Aibast Posted November 10, 2018 Author Report Share Posted November 10, 2018 (edited) I just finaly got the turbo engine ECU and wireing removed from the donor car. I removed the engine bay harness ( 1/6 ) before as it had a nice big connector in the engine bay. It was all routed trough this hole and ran under coil and beind the strut tower. This is now a ( 2/6th) part of my colored spagetty monster. I know what goes where so no problem with this. All the + side going trough this harnes, and passanger side front lights. Driver side lights are in the same harness as ABS and Ignition ECU's -going to remove these soon. Next removing the hood and front fenders and but them in storage. And a fotographer that was in the summer Youngtimer Camp found some photos of the van on the sprint run. I did try my best to get the car to lift a wheel and slide a bit, but not enough speed to get it going. Still had a small slide on the gravel corner, but didn't let it go to far. There was a concrete block on the outside edge in the end of the corner. Edited November 10, 2018 by Aibast Quote Link to comment
datsunfreak Posted November 15, 2018 Report Share Posted November 15, 2018 I really dig the van, but I'd be lying if I didn't say I was very curious about what's next to it... ? Quote Quote Link to comment
Aibast Posted November 16, 2018 Author Report Share Posted November 16, 2018 16 hours ago, datsunfreak said: I really dig the van, but I'd be lying if I didn't say I was very curious about what's next to it... ? Next to it is a friends 1962 Volvo Amazon 2 door. B18 engine and 4 speed manual box. Needs work but in a good condition for the age. Quote Link to comment
Aibast Posted November 24, 2018 Author Report Share Posted November 24, 2018 (edited) Front brakes where a bit hard. Had to realy press on the pedal to make her stop. Removed the calibers and pistons move realy well. The pins that the caliber glides on were a bit rust bitted and didn''t slide so well. Ordered a repair kit and added new pins and rubber boots with new grease. Noticed some weird things behind the bumper and gaps were off. So removed the bumper to get some things off. PS. Volvos 80's safety trick. 2cm thick aluminium girder thats in the bumper attach to these things. When that was done went on to remove the wireing harness from the donor. After some research removed the things that I needl. Most of the wires are not neaded. From 52 wires I only need 15 as minimum and 18 if I use some extra features like ECU controlled cooling fan, fuel pumps, constant idle adjusting to engine load. The Van has a carb engine originaly and use stand alone ignition computer with vacume adjusted load metering, knock adjusted timing, overheating protection and was even used on 16V turbo engines. So no need to use donor ignition. This is what is left on the inside. Still need some relays and fueses from this mess. Edited November 24, 2018 by Aibast Quote Link to comment
Aibast Posted November 29, 2018 Author Report Share Posted November 29, 2018 Went to annual technical inspection and everything works. Brakes are good, lights are ok, shocks are good, bushings and steering ok. Emmissions is metered but the result is not counted as the car is over 30 years old. But I'll be converting to injecton and add a catalityc converter to her anyway. Removed fuelpump and filter from the donor car. Waiting on the new gasgets for the injection intake manifold. Quote Link to comment
Aibast Posted December 1, 2018 Author Report Share Posted December 1, 2018 started getting things ready. First the intake manifold port matching and some smooting over the injectors connecting areas. Here is a pic of half done intake with gasget on it to check things over. Useing the same gasget on the heads intake channels to match things up. Quote Link to comment
Aibast Posted December 20, 2018 Author Report Share Posted December 20, 2018 (edited) going to use my "van" to get some Yule trees this year. Snow and RWD = perfect ? Happy solstice to you all. This years trip is done. Took my daughter with me this time. Used logging road to get to my property . Found a place to leave the transport. It is an hours walk to get where I have my young trees growing to take over old fields. Searching for trees. Found what we where looking for. Back to the Van. Edited December 20, 2018 by Aibast 2 Quote Link to comment
Aibast Posted December 26, 2018 Author Report Share Posted December 26, 2018 still can''t work on the van. First friends XC90 had issues with injectors and turbo management. Took the D5 apart. New turbo electronic actuator and cleaned everything up again. Got it running again with no more problems and fault codes. Next stripped the MX5 clean of the bad "mods" Off with front and rear spoilers, side skirts and fender flares. Quote Link to comment
Aibast Posted January 5, 2019 Author Report Share Posted January 5, 2019 Miata is a wrap Quote Link to comment
Aibast Posted January 8, 2019 Author Report Share Posted January 8, 2019 Used "van" today.... and.... the autobox is toast. Doesn't shift well and has no pull. So auto -> manual swap is in order now. Quote Link to comment
Aibast Posted January 10, 2019 Author Report Share Posted January 10, 2019 Damn that Miata is fun on snow ? Sideways all the time. Started on the auto box to manual by getting parts from the donor. It was but outside for storage. Well , got the thing lifted up first to loosen bolts under the car and open overdrive electric connections. Manual pedalbox, alternator from the engine to get more space, brake booster and cluch master cylinder. And then found out that driveshaft and gearbox connecting flanges have rusted together. Removed the bolts and stuck as can be. Hammering on it didn't do anything. So left it soaking with penetrating oil. Next morning but the car on stands. Took a concrete braking chisel, ground it to more defined edge/point. And with that and a hammer tapped the flanges apart. 1 Quote Link to comment
Aibast Posted January 11, 2019 Author Report Share Posted January 11, 2019 It is out ? Quote Link to comment
Aibast Posted January 13, 2019 Author Report Share Posted January 13, 2019 (edited) Old AW70 automatic is 710mm long, M46+Overdrive is 770mm long. The front part of the driveshaft is extended from stock as the cars body is extended. Now need to shorten this custom part. My friend removing automatic shifter/gear selector and pedal box. New pedals in, clutch master cilinder and slave cilinder are on the car. Edited January 13, 2019 by Aibast Quote Link to comment
Aibast Posted January 15, 2019 Author Report Share Posted January 15, 2019 Clutch is in Next came the gearbox. Clutch travel is adjusted and it is ready to go. All I need now is a driveshaft and some other parts. Quote Link to comment
Aibast Posted January 21, 2019 Author Report Share Posted January 21, 2019 (edited) Driveshaft is on the car and it drives and shifts. Overdrive works great, got 4th gear switch working to, so OD now only in 4th gear. Video of a test run https://youtu.be/h30hdt0CEh0 Edited January 21, 2019 by Aibast Quote Link to comment
Aibast Posted January 22, 2019 Author Report Share Posted January 22, 2019 https://youtu.be/5aiu9UA6tFE It was a bit cold here ( -21C / 70F ), but she started up. Quote Link to comment
Aibast Posted February 2, 2019 Author Report Share Posted February 2, 2019 played around with MX5 rear lights. But light rings in the center, now only brake lights on the sides of the cluster. Quote Link to comment
Aibast Posted February 5, 2019 Author Report Share Posted February 5, 2019 Removed the exhaust manifold from the Volvo. Only one stud broke. And found that the exhaust was leaking from the manifold seal, the pulsair system and carb EGR tube. This ment there was a huge airleak in the intake manifold via EGR. No pics this time, stilll need to get the broken stud out from the head - some nuts and MIG velder will fix that issue. Quote Link to comment
Aibast Posted February 6, 2019 Author Report Share Posted February 6, 2019 (edited) But everything back together and now I have next strange thing happening. Cars exhaust whistles. https://youtu.be/9t5-dJRzRVk Edited February 6, 2019 by Aibast Quote Link to comment
Aibast Posted February 7, 2019 Author Report Share Posted February 7, 2019 (edited) Guys, I fixed the exhaust whistle. I still wonder how the hell this thing even run. When I removed the rear muffler box this is what I found. Some animal had made a mud/hair/exhaust insulation/bugs nest in the exhaust tube right in front of the muffler. Edited February 7, 2019 by Aibast 1 Quote Link to comment
Aibast Posted February 11, 2019 Author Report Share Posted February 11, 2019 removed the back muffler on the exhaust and welded up straight pipe to replace it. The rear box was heavy and full of the same thing (read: shit) that was in the exhaust tube. It was way to restricting. As the car still has a resonator and muffler in front of the rear axel it still sounds ok. Quote Link to comment
Aibast Posted February 14, 2019 Author Report Share Posted February 14, 2019 been driving her for some days now. The fuel consumption is 11,7L/100km = 24 MPG. But it is still fun. Got this years Oldtimers Winter Rally number on. Two weeks to some winter fast driving. As every time, I navigate and my friend drivers. Quote Link to comment
Aibast Posted February 24, 2019 Author Report Share Posted February 24, 2019 (edited) Photo by: www.rallyfotod.eu - Pille Russi SS2 video Edited February 24, 2019 by Aibast Quote Link to comment
