Center Take-Off Rack & Pinion
Moist Lightning
If you measure the suspension up. Ie pivot points for top and bottom arms balljoint locations steer link locations i can run the whole setup through a design program and can tell you the best spot for mounting whatever rack you want to try. I will do it myself one day but i dont have the time spare or someone available to help with the string lines etc.
I did a quick dodgy sim on a file i have already and a rack mounted at the bottom pivot point hieght that is 3in wider can be bumpsteer minimised by moving the rack back a few in inches. It can be done just need to see what fits.
That would be awesome. Unfortunately, my truck is under a ft of snow so might be a bit before i measure. I will as soon as i can though.
  • Replies 78
