Sign in to follow this
DatEz
521 rear axle shims
Hey folks, I’m currently swapping the rear drums to disc brakes, but I noticed that when I pulled off my rear axles, one side had only three metal shims and the other side had about 6. Does anyone know what the correct amount on each side is and also where to buy new shims? I can’t find them online.
Share this post
Link to post
It's select fit. Some need more or less.
Share this post
Link to post
Is this why every 521 bed every is not installed center?
Share this post
Link to post
The shims are used to set the proper amount of free play in the axles.
When putting the axles back into the rear axle housing, the first axle should have .012 to .035 of free play, in and out.
The second axle should have .0008 to .0059 of free play.
Share this post
Link to post
Jap crap economy pick-up :P
Share this post
Link to post
Leave them the way they are, they are set, do not mix the shims up either, they might not all be the same thickness.
Share this post
Link to post
Silly gato, that's from drifting.
Share this post
Link to post
Ok, I left them all on the way they were when I took the axles off. But now I have fully installed the disc brake conversion and there is a ton of wobble/play. Was I supposed to leave some of the backing plate on to fill the gap? I had the entire plate cut off.
Share this post
Link to post
Didn't you get directions with whatever kit you bought?
I am thinking the plate has the rear bearing in it, there is a bearing on the axle isn't there, the axle is still held in by the 4 nuts on the studs, right?
Share this post
Link to post
Well I bought the kit off a guy who already installed it but never used it because he decided to convert to 5 lug. But I also didn’t have my differential in because I was waiting for my gasket that arrived today. Now to install the new diff gasket, do I NEED to have a dealer of some sort applied? If so, would clear rtv work?
Share this post
Link to post
Any idea who made the disc brake kit?
Share this post
Link to post
Pic would help..... I'll bet it could be identified by someone here. .
Share this post
Link to post
No, you don't NEED a gasket sealer, but why risk it? I use black or grey RTV on diffs. Mainly "the Right Stuff" RTV because it's tough as nails. And it's black so it won't stand out against the black paint on the axle housing.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
