Hrvat9
510 racecar to daily
It’s been some time since I posted here but I traded my 620 for this 510 with an Sr20det. The plan is to turn this track car back into a daily by summer time!
Here are some pics
*edit*
Google drive is being sucky on my phone , I’ll get some up from my laptop
Share this post
Link to post
Welcome back can't wait to see the oics of the car. Kinda funny I have a 72 510 daily driver I took apart to completely redo as a kinda streetable/track build. I will get that car put together here down the way.
I'm gonna try to make time to do some work on this car this summer.
Share this post
Link to post
You accidentally put an extra “to” in the title. Should be “510 racecar daily” :)
Share this post
Link to post
I have one of these!  It's a slippery slope.  Pretty soon you will be at 4k on the freeway in a racing seat on super stiff springs AND LOVING IT!!!!!  haha!!!!
Share this post
Link to post
Stiff ride? noise?... Enjoyment is a slippery slope... it goes down hill with age and distance traveled. :lol:
  • Like 3
Share this post
Link to post
Gotta be slippery to enjoy it
Share this post
Link to post
sorry for the crazy long wait!
i got the cage cut out already, i got a dash, oem gas tank that looks almost brand new, spare four complete doors and some other stuff with it
it was as 4 door, whoever raced it welded the rear doors shut
its missing a front valence but it came with some huuge front bumper valence thingy? like the one edekalil posted earlier in the thread
someone did front and rear discs already but the rears dont have a bracket for the calipers. i still have to take a pic of the rotors because i have nooo idea what theyre from and theyre tiny
https://drive.google.com/file/d/17_wARbafHotwkg-ldbTvUyHglg3qOY6Q/view?usp=sharing
https://drive.google.com/file/d/17uzjpZVOdDIATB7zKgR5xI_5mj95tQGk/view?usp=sharing
https://drive.google.com/file/d/1dNPE0uDOGMYyIJndfT88yJaYZK1RPUEz/view?usp=sharing
https://drive.google.com/file/d/1Bu-mxXbMeS_7nlwI9uBz_bIKpg9ZVd3R/view?usp=sharing
https://drive.google.com/file/d/1rXkOWdFhfSBnpOFWX7rZFm1OlMazX-6p/view?usp=sharing
https://drive.google.com/file/d/1tJjydx5Ex1IWmpZ-mtxTBBg_FkOojw0E/view?usp=sharing
https://drive.google.com/file/d/1qfMjrhuEO26MY5wykW8ceIObtclQh8pc/view?usp=sharing
first question! is it possible to put all the window stuff from one door to another? the ones on the car are mint compared to the spares. or to take the door skin off the complete rusty door and use my yellow one on the car already? the rears are a whole other beast :/
Share this post
Link to post
Buy a pair of 2dr doors, bolt them up, cut out & move the B pillars back, leaving the 4dr rear doors in place, but you will cut into them to fit the longer 2dr doors!  The rear doors act as the front half of the rear 1/4.  Lots of body work!  Yes, the 2dr doors will bolt right up......just need to move the B pillars back!
All of the 68-72 4dr Sedan doors are the same (front Wagon doors similar but slightly different upper window frames, rear Wagon doors have completely different upper window frames).  The 68-71 glass is CLEAR, the 71-73 glass is factory TINTED.  Hard to tell difference unless you put next to each other with a white back drop.  All door hardware the same.
Share this post
Link to post
Thank you for the oics. And good luck with it.
Share this post
Link to post
Downhill is faster too! Very enjoyable.
Good seats help.
Share this post
Link to post
Question, will 2 door rear windows fit on a 4 door? my doors have that little bar support thing in the door cut out
DA3_FB074-897_A-424_D-9_C60-95203_E2_C8_
531_CA112-_AD83-446_C-97_D7-22_DF83_FEFC
C7_F80_A33-9_CDA-494_C-9469-_A3_E72_D991
Share this post
Link to post
Nope. If you go thru all the trouble to install the 2dr doors, the rear 1/4 windows would fit.  If you actually have those rear windows, hold them up to the car.......you will see that the 2dr windows won't fit in place of the 4dr door glass.  You might be able to modify the window assemblies, but likely as much work as installing the 2dr doors!!
If the 4dr rear doors were simply gutted by unbolting the parts, you should be able to re-install all of the glass, tracks, regulators, small 1/4 windows etc, UNLESS they cut the inner sheetmetal panels out to lighten it...........that would suck cuz you would NOT be able to re-install all those parts!
Got pics of the INSIDE of the rear doors??
TJ
Share this post
Link to post
Dammit...yeah all four doors have everything cut out to be lightweight from what I remember :( I think I’m going to have to take my chances on the 2 door rear windows and making them fit since I don’t hAve glass on the rear doors(which are welded shut) , just that lexan plastic stuff
TJ
Share this post
Link to post
How about installing the vertical window tracks, including the long rearward one that also holds the front edge of the small rear 4dr 1/4 window, install that small rear 1/4 glass, install the OEM door glass, but install it permanently?  Without the inner sheetmetal, you have no way to mount the door glass regulator.
You could potentially lengthen the 2dr rear 1/4 windows if you have a second set to cut pieces from, but then you would have to weld them together.......no other way to successfully build that, that I can think of!  The next issue is that the OEM glass is curved, so no economical way to custom make longer glass.....you would be back to making Lexan (polycarbonate) "glass".
TJ
Share this post
Link to post
The B-pillars are different, so you'd need 2dr b-pillars ... but that's a HUGE project
Share this post
Link to post
INDY510 what differs between pillars?  I had heard that the 4dr pillars can be mod'd to work..........??
Share this post
Link to post
Hrvat9 I do have a DRIVERS side B-pillar if you go that route!
Share this post
Link to post
I have 4 door doors with everything but how would I go about installing the window assembly into the rear doors when the insides are cut out? impossible right ?
On another note , these just finally came In :D
Share this post
Link to post
With the inside sheetmetal cut out, you can not mount the window regulator.  Maybe you can still install the forward & rear vertical glass "tracks", and install the small 1/4 glass window, then figure out a way to fab some strong brackets to hold the door glass up in position permanently.........that's my thought!
Share this post
Link to post
Those wheels are pure sex.
Now I have to go wash up.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
