How to wire up a tach to a VG30e
  • Replies 9
  • 3 weeks later...
So I hooked up the Autometer tach to the ECU signal wire (blue/orange) and the tach is working, kinda. Inside the tach behind the light, there is a square box with two switches. I adjusted them appropriately for the 6 cylinder engine, 1= up, 2= down arrangement. I do have a moving needle but it is not accurate. It stays low and jumps a bit.
Here is the question: With the needle jumping and low position, is it likely a tach adapter is needed?
  • 10 months later...
