driver's door jam, different years had different widths. The '78 and '79 had the widest for the disc brakes..... up to 02 '73......... 4" 03 '73- 07 '77...... 4.5" 08 '77on.............. 5" 1 Quote Link to comment
paradime Posted May 3, 2018 Report Share Posted May 3, 2018 Hey there oukippy, I don't believe you said you were buying rims, only that you had a question. That being said, Mike's data is correct. As for those online rim sites, many (including the one you posted a link to) don't support Datsuns let alone 620s. Best to find the size you're looking for and search that way. Best of luck Bother. 1 Quote Link to comment
datzenmike Posted May 3, 2018 Report Share Posted May 3, 2018 The picture may be a representative one used for all of that style rather than one for a 620 another for a Dodge, a different one for 4 or 6 or even 8 bolt... and then there's different widths and diameters. 1 Quote Link to comment
oukippy Posted May 3, 2018 Author Report Share Posted May 3, 2018 Of course I'm not buying, I just want to understand. Thank you for the data, I didn't know that for sure. Does it mean that people converting older ones to disk brakes are replacing their wheels ? Quote Link to comment
abbylind Posted May 3, 2018 Report Share Posted May 3, 2018 I bought 15" for future disc conversion on my 77 but I believe there are folks who have added discs with 14" and some grinding....Correct me if Im wrong Mike... Quote Link to comment
racerx Posted May 3, 2018 Report Share Posted May 3, 2018 Will wheel spacers work. I remember doing brake swap on my 65 falcon and had to use spacers so that it did not rub. 1 Quote Link to comment
datzenmike Posted May 3, 2018 Report Share Posted May 3, 2018 The '78 and up stock wheels are stamped differently and have clearance for the disc brake caliper. Many who have had '78s have upgraded to the larger caliper and vented rotor on the later 720 and early D21 Hardbody, and I've never heard they wouldn't clear. Spacers are alright if used sparingly but check your fender clearance. 1 Quote Link to comment
Charlie69 Posted May 3, 2018 Report Share Posted May 3, 2018 78/79 620 wheels clear the larger 720 & early hardbody (d21) rotors and calipers. The center hole in the wheel is smaller than the the later model hubs. Mike Klotz turns down the center of the later 720 and earlier D21 hubs to fit the 78/79 wheels. Quote Link to comment
