Maschinenbau 554 Posted January 17, 2018 Report Share Posted January 17, 2018 New member here, and new owner of a 1980 210 wagon. I know it's a B310, but where else would this go. I picked up this pile for $180. It's mostly complete, with a bunch of pieces in the back, but rusty has hell. The plan is to race in the Grassroots Motorsports $2018 Challenge, the annual budget drag racing and autocross competition for cars built under $2,0XX. I've been participating off and on since 2012 and it's a blast. This year there is an unofficial sub-class for station wagons, with the winner getting nothing but bragging rights and points taken from his IQ. What better candidate for a lightweight, cheap, competitive wagon than a Datsun? I'm planning to swap a VQ35, trans, and IRS from a G35. I know it's a tall order, but I'm no stranger to an angle grinder and welder. I'm hoping with the VQ being front sump, I should clear the steering link of the 210. Crossmember, tunnel, firewall, and probably even shock towers will likely get cut. It's snowing now and I'm too deep into my autocross Model A hot rod project to even think about touching this. I have a few leads on cheap donor cars that I don't mind keeping around for a bit, including one I might pick up this weekend. Lil Blue getting towed home by Big Blue 2 Quote Link to post
metalmonkey47 1,509 Posted January 17, 2018 Report Share Posted January 17, 2018 Great idea for drivetrain. VQDE is a great powertrain for making decent NA power, and it's cheap to boost in the future. Curious, is this a revup or non-revup DE you're working with? Can't wait to see where this goes. Quote Link to post
Ranman72 4,337 Posted January 19, 2018 Report Share Posted January 19, 2018 mmmmm I love the vq motors smooth and decent power power to weight there is off the hook cant wait to see some progress Quote Link to post
Maschinenbau 554 Posted February 19, 2018 Author Report Share Posted February 19, 2018 Donor car acquired, waiting its turn in the driveway while I finish up another project. 2 Quote Link to post
]2eDeYe 9,603 Posted February 19, 2018 Report Share Posted February 19, 2018 Another VQ fan here. :cool: Quote Link to post
metalmonkey47 1,509 Posted February 21, 2018 Report Share Posted February 21, 2018 Are you going to maintain the G35's aluminum subframe and arm config? If you are and need any bushings, adjustable arms, or bits to go with it shoot me a PM. I can get you a great deal on stuff if you are.Also, if that's an auto car, it's going to have a 3.357 gear in it. Yikes. Quote Link to post
Ratwagon1600 4,348 Posted February 21, 2018 Report Share Posted February 21, 2018 Nice. This kinda craziness appeals to me. Quote Link to post
Maschinenbau 554 Posted February 23, 2018 Author Report Share Posted February 23, 2018 Correct, I will swap in the entire rear subframe, which is basically 4 bolts to the chassis. Have to fab rear subframe mounts to the Datsun body though, and convert rear to coilover using the Infiniti shock mounts. Picture of a rear subframe The front is trickier. Yes it has a subframe, but only the engine, steering rack, and part of the LCA connects to it. The UCA goes to the G35 unibody. I plan to simply cut the entire front clip including shock towers of the G35, basically everything ahead of the firewall, and graft that into the Datsun. This keeps all the G35 suspension/steering geometry and engine mounting correct. I've done something similar before, and it's way easier than designing a new suspension that won't be as good in the end. Then bolt Datsun panels back on and widen as necessary. The G is 6" wider up front, so we're talkin 3" box flares. Picture of a front sub frame for reference It's an auto car, so the gearing isn't great, but keep in mind the Datsun will weigh easily 1,000 lbs less than the G, which isn't a slow car in the first place. Rear pumpkins are interchangeable between G35 and 350Z, so that's an easy cheap upgrade if I think I need it. I know I'm talking big without showing any progress, but I promise it will happen. I have a build marathon weekend planned April 7th with all my buds to chop up both cars and stitch em back together. If you're near Indiana you're welcome to join :thumbup: Until then I am daily'ing the donor car and enjoying the heck out of this VQ. 2 Quote Link to post
metalmonkey47 1,509 Posted February 23, 2018 Report Share Posted February 23, 2018 This is gonna be awesome! Can't wait to see go together. As far as gearing, there are a million different gear options from cars that use the same R200 diff. We compiled the data on it last year. You can also get a 4.08, and 4.36 which were never a factory gear. The auto VLSD has a different ring gear offset so if you want to swap ratios, you'll need a manual LSD.https://www.z1motorsports.com/upload/Z1350ZG35370ZG37GearRatios.pdf 1 Quote Link to post
Lockleaf 5,007 Posted February 24, 2018 Report Share Posted February 24, 2018 Drumming pariah is doing the same basic swap to a z car. He's on here and on YouTube with his build. You should look him up. 1 Quote Link to post
JDOM310 75 Posted February 26, 2018 Report Share Posted February 26, 2018 My mind's blown Wish I could do something like This So much to learn. Can't wait to see more progress!!! Quote Link to post
Maschinenbau 554 Posted March 22, 2018 Author Report Share Posted March 22, 2018 Another month driving the G35 to work and I still love this powertrain! I got new semi-sticky tires so I can put one good auto-cross on the G before I start the transplant. I did some test fitting and I like how the G35 wheels look inside the Datsun fender, so they will be carried over with the engine and suspension. Overall it's been a good car and I will definitely miss it, at least until I start the VQ-Datsun for the first time. In exactly two weeks I begin the Datsun 210Z swap. If anyone is interested in cutting up a G35 and a classic Datsun into one crazy franken-mobile, PM me for build weekend details. It's happening April 7-8 in southern Indiana. B-Y-O-Angle Grinder! 2 Quote Link to post
Crashtd420 4,897 Posted March 22, 2018 Report Share Posted March 22, 2018 I wouldnt mind seeing some video of that happening, actually I'm sure everyone would like that.... if I was closer i would stop by but unfortunately I am not.. good luck Quote Link to post
Maschinenbau 554 Posted March 22, 2018 Author Report Share Posted March 22, 2018 I will try to set up a live stream of the build action. We did something similar when I helped a buddy convert his Saab into a pickup in one weekend. Quote Link to post
]2eDeYe 9,603 Posted March 22, 2018 Report Share Posted March 22, 2018 Don't forget the old standby, pics! Quote Link to post
Maschinenbau 554 Posted April 6, 2018 Author Report Share Posted April 6, 2018 Live streaming this build starting tomorrow morning around 9am EST! https://www.youtube.com/watch?v=h69HvQoCdiY 3 Quote Link to post
]2eDeYe 9,603 Posted April 7, 2018 Report Share Posted April 7, 2018 That's a little early, I will catch the reruns :) Quote Link to post
Maschinenbau 554 Posted April 9, 2018 Author Report Share Posted April 9, 2018 Things happened this weekend! ...anyone need any B310 suspension parts? 2 Quote Link to post
]2eDeYe 9,603 Posted April 9, 2018 Report Share Posted April 9, 2018 That looks pretty impressive. :cool: Caught the stream from time to time, but it was mostly whacking up the G so not much to see. The pics are a much better condensed version. :lol: Quote Link to post
Bstock 8 Posted April 10, 2018 Report Share Posted April 10, 2018 First off, I am extremely jealous of the amount of work space you have! Great progress in one weekend as well. I tried to watch but the video link had an error and said unauthorized. Quote Link to post
Maschinenbau 554 Posted April 10, 2018 Author Report Share Posted April 10, 2018 Apparently youtube didn't like the background music from the stereo. The work space is nice, but now all my other cars have been exiled to the outdoors until I get the Infiniti shell scrapped. We had about 5 people Friday night and got the engine pulled after 4 hours. Saturday was 15 people on and off, and we got the fronts and rears of Datsun and Infiniti completely hacked apart. Interiors were also removed that day. Sunday was fitting the Infiniti front clip and engine into the Datsun, which fit surprisingly well. We didn't cut any firewall or trans tunnel. Just everything forward of the firewall. 1 Quote Link to post
datsunfreak 10,436 Posted April 10, 2018 Report Share Posted April 10, 2018 Things happened this weekend! ...anyone need any B310 suspension parts? FYI, 1200 guys need those bits for brake/strut upgrades. Just saying... B) Quote Link to post
Maschinenbau 554 Posted April 24, 2018 Author Report Share Posted April 24, 2018 For some reason I dove into the gas tank for a bit. I plan to use it, but add a flange and in-tank pump setup scavenging parts from the G35 tank I still have. Surprisingly the tank poured out a mostly-clear but slightly red liquid that could easily be mistaken as gasoline. Then equally surprisingly the sender flange popped off with ease, and revealed a tank that is not completely coated in thick varnish. Just normal surface rust. Another surprise, the Datsun sender reads a resistance change after a few quirts of WD-40 and a light brushing. I can re-use this! Another day or four will be spent on the tank. In the meantime I have an IRS to mount. So I got to work cutting the frame-rail-like features that sit too low for the subframe's front mounts. So much for rigidity. I'm sure I'll add it back. Now it's time to guess and check. I guess with an angle grinder. I check with the parts. The rear bumper of this car is stout. So far it has been an excellent jacking point. I put few boards between it and my jack to get the body high enough for the IRS. I rolled the tires onto cardboard so I can slide it sideways by myself. Now it's time to check. Hmmm. It won't slide forward any further. Because the UCA mounts are hitting more frame-rail-like features. It's darn close though. So I cut some more out. (guessing) And put the IRS back under. (checking) Much better! Let's see how it all fits. A bit tight, especially where the UCA may swing to hit the chassis, but I think it will work. Also see one of the front subframe mounting points. I have to build to this and it doesn't look easy, especially if I want to keep a back seat. Luckily the rear subframe mounting points are much nicer. They hang down a couple inches directly below some more frame-rail-like features. So I just need to build pylons. Note my calibrated furniture dolly. It keeps the subframe at precisely the correct ride height. The IRS under the Datsun really clears up some floor space. I should keep it that way. To my back is a gigantic pile of parts. The hot rod waits patiently. 2 Quote Link to post
]2eDeYe 9,603 Posted April 24, 2018 Report Share Posted April 24, 2018 Excellent pics :) Quote Link to post
Maschinenbau 554 Posted April 24, 2018 Author Report Share Posted April 24, 2018 Thanks! Do you think I should move this thread to Project Datto or keep it here? Quote Link to post
