Velict Posted March 24, 2018 Report Posted March 24, 2018 Ladies and Gentlemen, I give you the most beautiful replacement for the Sunny 1200 that is a direct swap for, at the moment that I know of, ANY A series engine. The Wilson 70-25-12272. It is a diesel boat generator platform, heavy duty meant for continuous and stressfull use. The blue wire is for a tachometer, fully internal regulated and has an LR connector. It has been pre-treated with salt resistance, including all interior mechanical and electrical components. The mounting and fitment is 100% perfect on my A12 engine, top mounted. Pulley lines up without any need to change the length of the belt (960-990mm), and there is above-nominal clearance for the fan. There is a 90 amp alternator version, the LR190. I had O-o-o...oreilysssssssssssssss autoFARTS order it to compare the sizing. There are quite a few variations of the 90 amp, therefore a bit more difficult to get the right one. I don't recommend that. I've purchased the 12v 80 amp version. Other part numbers it goes by are as follows: Lr180-03 Lr180-03C 112375 4-6278 LR180-03A LR180-03B 119573-77200 If you're looking for a replacement alternator for LR135 series that is a direct swap, check this 80 Amp out. 4 Quote
datzenmike Posted March 24, 2018 Report Posted March 24, 2018 Have you tried it on an L series engine? Bet it fits. 3 Quote
bananahamuck Posted March 24, 2018 Report Posted March 24, 2018 He mentions it in the middle Quote: fully internal regulated and has an LR connector. . 2 Quote
bananahamuck Posted March 24, 2018 Report Posted March 24, 2018 I like the part about pre salt/corrosion protected,, i think that would be nice for cars that are stored uncovered mostly outside. . 1 Quote
KELMO Posted March 24, 2018 Report Posted March 24, 2018 Top mounted alt on an A12? Wait, what? Maybe mine are too old....... 1 Quote
Velict Posted March 24, 2018 Author Report Posted March 24, 2018 Post 79 started top mounted to make room for AC compressor 2 Quote
Velict Posted March 25, 2018 Author Report Posted March 25, 2018 Top mounted alt on an A12? Wait, what? Maybe mine are too old....... You'll need to move your lower radiator hose out of the way, or find the part number for the bracket that moves your alternator to the top of the engine. That bracket you could get for 20 bucks. 1 Quote
KELMO Posted March 25, 2018 Report Posted March 25, 2018 In order to move the alternator to a top mount, I would have to move the dizzy. :thumbup: 1 Quote
az_rat210 Posted April 2, 2018 Report Posted April 2, 2018 Looks like you have to have the pulleys swapped, as the Boat Alt Pulley sticks out further. But otherwise, good job. 80 amp better than stock 50 amps. 1 Quote
banzai510(hainz) Posted April 2, 2018 Report Posted April 2, 2018 be nice to see the back of th alternaotr also. does this fit the standard T connector? PRICE? What model car it comes from? I only say this cause I dont what to confuse the next kid at O rileys and get into it with him/her!!!! 1 Quote
Dguy210 Posted April 3, 2018 Report Posted April 3, 2018 be nice to see the back of th alternaotr also. does this fit the standard T connector? PRICE? What model car it comes from? I only say this cause I dont what to confuse the next kid at O rileys and get into it with him/her!!!! Looks like the range from 70-80$ on Amazon. https://www.amazon.com/YANMAR-DIESEL-HI-OUTPUT-ALTERNATOR-LR180-03C/dp/B008Y3R6DY This is what comes up searching on Vatozone: $102 https://www.autozone.com/batteries-starting-and-charging/alternator/duralast-gold-alternator/459931_0_0 Quote
datsunfreak Posted April 3, 2018 Report Posted April 3, 2018 FWIW, this is a direct swap for any L or A series engine. It is half the size and weight of any Nissan alternator. And it puts out 70 amps. It is internally regulated, and has a self-exciting regulator, which means it only needs one wire ran to the battery to function. https://www.ebay.com/itm/MINI-ALTERNATOR-Fits-DENSO-STREET-ROD-RACE-1-WIRE-Small-One-Wire-NEW-70-Amp/282513310986?hash=item41c71b050a:g:THEAAOSwm8VUyrwZ&vxp=mtr 2 Quote
Velict Posted May 26, 2018 Author Report Posted May 26, 2018 Looks like you have to have the pulleys swapped, as the Boat Alt Pulley sticks out further. But otherwise, good job. 80 amp better than stock 50 amps. That is 100% factually incorrect. Everything lines up perfectly. Verified by me who installed it. Also, stock is not 50 amps, but 35 amps. Quote
Velict Posted May 26, 2018 Author Report Posted May 26, 2018 be nice to see the back of th alternaotr also. does this fit the standard T connector? PRICE? What model car it comes from? I only say this cause I dont what to confuse the next kid at O rileys and get into it with him/her!!!! It comes from a boat engine. Easily google-able. LR180. Quote
Velict Posted April 22, 2020 Author Report Posted April 22, 2020 Final update; this swap works perfectly, output is clean and expected for a marine/industrial alternator. Zero modifications needed, completely bolt in. You can add an alternator tacho if you're feeling sassy. Quote
banzai510(hainz) Posted April 23, 2020 Report Posted April 23, 2020 may 25 2018? that's the longest alternator swap in HISTORY 2 Quote
Draker Posted May 22, 2020 Report Posted May 22, 2020 On 4/2/2018 at 6:17 PM, datsunfreak said: FWIW, this is a direct swap for any L or A series engine. It is half the size and weight of any Nissan alternator. And it puts out 70 amps. It is internally regulated, and has a self-exciting regulator, which means it only needs one wire ran to the battery to function. https://www.ebay.com/itm/MINI-ALTERNATOR-Fits-DENSO-STREET-ROD-RACE-1-WIRE-Small-One-Wire-NEW-70-Amp/282513310986?hash=item41c71b050a:g:THEAAOSwm8VUyrwZ&vxp=mtr have this but still need to install it. Lol 1 Quote
Velict Posted September 21, 2024 Author Report Posted September 21, 2024 The upgrade is still working to this day. 2 Quote
mike.lovell127 Posted September 29, 2024 Report Posted September 29, 2024 On 4/2/2018 at 6:17 PM, datsunfreak said: FWIW, this is a direct swap for any L or A series engine. It is half the size and weight of any Nissan alternator. And it puts out 70 amps. It is internally regulated, and has a self-exciting regulator, which means it only needs one wire ran to the battery to function. https://www.ebay.com/itm/MINI-ALTERNATOR-Fits-DENSO-STREET-ROD-RACE-1-WIRE-Small-One-Wire-NEW-70-Amp/282513310986?hash=item41c71b050a:g:THEAAOSwm8VUyrwZ&vxp=mtr I purchased this for my 78' 620 L20B. Was absolutely not a direct swap. Only one mount point lines up, and the belt was way off. What made you believe this was a direct swap? It was my own fault for not looking into it further before ordering, but I was impatient and now have a $125 alternator that I am in the process of shipping back and lost about a week in shipping time. Do not buy this one and expect a direct swap for a L20. I just ordered the Lr180-03C, and will post an update when I receive it and see how it works out. Quote
datsunfreak Posted September 30, 2024 Report Posted September 30, 2024 On 9/28/2024 at 9:20 PM, mike.lovell127 said: I purchased this for my 78' 620 L20B. Was absolutely not a direct swap. Only one mount point lines up, and the belt was way off. What made you believe this was a direct swap? The 14 times I bolted one onto an A, L, and Z engine and it worked just fine? 😁 Quote
datsunfreak Posted October 1, 2024 Report Posted October 1, 2024 Here is the most recent one, not the best pic, but... 1 Quote
