R160 diff limit
Eriks
  • Replies 24
Guest Mojo510
Well there's a lot of grey area in that question, a lot has to do how you drive it. If you like side stepping the clutch and doing burn outs it won't last to long, that said, Dave Lum has a VG30DETT in his 2 door 510, this is a conservative 375whp car and he ran a R160LSD for years with no issues, we had more haft shaft issues with joints going bad or bolts that hold them to the flange loosening up. R160's are tuff little diff's and you can swap the LSD into a 4:11 or what ever ratio you'd like rather easy. My 2 cents.
Steven
It's torque that kills them. The H-165 is good for 225 ft lbs of sustained torque.
I have an L20B powered 710 so about 100 ft. lbs. torque and Nissan decided an H-165 would handle it.  Transmission gear ratios (3.321 in 1st) multiply torque so 332 ft lbs in first gear. I can't imagine any condition where I could maintain that level for less than a split second. Maybe climbing a very steep 50% grade?? I should imagine that at 332 ft. lbs. the rear tire would break loose and act like a fuse.
A Quaife, or an AP Suretrac doesn't use spider gears, so that eliminates that weak point.
Then it's up to the universal joints, and their bolts.
But unless you are running 8" wide race tires, then like Mike says, the tires will spin.
I have run 300hp in a welded up one without trouble with the differential. The rest of the package was trouble though.
I have run over 200.000 miles, about 1/3 on track, on a factory LSD one without trouble. I have run over 500K miles on a stock one behind a 100hp L 16 with mostly sticky tires.
Any tire you can put under a 510 fender will not overstress a R160.
A LSD will more than double the strength of a R160.
Welding one is not a LSD and likely will shorten its life.
Maybe the question is vague, maybe a R160 is pretty strong.
Dennis
Dennis
^^^^ This sums it up pretty well although my opinion on welded diffs is slightly different to Dennis.
For years I ran welded R160's in my rally and hillclimb car(s) as well as my road cars.
Never managed to break one and would do stupid shit like shifting down from fifth to second and locking the back end up (good for getting around corners on the dirt with a welded diff).  Halfshafts on the other hand tended to take a beating.
IMLTHO, unles you have a stupidly torquey motor, an R160 (LSD is the bomb) should be fine in the majority of applications and certainly in road going cars.
Many people run the subaru R160 conversion (LSD) and anecdotally appear to have bugger all problems with them.
Biggest problem Ihave had is with driveshaft universal joints though this can be negated to a fair degree by putting good quality universal joints in your driveshafts.
RW's 2 cents worth.
Thanks for enlightning replies. I have a 610 coupe. I believe the ratio is 3,70. I also have a R160 with LSD from a Subaru in the basement, but the ratio is 4,44, which I think is too high. But perhaps there is no problem putting the LSD into the 3,70 diff ?
Guest Mojo510
^^^What Matt said about the early clutch LSD being the one you want.
But in my experience it won't bolt in, swapping the LSD into a non LSD housing requires some machining or grinding of the housing to fit the larger LSD unit, I've only swapped four of them from 3:70 to 4:11 but I had to clearance each one, I cleaned and taped everything off and used a hand air grinder with a carbide bit and copied the housing I took the LSD out of. In all 4 cases I reinstalled the bearing carriers from the 4:11 with all the shims in the original places to check the swipe of the pinion to ring gear, this is a good starting point, I check the swipe of the 4:11 diff before disassembly and take pics and when setting up the LSD again I try to match this as close as possible. Not setting the swipe or depth of the the ring gear correctly can cause noise on/off throttle and premature gear wear, but I've never had to reset the depth of the pinion which is good cause that's time consuming and a PITA.
I have a L16, dog leg 5 speed, 4:11LSD and 24.5" rear tires and from what I remember I'm taching out about 3300rpm in 5th gear at 65mph, if this was my daily I'd swap to a 3:90. I'd think a 4:44 would be to low for street, IDK someone chime in if there running a 4:44 on the street with there opinion?
I also run the Ford LSD friction modifier in my diff to raise the break away of the clutch packs in the LSD, adding a half bottle break away went from 75ft lbs to 120ft lbs, I like a tighter diff for spirited driving and auto-X.
Steven
3.889 diff with 5th gear dogleg and stock tires it's..... 3,126
With your tires and 4.11 this is ................................. 3,128.
4.11 diff and stock tires is............................................3,300
If running 4.11 gears and 24.5" tires this is the same as running stock tires and a 3.89 diff. Your 4.11 is basically compensating for the larger diameter tires.
Guest Mojo510
Thanks for doing the math Mike, I only drive mine in the summer now and couldn't remember exactly what the numbers were. While I like the looks of my wheels on my car they are just big heavy flywheels that take more torque to get rolling, and yes the whole reason I swapped to a 4:11 ratio. Kinda miss my old 13" wheels especially when auto-Xing.
Dennis
UFO?
Dennis
It would seem to me that when an open diff tire breaks loose, it takes the load off the diff. Like spinning a tire on ice, hardly any or much less torque transmitted. If LSD, then more tire traction is added and more load put on the diff gears. If welded, then twice the tire is added to the diff load.
Well I don't know. We're comparing apples and oranges.  I guess if the side and spider gears are up to the job perhaps a wildly spinning open diff IS more destructive than an LSD that more closely locks them together....
It’s interesting this topic comes up while I’m working on swapping a CLSD carrier to a 4.44 housing.
The ring gear of the 4.44 is a bit taller/thicker than the 3.7, maybe because of the gear count difference? Trying to assemble it, the ring gear hits the housing on the one side, so the carrier can’t slide in. The two nubs for the recess of the side cover bolts is what needs to be ground (left side of the case looking in the housing), maybe 2mm, for the carrier to slide in. I measured the depth of the bolt hole before grinding to make sure I wouldn’t breach the bolt hole.
