68Datsun510 Posted May 1, 2018 Report Share Posted May 1, 2018 Hey folks, I have an L19 with a DGV, freshly rebuilt in an attempt to stop the leakage out of the top. Still smell fuel and see seepage. Only when driving uphill does fuel escape. The front area of the carb shows fuel penetration through the gasket, no matter how tight. Carb always has the "residue look". Float is set correctly, pump is mechanical. Any ideas? Experiences? 1 Quote Link to comment
Doctor510 Posted May 1, 2018 Report Share Posted May 1, 2018 Mine has done that for 9 years, I just clean it regularly. I finally fixed it by lapping the top of the carb and the edges of the top on 800 grit sand paper. 2 Quote Link to comment
G-Duax Posted May 1, 2018 Report Share Posted May 1, 2018 Probably warped due to over tightening it over the years on an old gasket. Dr.510 has the right idea. A sheet of fine aluminum oxide paper on something really flat. Then pick up a food good gasket. 3 Quote Link to comment
banzai510(hainz) Posted May 2, 2018 Report Share Posted May 2, 2018 When I had a gas smell it was the accell pump diaphrame was broke and squirted gas in the exhaust manifold. 1 Quote Link to comment
Charlie69 Posted May 2, 2018 Report Share Posted May 2, 2018 Also check float level. 1 Quote Link to comment
Dolomite Posted May 2, 2018 Report Share Posted May 2, 2018 More incentive to get that vg in there. Do it now! 1 Quote Link to comment
68Datsun510 Posted May 2, 2018 Author Report Share Posted May 2, 2018 More incentive to get that vg in there. Do it now! Tell the people Im waiting on parts from.... Also check float level. Verified and adjusted. No improvement. Mine has done that for 9 years, I just clean it regularly. I finally fixed it by lapping the top of the carb and the edges of the top on 800 grit sand paper. I hadnt considered that... thank you! Probably warped due to over tightening it over the years on an old gasket. Dr.510 has the right idea. A sheet of fine aluminum oxide paper on something really flat. Then pick up a food gasket. Where do i buy a weber food gasket? 1 Quote Link to comment
G-Duax Posted May 2, 2018 Report Share Posted May 2, 2018 Where do i buy a weber food gasket? Anywhere they sell cardboard pizza crusts.... LoL.....I meant 'good' gaskets :rofl: 3 Quote Link to comment
Crashtd420 Posted May 2, 2018 Report Share Posted May 2, 2018 Anywhere they sell cardboard pizza crusts.... LoL.....I meant 'good' gaskets :rofl: I thought you were just referring to people here making gaskets from cereal boxes.... 2 Quote Link to comment
racerx Posted May 2, 2018 Report Share Posted May 2, 2018 Check pierce manifold, Gilroy, ca 1 Quote Link to comment
racerx Posted May 2, 2018 Report Share Posted May 2, 2018 Btw, if the base and or the adapter plate is warped, you will have vacuum leak. Is your idle unstable? 1 Quote Link to comment
nl320what Posted May 2, 2018 Report Share Posted May 2, 2018 Redline Weber Repair Kits 1 Quote Link to comment
Stoffregen Motorsports Posted May 2, 2018 Report Share Posted May 2, 2018 Though it may not help with the "leak" problem, there is a different float that you can use to allow more fuel into the bowl. It's from a Ford Pinto, and I believe you can get it from Pegasus Racing, or anyone else who has experience with building a racing DGV. Use that in conjunction with a larger needle and seat, or a grose jet, to maximize fuel level control. I had a Weber DGV on my first rock crawler (Jeep CJ5) and it spilled over on steep inclines, to the point that it would flood over and die. I wonder if you're having similar issues? Or is it really leaking out of the bowl? 1 Quote Link to comment
G-Duax Posted May 2, 2018 Report Share Posted May 2, 2018 I thought you were just referring to people here making gaskets from cereal boxes.... I'm guilty of that.... :blush: 2 Quote Link to comment
Crashtd420 Posted May 2, 2018 Report Share Posted May 2, 2018 I'm guilty of that.... :blush: Whatever keeps them on the road.... I won't even admit to the things I've done.... 1 Quote Link to comment
Charlie69 Posted May 2, 2018 Report Share Posted May 2, 2018 I prefered the Wheaties boxes for gasket making. Quote Link to comment
Charlie69 Posted May 2, 2018 Report Share Posted May 2, 2018 Redline Weber Repair Kits Do they have any knowledge of the Datsun's? Are they selling real Webers made in Spain? Pierce manifolds has decades of Datsun experience. 1 Quote Link to comment
racerx Posted May 2, 2018 Report Share Posted May 2, 2018 Hear ld 50/50 about getting real Webber from red line. 1 Quote Link to comment
68Datsun510 Posted May 3, 2018 Author Report Share Posted May 3, 2018 Btw, if the base and or the adapter plate is warped, you will have vacuum leak. Is your idle unstable? Negative Though it may not help with the "leak" problem, there is a different float that you can use to allow more fuel into the bowl. It's from a Ford Pinto, and I believe you can get it from Pegasus Racing, or anyone else who has experience with building a racing DGV. Use that in conjunction with a larger needle and seat, or a grose jet, to maximize fuel level control. I had a Weber DGV on my first rock crawler (Jeep CJ5) and it spilled over on steep inclines, to the point that it would flood over and die. I wonder if you're having similar issues? Or is it really leaking out of the bowl? Mine is just leaking out of the bowl, driving characteristics are unchanged Do they have any knowledge of the Datsun's? Are they selling real Webers made in Spain? Pierce manifolds has decades of Datsun experience. The weber I have is an oldy, no recent manufacture. Pierce is top notch with top shelf pricing unfortunately. It just seems like the float stops doing its job when the nose is pointed high, bowl overflows out the vent. Ill need to get a gopro under there or something 1 Quote Link to comment
datzenmike Posted May 3, 2018 Report Share Posted May 3, 2018 My water pump, thermostat housing and thermostat cover gaskets are all from a Cheerios box and are 3 to 5 years old. 1 Quote Link to comment
banzai510(hainz) Posted May 3, 2018 Report Share Posted May 3, 2018 buy new weber done good for 15years 1 Quote Link to comment
68Datsun510 Posted May 3, 2018 Author Report Share Posted May 3, 2018 Working on a VG30 swap, im just limping the L along until i have everything. engine runs fantastic, weber is the only issue. 2 Quote Link to comment
