yifith Posted April 29, 2018 Report Share Posted April 29, 2018 Ok so I changed my valve cover gasket today and didn’t touch anything els.when I was done hooked up the spark plug plugs and when to start it,it won’t start.it cranks but don’t start.the carburetor spits out a little gas and smoke coming out...any advice I’m so lost.thank you. Quote Link to comment
yifith Posted April 29, 2018 Author Report Share Posted April 29, 2018 Need help I changed my valve cover gasket put the spark plugs back together and and try to start it it won’t start.it cranks and the Weber 32/36 carburetor spits out a little gas and little bit of smoke and it won’t turn on.before I did I all this truck was running perfect. Quote Link to comment
Doctor510 Posted April 29, 2018 Report Share Posted April 29, 2018 Check the firing order. COUNTER CLOCK WISE 1-3-4-2 2 Quote Link to comment
flatcat19 Posted April 29, 2018 Report Share Posted April 29, 2018 Wires on wrong plugs. Roll to TDC. Rotor from distributor now points at the #1 position. Plug wire going to spark plugs number one. Now install the rest of the wires in order. 1-3-4-2 in a counter clockwise order. It's possible if wire order is correct, maybe wire not fully seated against plug. 1 Quote Link to comment
datzenmike Posted April 29, 2018 Report Share Posted April 29, 2018 2 and 3 are swapped. It Haaapens 2 Quote Link to comment
yifith Posted April 30, 2018 Author Report Share Posted April 30, 2018 So I put the spark plug wires back.now when I cranks it exhaust back fire...did Is the the valve cover?ive put gasket and Rtp... Quote Link to comment
racerx Posted April 30, 2018 Report Share Posted April 30, 2018 Maybe the coil wire? Quote Link to comment
flatcat19 Posted April 30, 2018 Report Share Posted April 30, 2018 Timing is off. Did you turn or bump the distributor at all? 1 Quote Link to comment
datzenmike Posted April 30, 2018 Report Share Posted April 30, 2018 Plugs are wet. Try in the morning. Quote Link to comment
banzai510(hainz) Posted April 30, 2018 Report Share Posted April 30, 2018 when changing a valve cover gasket one only needs to unclip the distributor cap and fold over the wires and clip dist cap back on. Simple did you pull the plug wires and the ends inside bust off? that could be a issue 5 Quote Link to comment
