five1oh
Datsun 510 2 door sedan "SHAKOTN"
On my grey 1200 I belive I used Scott's Old Auto Rubbers and that was quite some time ago (2010-2012 maybe) and also used the black 3M adhesive (yeah, that stuf can get very messy very quick). All of those  seals seem to be holding up well.  For the green coupe I used newdatsunparts.com and so far so good (installed September 2016).  The door seals were done off of the car. Used pretty much the same process...let the glue get tacky, hold in place for several minutes, then masking tape to hold in place at least 24 hours.  I just recently did the glass run on the front doors of the wagon and once the glass run was in place, I installed the door glass, ran it all the way up to hold the run in place....let it that way for 3 days and seems to be holding.
There are some Datsport seals I am looking at for the wagon but currently funds are tight.
Share this post
Link to post
great work! you made the RHD swap look simple.. Im jealous
  • Like 3
Share this post
Link to post
I just noticed my car is missing the hoop! Dammit I knew something didn’t look right about the roof
I got my roof hoop installed and went about grinding on the floor patches.
26312896987_325e636be6_o.jpgUntitled by five1oh2010, on Flickr
41141076942_6b34782a29_o.jpgUntitled by five1oh2010, on Flickr
27311350818_9ea8b7a008_o.jpgUntitled by five1oh2010, on Flickr
39374744170_a9b0de1acd_o.jpgUntitled by five1oh2010, on Flickr
ALSO FINALLY STARTING INSTALLING STUFF BACK ON CAR. Left side door and window is first:
27311348298_d332a9aa34_o.jpgUntitled by five1oh2010, on Flickr
39374743340_c39fa3af0f_o.jpgUntitled by five1oh2010, on Flickr
39374744060_f7027fdcda_o.jpgUntitled by five1oh2010, on Flickr
40472515554_2e97e01333_o.jpgUntitled by five1oh2010, on Flickr
Share this post
Link to post
So a few days ago I picked up the grill pieces and hood trim piece, and lower grill trim piece.  I couldn't wait so I decided to put the grill together and install to see how it looked.  I think I mentioned when I turned my grill in that it was in 9/10 shape, well after getting it back it probably decreased to 8/10 shape.....it turns out that the silver paint was applied over filler to fill the corrosion.  I don't mind the corrosion and it adds some "character".  I much prefer the factory polished look.  Another thing that amazes me is all of the pieces that were made to build this grill back in 1970!!!  I can't believe that Nissan supplied this grill as a factory option.  It is AMAZING!
26403805627_4b97012c78_o.jpgUntitled by five1oh2010, on Flickr
26404017797_b0fb5d4467_o.jpgUntitled by five1oh2010, on Flickr
26403865167_e150a01715_o.jpgUntitled by five1oh2010, on Flickr
41232093722_140a31aa32_o.jpgUntitled by five1oh2010, on Flickr
41275965761_7fdeb06c2e_o.jpgUntitled by five1oh2010, on Flickr
26404018687_8948e1f2f3_o.jpgUntitled by five1oh2010, on Flickr
41232171342_6b89ecd951_o.jpgUntitled by five1oh2010, on Flickr
Share this post
Link to post
Boy is it NICE to have two 510 shells on the side yard  :thumbup:
I was able to locate the interior drain hoses and clamps, as well as the fender hoses.  Not sure if these are made anymore as it may be nice to eventually replace the fender ones but these will do the job!  I soaked these in hot soapy water and scrubbed them for an hour before installing. They may not be pretty but I am glad I had some that I could use:
40561313854_49a86c90d7_o.jpgUntitled by five1oh2010, on Flickr
40379101455_6cb7cd5232_o.jpgUntitled by five1oh2010, on Flickr
27403101608_b81a26700b_o.jpgUntitled by five1oh2010, on Flickr
41275791791_8e178bc5ed_o.jpgUntitled by five1oh2010, on Flickr
Share this post
Link to post
So Eric came over yesterday to help me finish the trunk rust repair and POR-15 all of the floors.  While waiting for him to arrive I just HAD to try and install the dash among other things.  SO SATISFYING!!!  I am beyond happy I decided to go as far as I did with powdercoating and plating the hardware......it's like assembling a brand new car!
I also have appreciation for the staff that plated my bolts.......I had NO CLUE they have to wire EVERY SINGLE washer, nut, bolt, etc. separately so they are all coated evenly.  I estimate I have given them over 2,000 pieces.........
41275847051_1484ba3eb7_o.jpgUntitled by five1oh2010, on Flickr
BACK TO THE DASH..........and column......and pedal box........and crossmember
41232307402_474500ceb2_o.jpgUntitled by five1oh2010, on Flickr
39466091240_fe8f684dbc_o.jpgUntitled by five1oh2010, on Flickr
41275847941_c2b2ecee1f_o.jpgUntitled by five1oh2010, on Flickr
26403807347_3603f5cffc_o.jpgUntitled by five1oh2010, on Flickr
40379029575_bbbc64642f_o.jpgUntitled by five1oh2010, on Flickr
40561385524_fb06884ab7_o.jpgUntitled by five1oh2010, on Flickr
40379028685_be8290ab75_o.jpgUntitled by five1oh2010, on Flickr
39466226290_11e37b65b2_o.jpgUntitled by five1oh2010, on Flickr
39466086840_623760f3cc_o.jpgUntitled by five1oh2010, on Flickr
Share this post
Link to post
Trunk repair and POR-15 time  :thumbup:
39466088070_b4f95c0ec1_o.jpgUntitled by five1oh2010, on Flickr
26404010717_5dff52b523_o.jpgUntitled by five1oh2010, on Flickr
40379034415_f6f6433fed_o.jpgUntitled by five1oh2010, on Flickr
40379103595_40b4c94420_o.jpgUntitled by five1oh2010, on Flickr
40379208625_4fe356dea8_o.jpgUntitled by five1oh2010, on Flickr
41232313862_7c48faf029_o.jpgUntitled by five1oh2010, on Flickr
26403806507_da65327399_o.jpgUntitled by five1oh2010, on Flickr
40561326534_03b2172f46_o.jpgUntitled by five1oh2010, on Flickr
..............and Good Night SHAKOTN  :sleep:
40379035505_76f5b93583_o.jpgUntitled by five1oh2010, on Flickr
Share this post
Link to post
too clean... way too clean!!!
Share this post
Link to post
slapped my taillights on after being rechromed.  Unfortunately they are FAR from perfect but definitely much better than when I got them.  They had to be copper dipped three times to try and fill the corrosion and unfortunately there are still a ton of dots around the frames along with missing chunks  :( .  Oh well.  Should look much nicer once I get the black paint on them.
39532929610_2bf5674ef0_o.jpgUntitled by five1oh2010, on Flickr
41299492302_baf04bf942_o.jpgUntitled by five1oh2010, on Flickr
I also finished my trunk repair.  Seam sealed the battery tray, scuffed up the POR-15, and painted Cactus Green with the rattle can I got:
27470180438_9de7b8e16a_o.jpgUntitled by five1oh2010, on Flickr
39532940550_97bab0949e_o.jpgUntitled by five1oh2010, on Flickr
27470196898_534202d12f_o.jpgUntitled by five1oh2010, on Flickr
41299505862_4b757de354_o.jpgUntitled by five1oh2010, on Flickr
41299488342_6ae94493c6_o.jpgUntitled by five1oh2010, on Flickr
26470573097_0a576484f6_o.jpgUntitled by five1oh2010, on Flickr
26470574987_8433bed173_o.jpgUntitled by five1oh2010, on Flickr
26470577747_955b9655ec_o.jpgUntitled by five1oh2010, on Flickr
Share this post
Link to post
Headlight and signal time!  SUPER HAPPY with the front of this car.  I am going to remove the rechromed headlight trim and add the black paint where appropriate so it should look much better and sharper with some contrast.  I also robbed the Marchal headlights I bought for my Skyline.  Will need to get another set later.
40628621814_e76fe4f1e6_o.jpgUntitled by five1oh2010, on Flickr
39532939070_6fff42dc19_o.jpgUntitled by five1oh2010, on Flickr
41299505642_23d5965244_o.jpgUntitled by five1oh2010, on Flickr
40446192915_6c3b2a58e6_o.jpgUntitled by five1oh2010, on Flickr
39532939710_27bc3110dd_o.jpgUntitled by five1oh2010, on Flickr
26470577207_588afc733a_o.jpgUntitled by five1oh2010, on Flickr
I also mounted the ignition:
41299488622_ae5344db6b_o.jpgUntitled by five1oh2010, on Flickr
Next step is to modify the defrost cover to fit.  The LHD US cover has a hole for the VIN# that needs to be ground down:
27470190078_1c1939c8e9_o.jpgUntitled by five1oh2010, on Flickr
Share this post
Link to post
I am trying to do something each night, no matter how small the task may be.  Last night I installed the hood hinges and door handles as well as one lock cylinder.  I have a key that works in the trunk, gas door, and left side door lock.  The right side door lock appears to be different so I am hoping I can visit a locksmith to get the cylinder rekeyed to match........not sure if anyone does this anymore.
The reason for getting the hinges mounted is that I will be running hood shocks so I wanted to take some measurements and make sure I get the right ones.  Doing research I found that people use the McMaster-Carr ones but I personally don't like the mounting point and how short they are.  I want to mount it further forward below the hole in the fender well right next to the shock tower.  Any suggestions are greatly appreciated.  The keeper mentioned using VW Jetta trunk shocks but is unsure of the year.  Anybody have good ones they use?
41323230952_8aae8e9461_o.jpgUntitled by five1oh2010, on Flickr
39556548970_a03e9282e8_o.jpgUntitled by five1oh2010, on Flickr
39556549030_f75a667e5a_o.jpgUntitled by five1oh2010, on Flickr
41366301011_9acd6ab4fb_o.jpgUntitled by five1oh2010, on Flickr
  • Like 3
Share this post
Link to post
I know you said no, but I can't recommend highly enough the McMaster-Carr set-up. Used that on my last 5 cars and I love it. It also raises the hood up higher than stock by a good 4-5". Very nice if you're tall like me.
Share this post
Link to post
FLOORS ARE DONE!!!!!!!!!!  I finally received my Eastwood Undercoating and painted the underside of the car.  The only thing left to paint on the shell is the spare tire underside.  I am looking forward to being done with paint.  I can now finally run my gas line and install the tank.  That is the goal of tonight anyways.  Also, I installed the trunk latch bracket.
Sorry for the poor picture quality as it was night time:
41345397782_c22ce398d8_o.jpgUntitled by five1oh2010, on Flickr
41388182401_0841594eca_o.jpgUntitled by five1oh2010, on Flickr
40673923104_58274365c9_o.jpgUntitled by five1oh2010, on Flickr
41345395152_332be3947d_o.jpgUntitled by five1oh2010, on Flickr
40492657625_b264ddc80e_o.jpgUntitled by five1oh2010, on Flickr
  • Like 4
Share this post
Link to post
i had the same problem with my datsun and the locks, i went to the local locksmith after calling a bunch in town. got it done for 20$ and it took him less then 24 hours to do, he said he could of had it done in an hour but he was backed up with business.
Love the build quality BTW
Share this post
Link to post
Thanks for the kind words.  Also, thanks for the feedback on a locksmith.  I am hoping to find one local on my lunch break today.
Share this post
Link to post
I had all mine matched to the ignition. The only thing is the lock cylinder needs to accept the same style key. single side, double side, etc.
I think I paid $15 per lock.
Share this post
Link to post
I have long thought i would like to have all my Datsuns rekeyed to use the same key. Course none run atthe same time so it's never mattered
Share this post
Link to post
Got the lock rekeyed and installed!
26559082047_4ca34f6f5c_o.jpgUntitled by five1oh2010, on Flickr
40535266005_851a08b5c5_o.jpgUntitled by five1oh2010, on Flickr
Painted the spare tire area:
41387765992_f496815aba_o.jpgUntitled by five1oh2010, on Flickr
41387786242_95d47e9a3d_o.jpgUntitled by five1oh2010, on Flickr
41387753452_134a483f76_o.jpgUntitled by five1oh2010, on Flickr
40535279025_f8c557d2c2_o.jpgUntitled by five1oh2010, on Flickr
Better pics of the underside:
40535239855_f2d3f8f97b_o.jpgUntitled by five1oh2010, on Flickr
41387775802_ac9a875a51_o.jpgUntitled by five1oh2010, on Flickr
40715854094_85b3a3e771_o.jpgUntitled by five1oh2010, on Flickr
Installed the 1" rubber plugs:
40715864424_99437582e0_o.jpgUntitled by five1oh2010, on Flickr
Share this post
Link to post
Fuel line is in  B)
39620954470_460907e16d_o.jpgUntitled by five1oh2010, on Flickr
40535262755_99550da12c_o.jpgUntitled by five1oh2010, on Flickr
40715861314_d34f18b3d5_o.jpgUntitled by five1oh2010, on Flickr
GAS TANK is in....yes I know it is ugly.  When I was cleaning it to paint I noticed it appeared to have two repairs done to it.  Decided to run it as is until I find a nice one for replacement
40535279615_b30e5fdbe1_o.jpgUntitled by five1oh2010, on Flickr
39620968960_27b2a2efba_o.jpgUntitled by five1oh2010, on Flickr
26559086827_5a92b47caf_o.jpgUntitled by five1oh2010, on Flickr
39620994060_d1cd98360d_o.jpgUntitled by five1oh2010, on Flickr
40715872534_5d1b503fec_o.jpgUntitled by five1oh2010, on Flickr
Share this post
Link to post
Eric came over yesterday to help with a bunch of stuff.  He brought my newly polished trunk.  In addition while he was over he went back over the some of the body that wasn't previously cut and removed the orange peel and polished it.  Car is looking AMAZING!!  We also got the front spoiler on, the marker lights, badges, mirrors.
First thing to do was install the trunk rubber:
26559088577_46985f571b_o.jpgUntitled by five1oh2010, on Flickr
26559094437_5f71626337_o.jpgUntitled by five1oh2010, on Flickr
41430159931_18f107494e_o.jpgUntitled by five1oh2010, on Flickr
41387773992_27ec4b1f38_o.jpgUntitled by five1oh2010, on Flickr
41387759552_a053a22e9f_o.jpgUntitled by five1oh2010, on Flickr
26559082847_dc92e2536e_o.jpgUntitled by five1oh2010, on Flickr
40535267555_f811afc1a3_o.jpgUntitled by five1oh2010, on Flickr
40715863114_1fb68d7f43_o.jpgUntitled by five1oh2010, on Flickr
Share this post
Link to post
I painted my interior door trim silver and removed the weatherstripping from my 1/4 windows.........stabbed and cut myself at least 10 times what a pain in the butt:  Eric still has to paint the wiper cowl, 1/4 windows, and gas door.
27558014118_2f258f0b0c_o.jpgUntitled by five1oh2010, on Flickr
41387786892_46bd55b4d3_o.jpgUntitled by five1oh2010, on Flickr
26559095697_5c7414ee4b_o.jpgUntitled by five1oh2010, on Flickr
41430187151_7dc302a9ed_o.jpgUntitled by five1oh2010, on Flickr
Share this post
Link to post
Trunk installed:
41387755742_c764d865ec_o.jpgUntitled by five1oh2010, on Flickr
Bluebird badge installed:
40715878154_c64a2ccc34_o.jpgUntitled by five1oh2010, on Flickr
1600 SSS badge installed:
41430164651_fb047dde6a_o.jpgUntitled by five1oh2010, on Flickr
Rear bumper rubber installed:
27557992348_2887a68e80_o.jpgUntitled by five1oh2010, on Flickr
Front spoiler installed:
40715871424_482d4c6e21_o.jpgUntitled by five1oh2010, on Flickr
Bluebird fender badges and SSS indicators installed:
40535239095_42e221fa24_o.jpgUntitled by five1oh2010, on Flickr
40535271055_1473f65de3_o.jpgUntitled by five1oh2010, on Flickr
Fender mirrors installed:
26559083217_7548ff98de_o.jpgUntitled by five1oh2010, on Flickr
SSS Pillar vents installed:
40535265555_9a6c9b5814_o.jpgUntitled by five1oh2010, on Flickr
Good Night SHAKOTN - great day:
40535259365_645d52370e_o.jpgUntitled by five1oh2010, on Flickr
41387754442_405dcfebae_o.jpgUntitled by five1oh2010, on Flickr
  • Like 5
Share this post
Link to post
:frantics:  :frantics:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
