Antihero983 Posted March 29, 2018 Report Share Posted March 29, 2018 Hey all, first off, great forum you have here. I recently purchased a 1967 520, and am currently debating taking the cab and bed off. I have searched a little bit, and am still looking for a writeup on how to do so. Any help at all is appreciated. Thanks!! 1 Quote Link to comment
wayno Posted March 30, 2018 Report Share Posted March 30, 2018 What do you want to know? Unless you have the proper tools or 4 weight lifter friends it's not going to be easy, I have lifted the bodies off the frame several different ways, the easiest way for me was using air jacks on both sides like in the photos below. I also have lifted the body off the frames using a engine lift thru the door and an air jack in the front, the air jack can be replaced by a guy with muscles, but after in the air one has to set the body on jacks with 4X4s going across so you can roll the frame out from under the body. 2 Quote Link to comment
Antihero983 Posted March 30, 2018 Author Report Share Posted March 30, 2018 What do I do as far as disconnecting the steering column? Also, What else should I disconnect just to be on the safe side? This is my first time dealing with a full frame Datsun, all I have previously dealt with are the S30 Zs. 1 Quote Link to comment
mikec4193 Posted March 30, 2018 Report Share Posted March 30, 2018 I got this set-up last fall when I was pulling a cab off of a 1948 Chevy truck I had picked up...something like what Wayno has or something like this would be an awesome asset to have if you want to pull a cab off of a chassis...I pulled a 54 GMC cab once and set it on S10 chassis with a cheapo cherry picker from Harbor Freight (I took the doors off and put the arm inside the cab to make it work)...good luck with your project and post more pics as you go along... 2 Quote Link to comment
DanielC Posted March 30, 2018 Report Share Posted March 30, 2018 Like a 521, a 520 has a solid steering column. You have to remove the steering column from the truck before you remove the cab. 1 Quote Link to comment
wayno Posted March 30, 2018 Report Share Posted March 30, 2018 I call that a gantry crane above, the problem with them is most will just put a strap thru the cab and lift it up, but that way tends to bend the drip rails/gutters on both sides of the cab above the doors if not bending the top of the cab in general. Like Mike a couple posts above I used to use a cherry picker thru the door opening, but the cab is hard to balance this way and the front of the cab needs to be lifted at the same time, I put a 4 foot long 4X4 in the tunnel, wrapped a chain around it and lifted the cab thru the shifter hole, now I lift them with the air jacks like in my photos of my last post, it's way easier for me to do by myself. You will need to remove the steering gear/box and column before removing the cab, this means you will need to remove everything from the Pitman Arm and column in the cab, do not lose any pieces, also the clutch/brake lines need to be disconnected at the frame connections, remove the shift lever, e-brake cable from the lever inside the cab, disconnect the wiring from the engine, remove the radiator and cab(6)/box(8) mount bolts, there is likely something I have forgotten, I generally lift it slowly and disconnect anything I have forgotten before breaking it. Do not cut anything unless you have replacements. 3 Quote Link to comment
Antihero983 Posted March 30, 2018 Author Report Share Posted March 30, 2018 Awesome! Thank you all so much! Its something that may happen later this year, so I just want to be prepared, especially if I deem it necessary to do it sooner. 1 Quote Link to comment
wayno Posted March 30, 2018 Report Share Posted March 30, 2018 Why are you removing the cab? 2 Quote Link to comment
Antihero983 Posted March 30, 2018 Author Report Share Posted March 30, 2018 Welp, all 4 cab corners are rotted, and all the lines running under it are super rusty. I figure pull the cab, do the floors proper, take care of any major stuff under it, and go from there. I'd post pics, but they're all on Facebook and instagram. I picked up the truck for 400$ and it had been sitting sunk into the ground for 2 or so years. I got it to run, so now its a matter of making it stop and not be rotted. Haha 2 Quote Link to comment
wayno Posted March 30, 2018 Report Share Posted March 30, 2018 OK, I know why I remove them, I was just wondering why you were. 1 Quote Link to comment
wakemaniac Posted April 4, 2018 Report Share Posted April 4, 2018 Jacked the 521 highest I could. Strapped the cab to trusses. Put the frame down and roll it out. Then back up my trailer to cary the cab. P.S. : do not try this at home without a prior engineer calculation of truss capacity. lol. 3 Quote Link to comment
