Madkaw Posted September 8, 2018 Author Report Share Posted September 8, 2018 Hey Charlie, I hope you got your box of stuff for your door panels . Im still lacking a front bumper center piece . Love to find a good set of rear tail lights too! 1 Quote Link to comment
Charlie69 Posted September 8, 2018 Report Share Posted September 8, 2018 Yes sir I received the box of parts, thank you. Madkaw parts needed. Black bumper center piece and good tail lights for an 83/84 Do you still need a valance? Quote Link to comment
Madkaw Posted September 10, 2018 Author Report Share Posted September 10, 2018 Yep- valence too! 1 Quote Link to comment
Charlie69 Posted September 11, 2018 Report Share Posted September 11, 2018 I hope to be in the yards again this weekend. Had back and hip problems that took me out circulation. Quote Link to comment
Madkaw Posted September 12, 2018 Author Report Share Posted September 12, 2018 Strange coincidence- I’m out of circulation for my back also - surgery ? 1 Quote Link to comment
Charlie69 Posted September 14, 2018 Report Share Posted September 14, 2018 I will pray for a speedy recovery for you. Were you needing an AC harness? Or am I confusing you with Clumsy bird? Quote Link to comment
Madkaw Posted September 15, 2018 Author Report Share Posted September 15, 2018 Don’t need a harness. I have a 84 locally that has AC 1 Quote Link to comment
Madkaw Posted September 18, 2018 Author Report Share Posted September 18, 2018 The more I look at this frame the more I’m pissed I didn’t take a closer look before painting . These welds are horrible . Are all the 720’s this bad? I’m half tempted to start grinding and welding these over again. I’d have to repaint , but I don’t know if I can let this go 1 Quote Link to comment
datzenmike Posted September 18, 2018 Report Share Posted September 18, 2018 Normal welding. It's not done with robots like shit today and is probably thicker metal. 1 Quote Link to comment
Madkaw Posted September 18, 2018 Author Report Share Posted September 18, 2018 I noticed the welds on items jigged off the frame are better . It seems the amateur welders were attaching smaller items . Still crappy weld with poor penetration 1 Quote Link to comment
Stoffregen Motorsports Posted September 18, 2018 Report Share Posted September 18, 2018 I can't advise you on whether or not you should strip and weld, but those kind of welds are pretty normal on a frame. When I am prepping a frame, I usually take the time to hit the welds with a disc sander just to knock off the sharp edges, but I rarely find anything actually needing to be re-welded. The worst I ever saw was a 1974 Jeep CJ5 I restored a couple years ago, I did have to weld up about 60% of the factory welds on that frame. Those were so bad they were actually coming loose and cracking in areas. I can't see the welds on a Nissan frame actually needing to be re-welded. Only your eyes will tell you that. 1 Quote Link to comment
Madkaw Posted September 18, 2018 Author Report Share Posted September 18, 2018 I agree with you - just didn’t expect some of the welds to look that bad. Of course some of the bead welds on my 71 Z aren’t exactly pretty either. Trying not to get caught up in - while I’m at it- repair , that turns into full blown restoration. I guess with a 720, one should be happy the frame isn’t rusted away! 2 Quote Link to comment
Charlie69 Posted September 19, 2018 Report Share Posted September 19, 2018 Those ugly welds have lasted 35 years without failing. 1 Quote Link to comment
seattle smitty Posted September 20, 2018 Report Share Posted September 20, 2018 (edited) No doubt that's the practical attitude, Charlie, and some really horrible welds have somehow sufficed to keep metal parts stuck together. But any good welder can't help seeing bird-poop welds as almost personally offensive. It's like a lot of the work a decent craftsman does; nobody else will ever see the particular example of fine work he did, almost no one would care, but HE knows, and feels, what, just a little virtuous for having done it better than he had to. Welding is one of the prime providers of evidence for my contention that the factory engineers, Nissan/Datsun's or whomever, absolutely DO NOT always know better than the rest of us about their products. Take a look at the link below to stories of a cranky Englishman named Ed Craig who moved to the States and has been a welding consultant for many years. Occasionally one of the car makers will call him in to look at problems on their robotic welding lines, and what he has found will blow your mind if you know much about welding. The story, which I read on his site years ago and still has me shaking my head (about halfway down the linked page), involves a Chrysler chassis line. The chief welding engineer (and again if you are an experienced welder you'll hardly believe this) had specified the use of 5/64" Innershild (no gas) wire to weld the stamped-steel chassis members. This wire is something you'd choose for constructing tall buildings, and never thin sheetmetal. Of course, despite the best efforts of the guys working under this idiot, no amount of adjusting the welder and robot controls could keep them from blowing holes. They had a big rework crew of guys going full-time manually welding up the bad welds, yet somehow neither the chief engineer nor management could understand the problem. Ed Craig, who might have stood in stunned disbelief had he not seen many similar situations, immediately changed to an appropriate welding wire, reset the robots, and was quickly turning out flawless welds. Yet astoundingly (unless you have been around corporate managers), in the face of this evidence the chief engineer insisted that he knew what he was doing, kept his job, and continued doing things his way.https://weldreality.com/ROBOTmanagement.htm (Again, scroll about halfway down the page to get to the story I related). Edited September 20, 2018 by seattle smitty 1 Quote Link to comment
Madkaw Posted September 20, 2018 Author Report Share Posted September 20, 2018 The funny thing is- I’m just an average welder , not certified , one welding class, never did it for a living , and those welds bother me . I’ll be glad when they are covered up with other articles of machinery that are made better - I hope 1 Quote Link to comment
Charlie69 Posted September 21, 2018 Report Share Posted September 21, 2018 I agree seattle smitty but with all the other aspects of my build on my 66 520 the bird poop welds on the 1980 720 frame will wait until I tear it down for paint. I believe in if it aint broke don't fix it. Quote Link to comment
seattle smitty Posted September 21, 2018 Report Share Posted September 21, 2018 (edited) I feel your pain, Kaw. There is no excuse for that level of welding in a professional setting, whether they were applied manually or by robotics. It says something when you see some of the flawless beads on Japanese motorcycle frames, WHERE THEY SHOW, and then you look at the bird-poop welds under a chassis where a customer will never see them. If you didn't read that link I posted, you might take a look just to see the opinion of an expert who has seen corporate attitudes about fixing bad welds that could prove be dangerous to customers, including some that already have. Unlike the big corporations, where the bosses are rarely held personally liable, the owner of your little local welding shop knows very well that the lawyers will take him for everything he owns, even after his insurance coverage is used up, if someone is or can claim to have been hurt by something to do with the welder's work. Welding can have consequences. www.weldingweb.com has a couple of long-running threads devoted to the failures of amateur "welders;" take a look at this one on homemade (and a few commercial) trailers, and you'll start thinking you shouldn't be on the roads in anything smaller than a Humvee:https://weldingweb.com/showthread.php?372021-Trailer-fail-pics Here, this one is probably better. Stoffregen, you'll like the roll cage at the bottom of page 1 of this thread:https://weldingweb.com/showthread.php?139711-Welding-Fail!-post-pics-here Edited September 21, 2018 by seattle smitty 1 Quote Link to comment
Charlie69 Posted September 23, 2018 Report Share Posted September 23, 2018 My problem is: 1- I can not weld 2- I sold my welder 3- My brother, Garret's back has gotten bad enough that he will not be able to do much fabricating and welding for me in the future. Shawn a friend from Oregon will be doing my fab and welding in the near future. I need to buy another welder. Quote Link to comment
Madkaw Posted October 15, 2018 Author Report Share Posted October 15, 2018 Got the old truck some jewelry ! 2 Quote Link to comment
Madkaw Posted November 3, 2018 Author Report Share Posted November 3, 2018 Finally doing some assembly ! 1 Quote Link to comment
Madkaw Posted November 9, 2018 Author Report Share Posted November 9, 2018 Can someone tell me if the longer hockey stick type arm rests bolt into all door on these trucks ? I have the short straight ones , but would like to get the bigger door arm rests . 1 Quote Link to comment
Charlie69 Posted November 12, 2018 Report Share Posted November 12, 2018 I will check tonight. Quote Link to comment
Charlie69 Posted November 13, 2018 Report Share Posted November 13, 2018 Yes all three screws for the large arm rest and door pull screw into the door. I will try to bet some pictures tomorrow. Quote Link to comment
Madkaw Posted November 13, 2018 Author Report Share Posted November 13, 2018 16 hours ago, Charlie69 said: Yes all three screws for the large arm rest and door pull screw into the door. I will try to bet some pictures tomorrow. Thanks 1 Quote Link to comment
Charlie69 Posted November 14, 2018 Report Share Posted November 14, 2018 Did not get pictures today will try tomorrow. Quote Link to comment
