TResistance Posted March 19, 2018 Report Share Posted March 19, 2018 Hello everyone. I have a problem with the instrument panel light. So, I took a Circuit Tester and checked continuity. I saw that a fuse did not indicate continuity. And, the light lit only in one pole and not in the other. I cleaned the terminals with a sheet of sand and it did not work. I removed the fuse but left the switch open and saw that the front lamps were on & the instrument panel. Before they did not light. It took me by surprise, it's not supposed to be fuses for that. Unless there is another problem. What do you say? Thanks friends. Greetings. Quote Link to comment
datzenmike Posted March 19, 2018 Report Share Posted March 19, 2018 You probably have the wrong fuse. Loosen one end of each fuse till the lights go out... that's the fuse. Quote Link to comment
TResistance Posted March 19, 2018 Author Report Share Posted March 19, 2018 You probably have the wrong fuse. Loosen one end of each fuse till the lights go out... that's the fuse. But, I put that fuse and the lights go out. I take it off and turn it on. 1. Cluster is on: https://www.dropbox.com/s/wqh73e5w50xckqh/2018-03-18%2022.03.36.jpg?dl=0 2. Flasher | Luz (light), principal option: https://www.dropbox.com/s/myfbdnj6w4q9y5c/2018-03-18%2022.04.58.jpg?dl=0 3. Without fuse: https://www.dropbox.com/s/2tijmsguf1ip1z9/IMG_20180318_220431.jpg?dl=0 Thanks, I will try with the others. 1 Quote Link to comment
TResistance Posted March 19, 2018 Author Report Share Posted March 19, 2018 upgrade It seems that the problem is caused by a poor quality fuse. But the terminal is also overheating. The fuse that causes it, is: 20A CLEAR TAIL | ESTAC. TRASE https://www.dropbox.com/s/myfbdnj6w4q9y5c/2018-03-18%2022.04.58.jpg?dl=0 Quote Link to comment
datzenmike Posted March 19, 2018 Report Share Posted March 19, 2018 The 20A (upper right) should power the instrument, parking/tail, side marker, license lights. The 10A (upper left) is for the turn signals. Quote Link to comment
racerx Posted March 19, 2018 Report Share Posted March 19, 2018 Terminal heating? Corroded connection? Check underneath fuse box. 1 Quote Link to comment
TResistance Posted March 19, 2018 Author Report Share Posted March 19, 2018 The 20A (upper right) should power the instrument, parking/tail, side marker, license lights. The 10A (upper left) is for the turn signals. Yup. The Problem is the 20A. Replacement solves the problem? Quote Link to comment
TResistance Posted March 19, 2018 Author Report Share Posted March 19, 2018 Terminal heating? Corroded connection? Check underneath fuse box. Hello, RacerX. Yes, yesterday I did tests and I realized that the terminal felt hot. And, it begins to melt the plastic of the fuse box. I checked and it has a bit of corrosion. I add a photo. https://www.dropbox.com/s/0t4da2e96w0vkt4/2018-03-19%2010.25.08.jpg?dl=0 Thanks for the reply. Quote Link to comment
