Draker Posted March 7, 2022 Author Report Share Posted March 7, 2022 Smoke test complete. No smoke detected. Also nothing works. So off to a good start. Not everything is hooked up, so that’s expected. More work to do! 1 2 Quote Link to comment
Draker Posted March 9, 2022 Author Report Share Posted March 9, 2022 Alright, got most of the electronics working again. I got it running tonight. Next is getting the alternator wired and charging. Just a few other small circuits to get working again. Horn, tach, dome light. Then buy a replacement radio. 3 Quote Link to comment
Zrookie Posted March 10, 2022 Report Share Posted March 10, 2022 What a beauty!!!! 1 Quote Link to comment
Draker Posted March 11, 2022 Author Report Share Posted March 11, 2022 Dash is in, most things working. Replaced dash lights with LEDs. 2 Quote Link to comment
Draker Posted March 11, 2022 Author Report Share Posted March 11, 2022 I’m waiting on a fan belt. Old one was too short for the new alternator location. Measured and bought replacement.. still too short. Ordered another one.. will be here tomorrow. Quote Link to comment
Draker Posted March 13, 2022 Author Report Share Posted March 13, 2022 (edited) Got the new belt, too long. First belt was a 3VX375 (too short), second was a 3VX400 (too long). I found a belt locally, 3L390. It's a good fit.. however after further review it's for a lawn mower. 3-17 horsepower. So.. not that this A series is much over 17hp.. I'm guessing I should run this belt? It doesn't seem nearly as durable. Anyone got a part number for a 3/8" x 39" belt? I'm on the hunt. Nevermind, I found one on Amazon. 3VX390, good year belt. As they say, 4th times a charm. Edited March 13, 2022 by Draker 2 Quote Link to comment
jagman Posted March 13, 2022 Report Share Posted March 13, 2022 For anyone looking for belts I recommend Vbelts4Less.com. I use them for all our belt needs Mowers and cars and trucks. 1 Quote Link to comment
datsunfreak Posted March 15, 2022 Report Share Posted March 15, 2022 On 3/12/2022 at 8:09 PM, Draker said: however after further review it's for a lawn mower. 3-17 horsepower. I'm guessing I should run this belt? It doesn't seem nearly as durable. Did that once, never had an issue with it. But glad you found a legit belt. 😁 1 Quote Link to comment
Duncan Posted March 15, 2022 Report Share Posted March 15, 2022 Interesting. My new-ish sewing machine uses a 3L-390. It actually REALLY hauls ass, but not much HP... 1 Quote Link to comment
Draker Posted March 16, 2022 Author Report Share Posted March 16, 2022 (edited) Got the new belt, it fits. It’s actually on the longer side. 38” would be better but meh. The other thing is the alternator pulley is for a 1/2” wide belt. This new belt bottoms out and given it’s notched on the bottom, it made some noise. I tried swapping pulleys but they are different to the point they won’t swap. So I just sanded down the back of the belt to lower the profile. Seems like it worked but may need more adjustments. Second, I’ve got the voltage regulator bypassed at the plug. The alternator is putting out 14.9 volts. Seems about .6 volts too much. It makes no difference if the t-plug is connected or not. For reference this is a “one wire” denso mini alternator that @datsunfreak recommended. Edited March 16, 2022 by Draker add pics Quote Link to comment
Draker Posted March 16, 2022 Author Report Share Posted March 16, 2022 (edited) while fiddling with the alternator I found the factory smoke. I forgot to disconnect the battery the day before and the power wire found ground. Then the fusible link blew. I’m glad I took the time to install a fusible link with the new harness. It saved my bacon here. Bacon = wires. I didn’t have a replacement fusible link, but I have one on order. I built this new link with a 40amp maxi fuse, good enough for now and easier to replace. i added more heat shrink to ensure the fuse can’t come loose. (Not pictured) Edited March 16, 2022 by Draker 1 Quote Link to comment
Draker Posted March 16, 2022 Author Report Share Posted March 16, 2022 (edited) I don’t have any fuse box covers, so I designed and printed this one. Edited March 16, 2022 by Draker 7 Quote Link to comment
iceman510 Posted March 16, 2022 Report Share Posted March 16, 2022 On 3/6/2022 at 3:23 AM, Draker said: Ended up with the Koni’s. They fit just fine but you need to install a bushing in the rubber isolator. I just used the ones from the old KYB’s Rear wheel has a nice flat spot. 1 Quote Link to comment
Draker Posted March 16, 2022 Author Report Share Posted March 16, 2022 1 hour ago, iceman510 said: Rear wheel has a nice flat spot. you should see the other wheels! They are all beat. But they balance out great! Quote Link to comment
KELMO Posted March 16, 2022 Report Share Posted March 16, 2022 This thread has me working on the green coupe. Dude, you made me feel guilty about neglecting it. BTW, where did you get your LED dash bulbs? Looks good in the pic. 1 Quote Link to comment
Draker Posted March 16, 2022 Author Report Share Posted March 16, 2022 (edited) 1 hour ago, KELMO said: This thread has me working on the green coupe. Dude, you made me feel guilty about neglecting it. BTW, where did you get your LED dash bulbs? Looks good in the pic. I got them on Amazon. I'll dig up the links. Partsam T10 194 168 Dash Instrument White LED Light Bulbs https://www.amazon.com/gp/product/B00KT1BH1Q/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Yoper BA9S 53 57 1895 64111 LED Light Bulb https://www.amazon.com/gp/product/B07R9VW9HY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Edited March 16, 2022 by Draker 1 Quote Link to comment
datsunfreak Posted March 17, 2022 Report Share Posted March 17, 2022 On 3/15/2022 at 11:24 PM, Draker said: Second, I’ve got the voltage regulator bypassed at the plug. The alternator is putting out 14.9 volts. Seems about .6 volts too much. It makes no difference if the t-plug is connected or not. For reference this is a “one wire” denso mini alternator that @datsunfreak recommended. Do you have a wire straight from the alternator to the battery (or starter)? Also, known to be good battery? Those alternators overcharging usually means they aren't able to sense the battery load well enough (hence the direct wire), or a bad cell in the battery. Quote Link to comment
datsunfreak Posted March 17, 2022 Report Share Posted March 17, 2022 On 3/15/2022 at 11:24 PM, Draker said: The alternator is putting out 14.9 volts. Seems about .6 volts too much. It makes no difference if the t-plug is connected or not. And yes, all of mine charged at 14.2-14.3. Side question: what was the rated amperage on the one you got? I notice every few years they seem to up it. My first was 45, second two were rated at 55, Tim's said 65, and some of them on ebay now say 75 or 85. Quote Link to comment
Draker Posted March 18, 2022 Author Report Share Posted March 18, 2022 10 hours ago, datsunfreak said: Do you have a wire straight from the alternator to the battery (or starter)? Also, known to be good battery? Those alternators overcharging usually means they aren't able to sense the battery load well enough (hence the direct wire), or a bad cell in the battery. Good point and that got me thinking... Before it was connected through a OEM green fusible link. Alternator -> Fusible Link -> Starter -> Battery. Then I fried the fusible link and replaced it with a maxi fuse. I checked it again with this configuration, still nearly 15v. I just wired a thick gauge wire directly from the alternator to the starter, checked again. No change. I then swapped the battery out for another, and still the same. Great suggestion, but no dice. Quote Link to comment
Draker Posted March 18, 2022 Author Report Share Posted March 18, 2022 10 hours ago, datsunfreak said: And yes, all of mine charged at 14.2-14.3. Side question: what was the rated amperage on the one you got? I notice every few years they seem to up it. My first was 45, second two were rated at 55, Tim's said 65, and some of them on ebay now say 75 or 85. Based on our conversation, I'm guessing I got the 55amp version. I bought it so long ago, I can't find the ebay history anymore. I'll see if I can find old invoices.. hard to say. I may have to pull it off and go have it tested. Maybe it's just bad? 1 Quote Link to comment
datsunfreak Posted March 18, 2022 Report Share Posted March 18, 2022 11 hours ago, Draker said: Maybe it's just bad? It is possible the regulator has a defect and can't sense the battery load? 11 hours ago, Draker said: I just wired a thick gauge wire directly from the alternator to the starter, checked again. No change. I then swapped the battery out for another, and still the same. Especially knowing this. FYI, if you have the ability to disassemble and repair an alternator, these regulators are available by themselves. And you could up the amperage at the same time? 1 Quote Link to comment
Draker Posted March 19, 2022 Author Report Share Posted March 19, 2022 On 3/18/2022 at 6:57 AM, datsunfreak said: It is possible the regulator has a defect and can't sense the battery load? Especially knowing this. FYI, if you have the ability to disassemble and repair an alternator, these regulators are available by themselves. And you could up the amperage at the same time? Got it tested, they said it passed.. but it was putting out 15.3v. Looks like I’m replacing the regulator. Quote Link to comment
Draker Posted March 20, 2022 Author Report Share Posted March 20, 2022 8 hours ago, Draker said: Got it tested, they said it passed.. but it was putting out 15.3v. Looks like I’m replacing the regulator. replacement regulators appear to be 14.9v at least the ones I found on eBay. Wtf. Perhaps this is what I have? Quote Link to comment
datsunfreak Posted March 21, 2022 Report Share Posted March 21, 2022 On 3/20/2022 at 2:14 AM, Draker said: replacement regulators appear to be 14.9v at least the ones I found on eBay. Wtf. Perhaps this is what I have? Possibly... That is a bit high though... At least your headlights will be bright. 😁 Quote Link to comment
Draker Posted March 21, 2022 Author Report Share Posted March 21, 2022 24 minutes ago, datsunfreak said: Possibly... That is a bit high though... At least your headlights will be bright. 😁 I’ve got LEDs already lol. I messaged a seller on eBay that might have a 14.6v regulator. 1 Quote Link to comment
