Sign in to follow this
Dirtyowlnumber4
Weber tuning issue A14
I have been following the Weber tuning guide up above this, I just finished sealing all the vacuum leaks I had today as well as all the prerequisites to actually tuning the carb.
The problem I'm having is if I turn the air mixture screws out at all, the car stops running. I seen able to get it running all right by screwing around with the idle mixture screw, but it seems like it has more to give. Running a bit rich for sure
Edit: sealing all the leaks also had made it backfire out of the carb occasionally
Share this post
Link to post
Turn the idle speed up a bit and turn the A/F mixture screw IN slowly, check your timing  10-12* BTDC at idle.
Share this post
Link to post
32/36? I don't know what you have without going back through all your posts.
Try setting the engine up first. Sealing any vacuum leaks is a start but correct timing, valve lash, good ignition/strong spark are also needed.
https://www.racetep.com/manufacturer/carbs-and-injection/weber/weber-carb-tuning-and-technical-info/jetting-and-tuning-downdraft-and-sidedraft-weber-carbs.html
Share this post
Link to post
I tried holding the throttle at ~2000rpm maybe and as soon as I turn the screw out at all it will still kill it. Haven't checked the spark, but all ignition components are brand new. I haven't checked the valve lash I'll have a look at that
I believe the timing is at 12 or so I'll double check that too I heard it was good to run at 14° with these carbs
Engine is a stock a14 sorry
Share this post
Link to post
You need to go through all of the above. If valves are not set or timing wrong it can alter the manifold vacuum and make tuning the carb a waste of time. You'll never get it right is there is already an underlying problem.
Share this post
Link to post
It occurred to me that  don't know what I'm doing.
g8VK6i6.jpg?1
So from what I understand, this^^ screw just lets in more or less fuel at idle. I can use this one to seemingly make it richer or leaner, but it also seems to work alright within an entire turn, and no matter where I put it the throttle hesitates or backfires from the carb.
ULpAWiK.jpg?1
This is the real mixture screw right? and theres one on the other side for the other part of the carb. If i try and goof with this one at all the engine ceases to function, even if I'm holding it at 300rpm.
Valves seemed good, no real play between the rockers and the rods. spark seems fairly strong. Timing is at 13 degrees. Couldn't find any new vacuum leaks.
Share this post
Link to post
g8VK6i6.jpg?1
ULpAWiK.jpg?1
NO! That is the idle jet holder, DO OT remover it unless you are cleaning the carb guts.  First picture shows the air/fuel mixture at idle.  IN is leaner and
OUT is richer.  Idle  speed screw is attached to the linkage on the throttle shaft.  What is the clearance between the heel of the cam lobe and the top of the rocker?
Share this post
Link to post
Alright I figured it was something like that. So the only screw to adjust the mixture is that first one right?
If i catch your drift it is not much, like a mm or so on all of them I don't have a feeler gauge. If it is important to know I could acquire one and take a gander.
Share this post
Link to post
get a dagram of the said weber and then you will see the Fuel Mixture and Idle screws. Good to know where they are at before you start turning the wrong screw.
Share this post
Link to post
This is the issue I'm having with it hesitating, seems like it happens no matter where i put the mixture screw. Seem like a problem with the carb or maybe something else?
Share this post
Link to post
Carb adjusting is last. All the above needs to be checked and put right first. If you should have a bad valve setting or timing retarded or too advanced, you'll be fucking with the carb forever and still not get it to run right.
Share this post
Link to post
I'm betting the float height and drop are way out of adjustment.  Very common.  Until you do some homework on the Weber, I wouldn't advise that you do the float adjustment yourself.
Share this post
Link to post
I don't think this is mentioned enough:IDLE mixture screw. It only adjusts the fuel air mixture at idle only. It won't fix any mixture problems above idle.
Share this post
Link to post
g8VK6i6.jpg?1
ULpAWiK.jpg?1
The top picture is the one one that adjusts the A/F mixture.
Share this post
Link to post
Sounds like a mix of ignition timing out of adjustment and too lean. Popping out of the carb is lean, but can also be caused by distributor weights flailing around or even a fouled cap, bad plug wires, etc. You said it has new tune up parts, right? Have you checked the distributor internals?
Share this post
Link to post
Is this a real Wber or is ti an EMPI Chinese knock off?
Share this post
Link to post
See that's what I thought, and it idles fine. Honestly it doesn't seem to mind where the screw is too much, weather it's idling or running. Yesterday i had it like 8 turns out, today I have it all the way in and I can't  tell the difference really. But the only 4 screws I can see are the idle mixture the idle adjustment and the two for the jets.
Yah its got all new igniton parts, including the distributor so I haven't done anything to that yet besides adjust the points.
It better be a real one hoho,i bought it off pierce manifolds for 450 dollars.
XSUjRYG.jpg?1
EDIT: the timing is at 14 degrees but it does jump around a bit. The timing set is new so I'm not sure how to circumvent that
Share this post
Link to post
 So you are running a 32/36 DGV?  You are probably running rich at about 6,000' in Sliver City, the air is thinner, although that may not be the major issue.  These carbs come initially equipped with jets for low elevations.
Did you have to attach a throttle linkage to the carb or did it come that way?  The primary throttle shaft should be able to, initially, move independent of the secondary throttle shaft.
By loosening up the seat of the primary idle jet (on the choke side) you probably are allowing an ungoverned amount of fuel into the mix.  The idle mix screw only controls the idle jet on the primary side if your idle speed screw is no more than 1.5 turns in from just touching the throttle stop, any more and you start getting fuel from the main jet, which has no similar adjustment screw.
Easy on finding the bottom on the idle mix screw (it can be easily damaged) then back it out 1.25 turns from all the way in.  In is lean; you want the leanest you can idle well on, but you don't want it more than 2 turns out.
I am guessing that your idle speed screw is more than 1.5 turns open, for whatever reason.  Yes the idle mix screw is for idle only, but idle is technically no more than 1.5 turns on the speed screw.  I can't get a good idle until more than 2 turns in with the idle speed screw in Santa Fe on my Z24 with the kit that includes a DGV, because the idle speed screw opens the throttle for the needed additional air.  IIRC, my Air/Fuel ratio gauge tells me that it is too rich, and the idle is too slow, when the speed screw and mix screw are where they are supposed to be.
Spark plug reading will probably get your car tuned close enough, but, I've seen a O2 sensor go into a drill-and-clamp-on-bung for an EFI conversion, if you don't want to weld.
I ultimately need smaller idle, and main jets, and bigger air jets.  The DGV came with a style of idle jet dissimilar from the 'altitude' jet kit that I bought, but it may not matter because I have a DGEV that they appear to work with, or I could probably find them sold outside of a kit.  But now in January, wrenches are still too cold to comfortably handle.
Share this post
Link to post
If you purchased it from Pierce Manifolds it is a genuine Weber.  I have been doing business with them for several decades.
Share this post
Link to post
New does not always mean correct. In the case of the distributor, new could mean you've just introduced another variable to the problem. I would remove the cap and check the mechanical advance. Twist the rotor and see if it returns. Does it have free play (movement without spring tension)? If there's any free play, it could cause the timing problem you described.
Share this post
Link to post
You still need to address the float settings.  They get bent up in shipping, despite what Pierce says.  Float settings affect fuel mixture at ALL rpms  Idle mixture also affects fuel mixture at all rpms, just not in a great amount.  We use the idle jet to bolster or shave down the peak rpm fuel mixture in our race truck, because it ALWAYS flows fuel at any rpm.  It has to be properly set before you change jets.  But first, float height and drop are key.
Share this post
Link to post
I think I am going to get an electronic distributor in it before I tune it anymore so I know the spark is strong enough, then I will look into high altitude jets. The shop here probably has a little air fuel gauge they could use on it. The spark plugs are black, but I've got the screw quite lean so I dunno.
Seems like the return on the distributor is fine, and the points are fine.
I've got the carb apart now I'll check out the float height.
Share this post
Link to post
All right I set the float height it was about a quarter of an inch off.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
