BrianE Posted March 13, 2018 Report Share Posted March 13, 2018 Greetings. Can anyone help identify or point me to a resource that can help identify the cabin side Horn wiring..... The PO of my 510 pulled and replaced the stock steering wheel, horn ring, hub and replaced with an aftermarket Momo Corse wheel, horn button and 3503 hub but alas, no obvious stock horn wiring (at least anywhere near the column). I do have the colored wiring diagram for the "manual transmission" and it looks proper on the engine bay side but before going much further with it, I wanted to check with the Ratsun community for your thoughts / recommendations. For what it's worth, fuse box is freshly bathed in vinegar, all fuses good, all other accessories (signals, flashers, dome light, heater switch, ignition switch, idiot lights all function properly. Thanks! 1 Quote Link to comment
Doctor510 Posted March 13, 2018 Report Share Posted March 13, 2018 Go to the NICO website and pull down the FSM for the wagon 1 Quote Link to comment
datzenmike Posted March 13, 2018 Report Share Posted March 13, 2018 Black/Green stripe wire. When grounded by the horn ring or button it activates the horn relay and horn sounds. Horn and relay should be the same for sedan or goon and auto or manual. 2 Quote Link to comment
BrianE Posted March 14, 2018 Author Report Share Posted March 14, 2018 Doctor 510 - Thank you. Just now completed the "registration" submittal for the NICO site. Once thru the wickets, I'll pursue the FSM DatzenMike - Thank you. Found a Black / Green stripe wire behind the center console, under the heater control assy. Looks to be decoupled at a male/female connector(s). Once I have the FSM, I'll go about knitting it back together and report back. Untitled by Brian H2012_iPhoto, on Flickr Untitled by Brian H2012_iPhoto, on Flickr 1 Quote Link to comment
datzenmike Posted March 14, 2018 Report Share Posted March 14, 2018 Lots of Black/Green stripe wires in a 510. Ground it... horn should sound 1 Quote Link to comment
