Sign in to follow this
loudandgreen
outlaw questions
Its been years! I don't have my 720's or d21's anymore but hope to find something after this upcoming project
I'm trying to figure out what i would need to do to run dual outlaw carbs on a LS .... Yes i know LS are played out but I'm trying to put a touch of ratsun funk on it by running webers.
I seen the weber 48 set ups but that's not my style. I've played with webers in the past and tinkered with them some. I don't remember much about them other than they were reliable and fun if sealed correctly
Thanks!
Share this post
Link to post
 What about twin R-1 motorcycle carbs on a cross manifold? That's like 8 little SU carbs.
Share this post
Link to post
Hiya Mike! I've missed you and Tloof lots!
I will google those in a few. I hope the set up is around the $1k -/+ mark.
Share this post
Link to post
Tloof was really hard core 720. I don't know where he is now.
Share this post
Link to post
Last i seen he was on a 720world forum or FB page. I remember seeing him pop up on 1 of those.....with in the last year or so
Share this post
Link to post
Anyone make a dual 4bbl carb intake for it? That and some adapters would really kill your horsepower potential, but it would work...    ^_^
Share this post
Link to post
But it would be cool........
Share this post
Link to post
Yes I've seen a few different dual quad intake manifolds on Summit Racing and jegs and I've also seen an adapter that looks like it's for side draft carbs OR ITB to 4bbl (im looking into this as well but not looking promising for obvious reasons)
Being that Mike mentioned the Yamaha R1 carbs (cv started in 2002 from what i gather) im thinking about that as well.
Share this post
Link to post
Thanks! Im going after a cool facter even though I've been flamed for it or just totally ignored by others outside of ratsun.
I am trying to make this a functional and somewhat feasible set up, trying to keep it around $1000+/- or less. i will be starting on the build this winter if nothing else attacks what little money im trying to set aside for it.
I was even thinking TBI from early 90's chevies at 1 time lol
Share this post
Link to post
Adapters wouldn't be hard to make. Get some 1/2" thick aluminum plate and get to drilling/cutting.  ^_^
Share this post
Link to post
O yes im familiar with aluminum stock. I've made adapters for carbs and solid mounts for engines and trannies over the years.....im just worried about putting all that work drilling and shaping and then find out there's a more efficient adapter design or intake for the time/work that i put into it.
I know it would be one hell of a job to do and probly costly but i was thinking about making a wooden form (can't think of the real term for it) that has the dimensions i need for the original fitment of the factory intake manifold for the LS and fit the flanges and custom runners where i need them in the form and figure out a way to temporarily stick them that way till i could find someone to weld them....or jb weld the hell out of the connections then grind everything clean.
Share this post
Link to post
This is not something that is going to happen.   B)
This is a terrible plan.   ^_^
Guess what gasoline does to most low grade epoxies? It's not good.
Share this post
Link to post
Now, I'd bet if someone makes a six pack manifold, and you got some 2bbl-to-Weber adapters (which are a thing you can buy), then...
Share this post
Link to post
I guess i will figure out the intake manifold design on my own if i don't decide to buy 1 of the premade ones from summit or jegs (haven't looked at all the ls carb intakes from jegs yet, may be exact selection as summit)
For now i suppose i will study on how to set up an outlaw carb or 2 for an LS or v8 in general. I hope the next few months fly by so i can get my hands on some parts.
Where would i find some great literature on setting up a carb for applications? Pictures would be nice too lol.
Share this post
Link to post
The 38/38 weber is a large V6 small V8 carb. For an LS get 650- 750 Holly.
Share this post
Link to post
So it's figured out then. Ill scrap the dual outlaws project and be like everyone else around here that lives near me with a carb on a LS LOL.
I'll figure it out even if i have to stay at a friends out of town for a week or so and have him show me.
Thanks anyway...
Share this post
Link to post
No be original, that's all that matters if you ask me.
Share this post
Link to post
Folks can best advise on what they know/have done. Take it for what it is and proceed with your project. Waaaay less nay sayers once metal takes shape.
Share this post
Link to post
That's why he's wanting to run two.   B)
Share this post
Link to post
I know this is kind of a dumb question to ask this far into the process BUT being i will be running the outlaws for a little while till i get bored then swap out the intake or carbs later.
What is the max hp dual outlaws would support? I'm going to try for a stroker kit to reach 500-750hp BUT for time being i could run the outlaws on almost stock internal dimensions. ...till i get bored lol
Share this post
Link to post
I'd wager 150-175hp each max. It's really more about volume. The LS flows well enough that even with two it will be struggling to breathe a little.
Although Weber claims one 38/38 is capable of flowing 390cfm, I'm not sure that sounds plausible. If they are correct, 780cfm should be enough...
Share this post
Link to post
Thanks, years ago i had a 390 autolite (i think) on either a z24 or the vg30....can't remember but it was a great size carb from what i remember. If i can get that same peppy power out of that LS with the 2 outlaws then i think that would do me good for a little while...
I'm going to push for the outlaws as hard as i can but....we will see
Now I'm remembering about the 390 autolite...i don't think i seen one of those since i had mine but i did have to dig through a mans junk yard to find that one. The owner looked at me kinda weird because i was so damned happy to find it lol
Share this post
Link to post
Run a six pack. Run the center one for mileage and have the others come in at 3/4.
Share this post
Link to post
Pretty sure that's a copy of a Weber 38/38 isn't it? Or do you mean the 2bbl Holley knockoff?
Share this post
Link to post
I think you're thinking of the holley 5200 series carbs that were the 32/36 webers licensed by holley that were used on vehicles like the ford pinto and lots of others if i remember correctly
The autolite carbs turned motorcraft or something moto-. I welcome correction on that if any.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
