Draker Posted May 4, 2022 Author Report Share Posted May 4, 2022 4 hours ago, datzenmike said: Have not been 'de smogged' yet either. See the screw with spring just above the left dome? it interconnects the carbs and has a braided hose out to the air filter. We didn't get the dual Hitachi's so not much is known about it's function. It was discussed on The Realm and best guess is that it's an adjustable air bleed to tune the idle mixture. They suggested removal and triangular aluminum covers put on, typical 'smog shit' mentality, but I would think you could just close them or use them. I have a set from an L16/18 SSS. The little red capped tube is the vacuum advance. Does this have water cooled intake runners???? I don't think the A series used this on their intakes. Easy enough to drill the two holes in the head to match up. The outlet from the intake has to connect to the lower rad hose inlet to the water pump. L16/18 SSS SUs didn't like heat and the intakes were water cooled and even were heat shielded so likely these are too. I've got the same set on my 71 510, and I see what you're saying about the block off plates. They've been deleted on my other car. I gotta get some point in the domes and see if I can get the pistons moving freely. One is a bit sticky, and one is seized completely. Otherwise the throttle shafts seem tight. Regarding to cooling, from my very limited research it appears that the oval port GX heads did have coolant passages. But other A series heads did not. I'll have to look into the modification of a non GX head to suite these carbs. I haven't gotten there yet. This was more of a "buy it when it's available" purchase. 1 Quote Link to comment
datsunfreak Posted May 4, 2022 Report Share Posted May 4, 2022 (edited) 1 hour ago, Draker said: it appears that the oval port GX heads did have coolant passages. But other A series heads did not. I'll have to look into the modification of a non GX head to suite these carbs. I haven't gotten there yet. As long as it's an oval-port head, you'll be fine. I've run them on heads with and without water passages and never saw a difference. But... 1. I wasn't "racing". 2. It's a lot colder in Eugene that Texas. YMMV 😁 Edited May 4, 2022 by datsunfreak 1 Quote Link to comment
Draker Posted May 5, 2022 Author Report Share Posted May 5, 2022 9 hours ago, datsunfreak said: As long as it's an oval-port head, you'll be fine. I've run them on heads with and without water passages and never saw a difference. But... 1. I wasn't "racing". 2. It's a lot colder in Eugene that Texas. YMMV 😁 I don’t think the head is an oval port. I’ll pull the valve cover and ID it. Quote Link to comment
datsunfreak Posted May 5, 2022 Report Share Posted May 5, 2022 (edited) 6 hours ago, Draker said: I don’t think the head is an oval port. I’ll pull the valve cover and ID it. You can usually tell a lot by looking at the intake. 👍 Most often, the round port intake has one upper bolt, between the runners, while the oval port has two upper bolts on either side of the runners. The thickness/height of the runner will also tell you a lot. There are a few round port intakes that look like oval port at first glance, usually from a 210. And based on how smogged up your intake looks, maybe... Edited May 5, 2022 by datsunfreak 1 Quote Link to comment
KELMO Posted May 6, 2022 Report Share Posted May 6, 2022 Pics of the two different intakes. Illustrates what DF said. Oval port intake. Round port intake. 2 Quote Link to comment
datzenmike Posted May 6, 2022 Report Share Posted May 6, 2022 KELMO, where does the water exit the oval intake and how does it connect to the lower rad hose to the water pump? Quote Link to comment
Draker Posted May 7, 2022 Author Report Share Posted May 7, 2022 Good news, I appear to have an oval intake based on the pics posted above. Also have a new exhaust manifold that doesn’t bolt to the intake. Quote Link to comment
Draker Posted May 7, 2022 Author Report Share Posted May 7, 2022 a while back I bought a NOS glove box. The only problem, it’s been smashed for decades. Anyone make a sheet metal replacement? I got it installed anyways. I needed a mounting bracket for a amp volume control. Modeled something simple and mounted under the dash. 1 Quote Link to comment
KELMO Posted May 7, 2022 Report Share Posted May 7, 2022 (edited) 22 hours ago, datzenmike said: KELMO, where does the water exit the oval intake and how does it connect to the lower rad hose to the water pump? If you look at the pic of the manifold Draker posted on the previous page, you can see at the bottom side of the manifold there are water "jackets" under the ports. On the head, there should be 2 corresponding holes for coolant circulation. IIRC, the head I used did not have the corresponding holes but was an oval port head. Edited May 7, 2022 by KELMO 1 Quote Link to comment
datzenmike Posted May 7, 2022 Report Share Posted May 7, 2022 Yes. I wanted to know how the coolant exited the intake and returned to the lower radiator inlet to get back into the water pump so it circulates.. 1 Quote Link to comment
datsunfreak Posted May 7, 2022 Report Share Posted May 7, 2022 (edited) 10 hours ago, datzenmike said: Yes. I wanted to know how the coolant exited the intake and returned to the lower radiator inlet to get back into the water pump so it circulates.. I don't think it does? I thought it was just a horseshoe to prevent "carb icing" in colder weather... Edited May 7, 2022 by datsunfreak Quote Link to comment
datsunfreak Posted May 7, 2022 Report Share Posted May 7, 2022 10 hours ago, datzenmike said: Yes. I wanted to know how the coolant exited the intake and returned to the lower radiator inlet to get back into the water pump so it circulates.. Looks like there's maybe a coolant pipe at the front, same as on SU intake... Quote Link to comment
datsunfreak Posted May 7, 2022 Report Share Posted May 7, 2022 Yeah, SU intake crossover tube has two runners inside it, one for air, one for water. Air tube terminates into a PCV valve, water terminates in a pipe to send water away... https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcRv9V1-_idkQ6Qh22ZMBZMYgoBP6VCAW90y8g&usqp=CAU Quote Link to comment
Draker Posted May 10, 2022 Author Report Share Posted May 10, 2022 (edited) Knocked out a custom trunk carpet. Ignore the sub and wiring, I’ll deal with it. Edited May 10, 2022 by Draker 3 Quote Link to comment
Draker Posted May 12, 2022 Author Report Share Posted May 12, 2022 Floor mats came in today. They look pretty good! 4 Quote Link to comment
KELMO Posted May 12, 2022 Report Share Posted May 12, 2022 Those look vehicle specific (and they also look very good). 1 Quote Link to comment
Draker Posted May 12, 2022 Author Report Share Posted May 12, 2022 11 hours ago, KELMO said: Those look vehicle specific (and they also look very good). coco mats. You send them a pattern, they send you the custom made mats. They followed my pattern pretty well, good fit! 1 Quote Link to comment
Dguy210 Posted May 13, 2022 Report Share Posted May 13, 2022 1 hour ago, Draker said: coco mats. You send them a pattern, they send you the custom made mats. They followed my pattern pretty well, good fit! Those look really good. About how much though for the cheap bastards out there (I mean me of course) Quote Link to comment
Draker Posted May 13, 2022 Author Report Share Posted May 13, 2022 2 hours ago, Dguy210 said: Those look really good. About how much though for the cheap bastards out there (I mean me of course) they aren’t cheap, about $240 shipped in this case with discount code.. Lots of different colors, patterns, options. Truly custom mats. 2 Quote Link to comment
iceman510 Posted May 13, 2022 Report Share Posted May 13, 2022 11 hours ago, Dguy210 said: Those look really good. About how much though for the cheap bastards out there (I mean me of course) https://www.cocomats.com/coco/ 8 hours ago, Draker said: they aren’t cheap, about $240 shipped in this case with discount code.. Lots of different colors, patterns, options. Truly custom mats. Did they not have the 1200 pattern, or you wanted it cut differently? I guess it's a bit confusing to me they have you select the vehicle, but then do you have to provide a pattern as well? Maybe not in all cases. Fronts only? Quote Link to comment
datsunfreak Posted May 13, 2022 Report Share Posted May 13, 2022 On 5/11/2022 at 11:26 PM, Draker said: Have you seen this thread? 😁 Quote Link to comment
Draker Posted May 14, 2022 Author Report Share Posted May 14, 2022 16 hours ago, iceman510 said: https://www.cocomats.com/coco/ Did they not have the 1200 pattern, or you wanted it cut differently? I guess it's a bit confusing to me they have you select the vehicle, but then do you have to provide a pattern as well? Maybe not in all cases. Fronts only? no 1200 patterns. Also I think there is a difference between manual and auto cars due to the tunnel sizes. Basically you can order the samples, they send you everything you need for making a pattern. You pay online, mail the pattern. They make the mats and send them back to you. Pretty easy really! Quote Link to comment
Draker Posted May 14, 2022 Author Report Share Posted May 14, 2022 11 hours ago, datsunfreak said: Have you seen this thread? 😁 I actually have seen it. Pretty cool. I do have the Nardi horn button though. I’ve just been doing some work on the horn. Quote Link to comment
datsunfreak Posted May 17, 2022 Report Share Posted May 17, 2022 On 5/13/2022 at 11:54 PM, Draker said: I think there is a difference between manual and auto cars due to the tunnel sizes. There is a noticeable difference. Auto car tunnel is at least 2" wider. 1 Quote Link to comment
Draker Posted May 17, 2022 Author Report Share Posted May 17, 2022 9 hours ago, datsunfreak said: There is a noticeable difference. Auto car tunnel is at least 2" wider. Thanks for the confirmation. When I ordered the previous set of floor mats from stock interiors (which are nice by the way), they were a little wide. I figured the template they used was from a manual car, where as mine is (was) an auto. 1 Quote Link to comment
