Madkaw Posted July 12, 2021 Author Report Share Posted July 12, 2021 4 hours ago, Charlie69 said: The difference in the 2 wd and the 4 wd steering boxes are the pitman arms. The boxes are the same. I think I also read that the boxes were the same all the way into the D21 models ? 1 Quote Link to comment
Madkaw Posted July 21, 2021 Author Report Share Posted July 21, 2021 My new configuration . All eight plugs are firing . It’s tight , but fits . Now I need to retard the timing a little 1 Quote Link to comment
NC85ST Posted July 21, 2021 Report Share Posted July 21, 2021 Awesome work. Nice truck. 1 Quote Link to comment
Madkaw Posted July 22, 2021 Author Report Share Posted July 22, 2021 Guys - I need a new AC compressor . Best options ? Why is there separate listings for 85 and 86 ? I want to make sure I get the right one . This is the one that fits my lines 1 Quote Link to comment
powderfinger Posted July 23, 2021 Report Share Posted July 23, 2021 (edited) I had a difficult time finding one for my 85 720. I ordered one from Autozone but it ended up being the wrong one. I got lucky and got a used one off of another truck to work. I seem to remember a site that sold rebuilt ones but can't remember where. They wanted like $350 for them if I remember correctly. Rock Auto usually claims they have them in stock but if you look at the photos you will see that it is not the correct one. The ones they carry may be for the D21? Might be easier to get new hoses made that fit the compressor everyone stocks with the single bolt that holds the hoses on. Those seem to be easy to find and they fit perfectly. I may do that if/when my old compressor fails. Edited July 23, 2021 by powderfinger 1 Quote Link to comment
Madkaw Posted July 23, 2021 Author Report Share Posted July 23, 2021 I ordered this one https://www.partsgeek.com/catalog/1985/nissan/720/climate_control/a-fs-c_compressor.html which looks like mine , but still hard to tell . Hoping for the best 1 Quote Link to comment
datzenmike Posted July 23, 2021 Report Share Posted July 23, 2021 I believe in the after market, anything designated as an '86 defaults to the later D21 Hardbody when ordering parts. Build dates for the 720 from June to November '85 are technically '86 model years. If ordering from the Nissan dealer the build date on the truck would avoid this blunder. 1 Quote Link to comment
Charlie69 Posted July 23, 2021 Report Share Posted July 23, 2021 What Mike said and I believe 86 was the year for 134A in Nissan trucks and if I am correct it started with the D21 Hardbodies. Quote Link to comment
NC85ST Posted July 23, 2021 Report Share Posted July 23, 2021 I had an ‘88 Subaru a couple of years ago that I could not find an a/c compressor for. I found a company that I sent my old compressor to and they rebuilt it and sent it back to me. Worked great. That might be an option. 1 Quote Link to comment
Madkaw Posted July 24, 2021 Author Report Share Posted July 24, 2021 So I have a miss when I run all 8 plugs . It’s a little pop at the tail pipe that I can hear at idle . It’s erratic - not constant . Don’t feel it or hear it when driving around . Kind of annoying that all the work to get the other 4 plugs firing and now I have a miss. I pulled all the exhaust spark plug and they looked perfect burn . The engine has always had a tick and never idled as smooth as I would like . Also I get oil around the plug on #4 exhaust . I think there is a bad guide or something with this head . I need to rebuild another one to have ready for EFI - so maybe that will fix it . 1 Quote Link to comment
datzenmike Posted July 24, 2021 Report Share Posted July 24, 2021 Single plug operation will have an ignition advance of around 10-120. Dual plugs, two ignition points, will shorten the burn time so ignition timing will need to be more retarded. Stock Z24 is 50 +- 20 1 Quote Link to comment
Madkaw Posted July 27, 2021 Author Report Share Posted July 27, 2021 So the compressor was wrong 😡 I found a shop that said they can rebuild mine . I sent them both of my boat anchors and hope to get one good one out of the pair . I let everyone know how it turns out . Ive about decided to stay with a single plug operation . I don’t want to spend the time to figure out why the engine misses with both coil packs . Maybe later I will revisit this .With full control of spark I have no fear to design a timing curve for this engine . I will post up my timing table once I am confident if the curves . 2 Quote Link to comment
Madkaw Posted July 30, 2021 Author Report Share Posted July 30, 2021 Next project arrived today 1 Quote Link to comment
Madkaw Posted July 30, 2021 Author Report Share Posted July 30, 2021 Okay - have kind of a weird issue - weird because I can’t figure out what’s happening. The drivetrain chatters when pulling up a hill from a dead stop . It only seems to happen when the engine is hot . The chatter makes the whole cab shake and groan . I’m always suspicious of these transmissions since they break all the time , but don’t know what would cause that chatter with a trans . There’s no real noise associated with it . It doesn’t seem to happen when I first drive the truck . Clutch doesn’t feel like it’s slipping at any other time while driving - so I don’t believe it’s the clutch . I know these trucks have their inherit issues so I’m hoping someone else dealt with this . 1 Quote Link to comment
Charlie69 Posted July 31, 2021 Report Share Posted July 31, 2021 U-joints or carrier bearing bad? Quote Link to comment
Charlie69 Posted July 31, 2021 Report Share Posted July 31, 2021 What is the EPS out of? I have one from a 2009 Nissan Versa I am going to install in my 84 720 2wd King Cab ST. Enventually I will get one in my 86 720 2wd King Cab and my 66 520. For me that is a winter project. Quote Link to comment
Madkaw Posted July 31, 2021 Author Report Share Posted July 31, 2021 Prius - U- joints wouldn’t only act up when hot . 1 Quote Link to comment
Charlie69 Posted July 31, 2021 Report Share Posted July 31, 2021 I chose to try to stay with Nissan parts. Quote Link to comment
Madkaw Posted July 31, 2021 Author Report Share Posted July 31, 2021 9 minutes ago, Charlie69 said: I chose to try to stay with Nissan parts. I went with the best deal and one that included shafts 1 Quote Link to comment
datzenmike Posted July 31, 2021 Report Share Posted July 31, 2021 13 hours ago, Madkaw said: Okay - have kind of a weird issue - weird because I can’t figure out what’s happening. The drivetrain chatters when pulling up a hill from a dead stop . It only seems to happen when the engine is hot . The chatter makes the whole cab shake and groan . I’m always suspicious of these transmissions since they break all the time , but don’t know what would cause that chatter with a trans . There’s no real noise associated with it . It doesn’t seem to happen when I first drive the truck . Clutch doesn’t feel like it’s slipping at any other time while driving - so I don’t believe it’s the clutch . I know these trucks have their inherit issues so I’m hoping someone else dealt with this . From a stop? Is this only as the clutch engages? or only first gear? or all the way up hill in any gear?? Is the throttle moderate or heavy and to the floor? 1 Quote Link to comment
Charlie69 Posted July 31, 2021 Report Share Posted July 31, 2021 I went and pulled mine from the junk yard for $67. 1 Quote Link to comment
Madkaw Posted July 31, 2021 Author Report Share Posted July 31, 2021 2 hours ago, datzenmike said: From a stop? Is this only as the clutch engages? or only first gear? or all the way up hill in any gear?? Is the throttle moderate or heavy and to the floor? From a stop in first gear on a grade . I’m not giving any more throttle than normal .Drivetrain shudders and makes cab shudder . Clutch seems to engage and the truck moves fine . Hot spot on clutch ? 1 Quote Link to comment
Madkaw Posted July 31, 2021 Author Report Share Posted July 31, 2021 1 hour ago, Charlie69 said: I went and pulled mine from the junk yard for $67. I was too lazy and my back won’t do that kind of work 1 Quote Link to comment
Charlie69 Posted July 31, 2021 Report Share Posted July 31, 2021 My back and neck won't either, but I have good drugs! LOL 1 Quote Link to comment
Madkaw Posted July 31, 2021 Author Report Share Posted July 31, 2021 3 hours ago, datzenmike said: From a stop? Is this only as the clutch engages? or only first gear? or all the way up hill in any gear?? Is the throttle moderate or heavy and to the floor? I need to try and make this happen when the drivetrain is cold . I’m assuming this is when things are hot - but I only back down my driveway . Don’t do much grade climbs cold 1 Quote Link to comment
