Sign in to follow this
noramost
200SX 5 spd, 1983
I'm parting out an 83 200SX with a 5 spd ans some sort of t-belt engine, will the trans work in anything else?
Share this post
Link to post
This is a dog leg trans, eh? Reverse over first?
Trans, yeah. Rear-end...prepare for lots of PMs.
If I still had a 210 I'd be all over that.
Share this post
Link to post
Now that I have actually paid attention to what OP wrote...there is t much on that 200sx that will work in the Datsun world.
Car is more valuable to someone as a whole. At least here.
Share this post
Link to post
Check the block to see if the motor is a CA18 or CA20.  Tyranny will not fit an L series.
:rofl:
Sig line material there
No mention of what T belt motor...
Share this post
Link to post
Also, not possible if stock. 1983 would be an S110 chassis, Z20E/Z22E engine (timing chain). 1984 would be an S12 chassis, CA20E engine (timing belt).
CA trans only fits a CA. Z20/Z22 trans really only fits a Z20/Z22/Z24 engine, but can be used on an L in a pinch.
Share this post
Link to post
'82-.83 S110 200sx were Z22E engines. '84 and on S12 200sx had the CA18ET, CA20E and VG30E engines. The transmission is a direct bolt in, to the earlier '80-'81 S110 200sx and the '81-'86 gas engine 720 if you check the lengths.
Share this post
Link to post
Thanks King Rat if I understand you correctly you are saying my C-5spd will fit a 81-86-Z-22-24 but it won't fit my 92-D-21 Z-24
Share this post
Link to post
Everything I said was for the 31.5" long FS5W71B transmission used on a Z series engine.
The D21 Hardbody truck 71C is (I think) slightly shorter than the 71B but might fit. The longer 71B may not fit where the 71C fit. Too tight? So the 71B will bolt to the Hardbody Z24 but may be a little long. In addition the 71B is a weaker transmission than the 71C.
The S13 and S14 car 71Cs were much longer and not even close.
Share this post
Link to post
A CA 5 speed only fits a CA engine.
Share this post
Link to post
Engine verification has not been provided...thus year of vehicle still unknown.
Share this post
Link to post
Thanks guys, it's a C20, I think I will take it to the crusher this week, anybody need a 5-spd boat anchor?
Share this post
Link to post
 There were two CA 5 speeds, a wide used on the CA18ET and a mid ratio used on the CA20E but both have the much better 2nd to 3rd shift without the big RPM drop. Second is moved very slightly away from first and closer to third so the drop is less noticeable. (true the first/second now has a 5% increase in RPM drop but it's in the lower gears/speed and not as noticeable as the 2/3 shift at higher speeds) On the CA 5 speeds the 2/3 shift RPM drop is 33% (wide) 31% (mid) verses the 37% drop on all the previous wide and mid ratio transmissions.
Depends on the year CA, it's still a good 5 speed. Up to '86.5 (model year) it was a 71B. After '86.5 it was a 71C.
A 4 or 5 speed 71B front case and a new 56mm counter bearing will convert it to L series IF it's a 71B to begin with. After is problematic, but doable.
Share this post
Link to post
The first time I went to a factory Datsun school in Gardina in 1969 there where a lot of Datsun Auto Engineers running around the dyno room writing things down on their clip boards in their white lab coats, were you one of them? I'm impressed!
Share this post
Link to post
I have an '85 CA18ET 5 speed laying around. That's the wide ratio with the low 3.592 first gear and 62mm counter bearing. I counted the main and counter gears and confirmed them. I also have a spare L series front case for it..... some day....
Some of this stuff I heard about or researched it but can't always remember the exact numbers. But I know where to look for it. Some I wrote down and saved.  Have about 600+ 'tranny' related pictures.
Share this post
Link to post
Okay, now you're just taunting me...
Share this post
Link to post
FYI, it's just a matter of machining out one of the holes in the front half of the case for the larger shift rail. Done this a few times before to be able to use a KA/SR trans behind a turbo L-series...
Share this post
Link to post
Yes a 16mm hole where the 14mm was for the 1/2 shift rod. It also requires machining around the counter bearing area on the front case for clearance or risk pinching when the case bolts are tightened up.
FS5W71C
FS5W71B case modified to take a 71C internal gears, 62mm counter bearing and 16mm 1/2 shift rod.
See that thin toothed wheel just behind the lower counter bearing and in front of the counter drive gear? I think this is an oil slinger to lube the two large bearings, can't see any other use for it. This will pinch the front case if it isn't clearanced. 71C gears are also wider (front to back) to increase strength so not much room left.
In the top picture near the 16mm hole... see that little J shape and the small hole. I think this and the front cover plate supply splash oil to the two front bearings through it.
71B and 71C front covers. See the extra slots added on the C?
Share this post
Link to post
King Rat can you build a Nissan 5spd for an in-line engine using a 4:11 dff that makes it all the way across the intersection before shifting to 2nd? We all know Nissan can't
Share this post
Link to post
Show us a picture of L-trans bell-housing that bolts to a Toyota 5-spd, we can make a Toyota pilot bushing and run a Toyota disk under a Nissan p-plate and then we can go slow faster
Share this post
Link to post
