Datsun 510 2 door sedan "SHAKOTN"
five1oh
So I finally removed the carbs and put proper gaskets in between the manifold/isolaters/carbs and also installed a one way valve on my brake booster vacuum line.  I also drilled a hole in the mounting plate for the throttle cable and added a spring for the center linkage.  Josel will be over in the next hour for the final tune on my carbs!!!!!  Can't wait!!!  I also finally started one of the final pieces of the car by getting some plastic cut to fix my SSS center console.  More to come on that very soon...
43461285195_4601184677_k.jpgUntitled by five1oh2010, on Flickr
44366256741_1fe22e8a9c_k.jpgUntitled by five1oh2010, on Flickr
43461286355_6804a48202_k.jpgUntitled by five1oh2010, on Flickr
29430675647_7e34eff7b8_k.jpgUntitled by five1oh2010, on Flickr
44319169942_74e0597ac8_k.jpgUntitled by five1oh2010, on Flickr
44319168452_d091cba0d9_k.jpgUntitled by five1oh2010, on Flickr
43460610105_b2728571d2_k.jpgUntitled by five1oh2010, on Flickr
29430675067_bb9f9a31d1_k.jpgUntitled by five1oh2010, on Flickr
44366927721_8f62b84afa_k.jpgUntitled by five1oh2010, on Flickr
42558938860_6f5110c492_k.jpgUntitled by five1oh2010, on Flickr
  • Replies 554
26 minutes ago, mrbigtanker said:
I have that center console to bad that one is drilled up. Show some finished pics. Looking good.
See you at JCCS, bring yours and we can trade straight up....does yours have the badge?
Spotted a clean sqaure tail light 2002 while out on a drive this past weekend:
29559244887_6d0cd056ae_k.jpgUntitled by five1oh2010, on Flickr
42687754520_3d9a3b0b8c_k.jpgUntitled by five1oh2010, on Flickr
30627003888_5fbc72f042_k.jpgUntitled by five1oh2010, on Flickr
43587290615_aaedd86acc_k.jpgUntitled by five1oh2010, on Flickr
44496823641_027729c5f6_k.jpgUntitled by five1oh2010, on Flickr
30627065638_0a7f017715_k.jpgUntitled by five1oh2010, on Flickr
43778943714_8d4336b92a_k.jpgUntitled by five1oh2010, on Flickr
44496935661_1c01f8d388_k.jpgUntitled by five1oh2010, on Flickr
30627171738_e1cbc624ae_k.jpgUntitled by five1oh2010, on Flickr
So I semi-finished my trunk.  Got my battery tie down and battery box lid and finished the battery area.  I also cut my trunk carpet but you will see from the photos below I made an egregious error.......I forgot to measure the width and used my factory rubber mat as a template.  Unfortunately the rubber has shrunk a bit over the past 50 years so I cut the carpet too narrow.  I plan on getting another one eventually but this will have to do for now ?
44447055502_090339787a_k.jpgUntitled by five1oh2010, on Flickr
30627174588_4b50edffa2_k.jpgUntitled by five1oh2010, on Flickr
44496927041_ba4a14526c_k.jpgUntitled by five1oh2010, on Flickr
29559441817_ad83c5669f_k.jpgUntitled by five1oh2010, on Flickr
42687960140_a9bc0f4ae2_k.jpg by five1oh2010, on Flickr
43587292805_56a1a52874_k.jpg by five1oh2010, on Flickr
43587290995_38f56899f5_k.jpg by five1oh2010, on Flickr
29559323857_89ba5be9a8_k.jpg by five1oh2010, on Flickr
43778848164_dbaa20b2cb_k.jpg by five1oh2010, on Flickr
30626994628_0f09fa5f49_k.jpg by five1oh2010, on Flickr
Finished my heater box assembly.  I cleaned it up and painted it and put it in.  Then I set the center console in.  Looking good.  I should be finishing the center console soon as I got my pieces back from the plastic shop...
30627168758_b3a6761011_k.jpg by five1oh2010, on Flickr
43779048384_f4ec6b0e8e_k.jpg by five1oh2010, on Flickr
29559331227_554272b5d5_k.jpg by five1oh2010, on Flickr
44446957392_340fcf0376_k.jpg by five1oh2010, on Flickr
So I did some stuff on Saturday but was slacking when it came to pictures.......
I put the car up in the air for the last time before JCCS.  While up in the air I put in the new speedometer cable and topped off the transmission....hopefully my car will be leak free now.  I also cleaned off the inside of my rear wheels since the coilovers are leaking oil and getting them dirty.  I wish I could afford some new rear coilovers.  Hopefully one day soon.
When running the speedo cable I had to drill a massive hole in the firewall to fit the connection through.  Also it turns out my pedal box bracket runs squarely into the back of the speedometer.  I am actually quite surprised but I was able to drill a hole with a step drill bit and I managed to get it spot on.  While the gauges were out I replaced all the lights and swapped the headlight and wiper switch since I have them in the wrong position initially.  One other thing is that I received a new signal stalk and installed that and FINALLY hooked up the flasher can correctly.  My signals NOW WORK ? ................except the sequential part is not working yet ?
I guess I still have some diagnosing to do.....when I remove the covers they look brand new inside and I can hear the relay click.  I honestly believe the location of my battery and the distance the current has to travel from the trunk to the engine room to the signal stalk through the relay and back to the trunk may be the issue.  Will test another day but I am glad the wiring is getting there.
The pics I did get:
42827205180_949f939c39_k.jpgUntitled by five1oh2010, on Flickr
43918341764_fd3164739a_k.jpgUntitled by five1oh2010, on Flickr
29697971107_e91c350f30_k.jpgUntitled by five1oh2010, on Flickr
43727325835_d6a57e0b5b_k.jpgUntitled by five1oh2010, on Flickr
43917547584_c74d15c1b9_k.jpgUntitled by five1oh2010, on Flickr
So I finally decided it was time to take a shot at fixing up my center console.  I was super nervous because there was a bunch of plastic missing and I was worried I would ruin it trying to weld it.  I picked up a plastic welder from Harbor Freight and decided to give it a go.  I started with removing the old wood covering on the base piece.  The base piece was cracked in half so I glue/welded it together and filled the 4 old switch holes someone drilled in it.  My console was cut up near the front and was missing the front panel.  Using pictures I had TAP Plastics cut out some pieces for me and made my own.  Once the missing sections were welded into place and the glove box was assembled I wrapped it in some vinyl wood wrap I picked up on eBay the shade is much lighter but the grain is the same and I am STOKED with how nice it came out.
Sure the welded parts could use some sanding but overall I am super HAPPY ?    Now to rob the shift boot of my hako console.......
BEFORE where the chunks were missing:
Process:
42826436850_2ca742f0e0_k.jpgUntitled by five1oh2010, on Flickr
44636325311_cca226c024_k.jpgUntitled by five1oh2010, on Flickr
42826242550_1af8338049_k.jpgUntitled by five1oh2010, on Flickr
42826242370_0c82750f41_k.jpgUntitled by five1oh2010, on Flickr
44636322611_8f7a500700_k.jpgUntitled by five1oh2010, on Flickr
29697971047_c4b02daf29_k.jpgUntitled by five1oh2010, on Flickr
42826243790_75e6f70718_k.jpgUntitled by five1oh2010, on Flickr
29698171797_af8be7831a_k.jpgUntitled by five1oh2010, on Flickr
44636326611_3e6bef0889_k.jpgUntitled by five1oh2010, on Flickr
44636325881_b2e3603b40_k.jpgUntitled by five1oh2010, on Flickr
42826244170_716ec52345_k.jpgUntitled by five1oh2010, on Flickr
42827204720_6fcf52210f_k.jpgUntitled by five1oh2010, on Flickr
42827202840_c6e82576b8_k.jpgUntitled by five1oh2010, on Flickr
30766424388_d1446524ab_k.jpg by five1oh2010, on Flickr
44586524582_e171771d5b_k.jpgUntitled by five1oh2010, on Flickr
30766423708_9123183e32_k.jpgUntitled by five1oh2010, on Flickr
30766425008_72ca29a48c_k.jpgUntitled by five1oh2010, on Flickr
29698171927_29f53b70ea_k.jpgUntitled by five1oh2010, on Flickr
Edited by five1oh
  • Like 6
8 hours ago, Charlie69 said:
Nice work!  How would you rate the Harbor Freight plastic welder?
I loved it. Easy to use and worked well. I am now confident to tackle more things in the future. As always I can get better with more use but it was very simple.
So two days before I left for JCCS I got a couple last minute things done.  I replaced the oil sending unit with one that works with a gauge (since I put the wrong one in previously - light type) and I sand blasted, painted, and installed a stock 510 radiator fan shroud to help with cooling at slower speeds or in traffic.
29805407387_0bf907bf8a_k.jpgUntitled by five1oh2010, on Flickr
44026883814_46c1813953_k.jpgUntitled by five1oh2010, on Flickr
30875237738_828bc7be97_k.jpgUntitled by five1oh2010, on Flickr
44696131862_c4c3a2675c_k.jpgUntitled by five1oh2010, on Flickr
44745111301_65df482af5_k.jpgUntitled by five1oh2010, on Flickr
42935705910_e90fe0c3bb_k.jpgUntitled by five1oh2010, on Flickr
42932075720_5d6c302863_k.jpgUntitled by five1oh2010, on Flickr
44745397471_9d37b642ad_k.jpgUntitled by five1oh2010, on Flickr
29805408947_c5fcf83163_k.jpg by five1oh2010, on Flickr
Edited by five1oh
After the little fixes I decided to wash the car for the first time hoping it would still be clean when I arrived in Long Beach:
29805412557_4bece736f0_k.jpgUntitled by five1oh2010, on Flickr
44026875414_3d6745944f_k.jpg by five1oh2010, on Flickr
29808781567_e25c343b71_k.jpg by five1oh2010, on Flickr
44026857074_109484de62_k.jpgUntitled by five1oh2010, on Flickr
44745421821_55312bc2d3_k.jpgUntitled by five1oh2010, on Flickr
42935707660_30f8dd9754_k.jpg by five1oh2010, on Flickr
42935523810_bf5eeb5119_k.jpgUntitled by five1oh2010, on Flickr
30875241258_1442e17484_k.jpgUntitled by five1oh2010, on Flickr
44696453512_28f9bb825c_k.jpgUntitled by five1oh2010, on Flickr
30875242398_a0f56aaf3f_k.jpg by five1oh2010, on Flickr
44023589264_08928c9775_k.jpgUntitled by five1oh2010, on Flickr
Edited by five1oh
I just had to go for a spin now that my oil pressure gauge and speedometer worked.  I still need to hook the tach up but I DID test it and it works.  I blew the fuse because when testing it (looped circuit) I had it attached to the starter wire which only has power on cranking.  Will get it fixed soon.
29805412617_be614b0a24_k.jpgUntitled by five1oh2010, on Flickr
43833503715_750e03151f_k.jpg by five1oh2010, on Flickr
42932077780_f948042294_k.jpgUntitled by five1oh2010, on Flickr
29808042687_3036c2992d_k.jpgUntitled by five1oh2010, on Flickr
44026797364_db54920bde_k.jpg by five1oh2010, on Flickr
42935584220_04db2ff1c3_k.jpg by five1oh2010, on Flickr
29808781737_64ef04e058_k.jpg by five1oh2010, on Flickr
Edited by five1oh
So on Friday AM I got up at the crack of dawn, dropped my kids off at a friends so that she could take them to school.  I left Benicia at 650am to our meet up spot in San Jose off 101.  The first 70 miles went well and I was in traffic for a bit.  I arrived at 830am with the agreed meet time being 9am.  Once I got there I filled up the car and got some donuts for breakfast.
44696836822_39ea381706_k.jpgUntitled by five1oh2010, on Flickr
42936224110_3d1dde25cf_k.jpgUntitled by five1oh2010, on Flickr
30876583758_1cd4970bb0_k.jpgUntitled by five1oh2010, on Flickr
Naveed and Matt showed up at 9 and we were supposed to head out at 930.  By that time we heard Sergio and Daniel were on their way south so we decided to wait so we could all drive down together.  They arrived at around 950 and then filled up with gas as well.  When Sergio pulled out of the gas station his left rear brake started seizing up.  We hadn't even left yet and already an issue!  It was very minor though, we got his car up in the air and he adjusted the brake drum and it was good to go.  We left at about 1030am finally on our way south.
After about 10 miles my friend Naveed pulls off to the right side of the freeway.  (this isn't the first time I have been with him for this exact situation)  Turns out his Abflug front spoiler started coming off on his r32 GTR.  A quick zip tie fix and we were on our way again.  About 30 minutes later we exited the freeway and it turns out he was losing the other side of the spoiler and asked if I could carry it the rest of the way to Long Beach.  Obviously I obliged but it was super difficult to drive after that because the spoiler is also an underbody piece so it was super wide and kept creeping into my shifter which made it difficult to shift.
44746741711_fff86e936c_k.jpgUntitled by five1oh2010, on Flickr
30876564038_5fd389af58_k.jpgUntitled by five1oh2010, on Flickr
29809205157_827a300081_k.jpgUntitled by five1oh2010, on Flickr
29810492507_f8f9f04bcf_k.jpgUntitled by five1oh2010, on Flickr
30875813608_e114cf027b_k.jpgUntitled by five1oh2010, on Flickr
VIDEO:
44747377611_56275546fc_b.jpgUntitled by five1oh2010, on Flickr
29809185427_f9ab3f6334_k.jpgUntitled by five1oh2010, on Flickr
FIRST GAS STOP:
29809196157_fcf81f0002_k.jpgUntitled by five1oh2010, on Flickr
30875818678_732937c6e3_k.jpgUntitled by five1oh2010, on Flickr
30875818938_167abe378e_k.jpgUntitled by five1oh2010, on Flickr
SECOND GAS STOP:
43838399815_bf8491502f_k.jpgUntitled by five1oh2010, on Flickr
DRIVING:
43838386425_6781879b21_k.jpgUntitled by five1oh2010, on Flickr
43837119985_a6b7200bbf_k.jpgUntitled by five1oh2010, on Flickr
44745841941_e436128f17_k.jpgUntitled by five1oh2010, on Flickr
Edited by five1oh
