Gfunk13 Posted May 2, 2018 Report Share Posted May 2, 2018 Whats everyone doing with their exhaust when they lower their 620s mines bangin against the frame when i drive 1 Quote Link to comment
datzenmike Posted May 2, 2018 Report Share Posted May 2, 2018 You could notch the frame and weld in support. I had a transfer case built into a 2wd frame and the driveshaft went right into the cross frame that holds the torsion bars. I got a 6" length of 10" water pipe and cut away a section in the middle of the frame and welded in the pipe. The driveshaft now had a 10" 'window' to fit through and the frame strength was not compromised. You could scale this down for a smaller exhaust pipe. 2 Quote Link to comment
KoHeartsGPA Posted May 2, 2018 Report Share Posted May 2, 2018 Custom made to meet your demand, once you get behind the cab you've got all kinds of room to taylor it your way 1 Quote Link to comment
2wheel-lee Posted May 2, 2018 Report Share Posted May 2, 2018 A good exhaust shop can route it over the transmission mount cross member and over the torsion bar mount cross member. It's even easier if you have coilovers, as you can remove the upper torsion bar bolt perch. Quote Link to comment
