Datsun 510 2 door sedan "SHAKOTN"
five1oh
  • Replies 554
What kind of transmission are you running ? if its not stock what is it out of ? thanks
I forget what the number is but it is the desirable Nissan 280zx 5 speed with the overdrive 5th gear.  Since my shell was stock automatic the hole lined up perfectly.  No cutting required  :)
So I ordered some parts I need for the 510 before I tear the motor back down to the block to replace the head gasket and surface the head.  While waiting for parts I started tackling the small things again.  Here is a pic of my Watanabe Falcon steering wheel and horn button mocked up.  I bought this wheel for my hakosuka but while I wait for that car to get done I thought it would be nice to run it in the 510.  I bought the wheel and had it recovered in black Alcantara with red stitching and center stripe.
27387806367_010e038ef1_k.jpgUntitled by five1oh2010, on Flickr
I also removed the stickers from the drivers side 1/4 window:
41356672135_421e9c18f3_k.jpgUntitled by five1oh2010, on Flickr
In addition I finally replaced the hardware on my SSS coupe fold down rear seat and fabbed the upper mounts to work.  I still need to adjust them a little bit and modify the door cards to fit but I am very happy with the result:
40451216660_88dbd35bf8_k.jpgUntitled by five1oh2010, on Flickr
42212163562_eb22b4661f_k.jpgUntitled by five1oh2010, on Flickr
41357011725_8573ab74a2_k.jpgUntitled by five1oh2010, on Flickr
42258614761_8cd2d40085_k.jpgUntitled by five1oh2010, on Flickr
41356943095_cd583a89fa_k.jpgUntitled by five1oh2010, on Flickr
40451618040_19202ba56b_k.jpgUntitled by five1oh2010, on Flickr
42258678471_64088e4708_k.jpgUntitled by five1oh2010, on Flickr
42212084272_4f85bc9b4c_k.jpgUntitled by five1oh2010, on Flickr
41537019524_c6836ec225_k.jpgUntitled by five1oh2010, on Flickr
42211907892_f10034d298_k.jpgUntitled by five1oh2010, on Flickr
Most excellent build!  Love the cactus green, and that you are keeping it L-series. A few comments from the peanut gallery: What did Troy say about your tie rod installation? I notice you have all the shims on top of the steering arm. You might need to move some under the steering arm to make the tie rods parallel to the lower control arms. A good alignment shop will adjust the shim stack to minimize bumpsteer. Also, your motor may be tipped back a little. On my '72 floor shift automatic to 280ZX 5 spd conversion, even though the shifter ears came up centered in the factory cutout, I had to cut the tunnel forward of the shifter about 6" to fully clear the trans. This is with a Design Products (DP Racing) modified tranny crossmember and 510 tranny insulator. It might also explain what looks like (from your pics) to be a fair amount of clearance between the header collector pipe and the trans crossmember, especially if the pipe is angled down.  I would expect that the header was designed for the collector pipe to be level.  Just a couple things you might want to check. You've got a damn nice build going!
Thanks Tedman! Your car is ultra clean!!!! Thanks for the tips....I admit I have some adjustment to do on the tie rods....haven't had a chance yet but it will be addressed, I was more concerned about it contacting the wheel but it should be ok. I still have to swap front springs to raise the car up and then I will have my hands full trying to get it aligned.
On the tranny note I looked under the car and see what you are talking about. It does appear to be in contact but I'm running Troy's tranny mount and it is cinched all the way up. I will loosen it back and see if there is more cutting I need to do.
So I received my coupe dash harness from Craig Ford last week (thanks!!!!) and had a chance to put it in yesterday. I used the engine room harness I already had in the car(JDM SSS sedan) but once everything was hooked up I didn't seem to get headlights or signals working so I have some diagnosing to do. Craig also shipped me an engine room harness from a coupe so I may need to swap it out. Here are the pics of the dash :)
42393437792_a06fe7aea8_k.jpgUntitled by five1oh2010, on Flickr
27573698927_8998698a83_k.jpgUntitled by five1oh2010, on Flickr
42393436912_904eb03318_k.jpgUntitled by five1oh2010, on Flickr
41720731644_67e7461522_k.jpgUntitled by five1oh2010, on Flickr
42393437772_5154b45461_k.jpgUntitled by five1oh2010, on Flickr
41720731444_7a2a0a5c9b_k.jpgUntitled by five1oh2010, on Flickr
27573698657_32d001fd3a_k.jpgUntitled by five1oh2010, on Flickr
42393436602_a962df4b25_k.jpgUntitled by five1oh2010, on Flickr
27573696927_d7dc2e8b1b_k.jpgUntitled by five1oh2010, on Flickr
Found this thread this morning and have spent a sick day from work reading it. Inspirational, I really need to get out into the garage and crack on with my Coupe. I could use some friends like yours. Erics work looks awesome. I know you said wiring wasn't your thing, but I was wondering if you could try make a diagram for the sequential flashers? I have them in my Coupe but without the harness and the wiring in my car isn't factory so I'm at a loss as to where to begin.
Keep it up, love where you're going with this. Now off to read about your Hako.
I can't promise anything but will try.  I NEED to finish this car first though.  PLEASE PLEASE PLEASE update your build thread!  I saw your flickr account and we need updates.....it has been 4 years!  Get motivated!
My advice? Start somewhere like here...   ^_^
https://www.ebay.com/itm/Universal-3-Step-Sequential-Chase-Flash-Module-Boxes-For-Car-Turn-Signal-Light/142680629281?hash=item21386da021:g:i10AAOSw-W9bBGW8:sc:USPSFirstClass!76017!US!-1
There have been many advancements made in the last 40+ years in sequential turn signals.   :thumbup:
So a couple days ago we took the head off.  In preparation for reassembly I ordered a new head gasket, new ARP head bolts, and some better plug wires as the ones I had were falling apart.  Once the head was removed it appears that the head gasket was the issue.  I could feel bumps all over on the holes they put in the gasket to make it work.  Because I purchased it from a reputable shop I was very dissappointed.  I felt they rushed the modifications and it is what caused the issue.  The water was leaking out of the side of the block on 1, 2, and 4 which doesn't point to a warped head.  Either way while the head is off I am going to do a minor surfacing to make sure.  In addition we will be modifying the new gasket very carefully.
On to the pics.  The cylinder walls have been cleaned and everything is ready to go once I get the head back.  In addition my friend bent up the new exhaust and the next task is mocking up and cutting to fit.  I will be using two V-band clamps to assemble the exhaust.  Getting closer!
42574433361_d56d48001a_k.jpgUntitled by five1oh2010, on Flickr
42574433371_39c1f8f5cb_k.jpgUntitled by five1oh2010, on Flickr
41852249364_edf1ce3387_k.jpgUntitled by five1oh2010, on Flickr
42522805852_578ed4912b_k.jpgUntitled by five1oh2010, on Flickr
41852259264_468e13def0_k.jpgUntitled by five1oh2010, on Flickr
42574439111_9a37a967da_k.jpgUntitled by five1oh2010, on Flickr
40765931280_8b05036f0a_k.jpgUntitled by five1oh2010, on Flickr
40765926790_3f9a2c0f4c_k.jpgUntitled by five1oh2010, on Flickr
41852255774_f76cc6dbd3_k.jpgUntitled by five1oh2010, on Flickr
42574436741_376f0ad03c_k.jpgUntitled by five1oh2010, on Flickr
So when installing my transmission I noticed that the transmission bracket I got from Troy did not line up with the existing holes on the car.  I know that it worked perfectly on WANABRE and also noticed it appears that there was room for two holes closer to the engine bay.  I was going to drill the holes out and install nuts and bolts but my friend Peter talked me out of it.  He said since you already have the two holes near the rear of the car why not just cut the tabs off the bracket and weld them on the otherside.  Of course since he offered to weld them I agreed as I did not want to make unnecessary holes in the car.  From what I gather since this car was an automatic with a longer transmission from the factory I am assuming that is the reason the welded bolts and mounts are in different spots.
Needless to say we got the modification done and I will install tonight as I wanted the paint to dry:
41852248214_edd28b1524_k.jpgUntitled by five1oh2010, on Flickr
42522795152_7daf749a28_k.jpgUntitled by five1oh2010, on Flickr
Another HUGE step was made as Peter helped me bleed the brakes!  NO leaks either! So happy!  :thumbup:
42574435831_7c72e9c11d_k.jpgUntitled by five1oh2010, on Flickr
In addition Peter drilled out the spot welds on the LHD pedal mounts!  Still need to grind down and paint but juiced that once I finally can afford carpet there won't be these ugly blocks underneath it:
41852259434_109152457b_k.jpgUntitled by five1oh2010, on Flickr
27704728567_ec8a7cbf71_k.jpgUntitled by five1oh2010, on Flickr
So because I went for the coupe rear seat I needed to drill holes near the C pillar to mount the brackets that hold the seat while it is in the upright position.  My modification made in an earlier post that pushes the bracket out from the panel worked perfectly but I still needed to modify the rear door cards to fit and not interfere with the bracket mounts.  I got that done last night as well as installing my new front door cards.  Interior is looking better each day.  Still a bunch to do to finish but I am LOVING where it is headed:
40765921340_7cd0f097f3_k.jpgUntitled by five1oh2010, on Flickr
42574432841_feeb4011e1_k.jpgUntitled by five1oh2010, on Flickr
42522795412_fe98dd82cb_k.jpgUntitled by five1oh2010, on Flickr
28700596948_1d26463a3c_k.jpgUntitled by five1oh2010, on Flickr
42522796082_55b9f12916_k.jpgUntitled by five1oh2010, on Flickr
40765931950_3faa403371_k.jpgUntitled by five1oh2010, on Flickr
41852257554_fb0c7a4bc2_k.jpgUntitled by five1oh2010, on Flickr
41672833585_c69f97cae0_k.jpgUntitled by five1oh2010, on Flickr
41672833105_c51761bc48_k.jpgUntitled by five1oh2010, on Flickr
41672832725_beef206878_k.jpgUntitled by five1oh2010, on Flickr
41672832975_adfd58e9d9_k.jpgUntitled by five1oh2010, on Flickr
42522801532_91388bcfe0_k.jpgUntitled by five1oh2010, on Flickr
42522800642_914c28b586_k.jpgUntitled by five1oh2010, on Flickr
  • Like 3
So being the idiot I am I finally replaced my engine room harness.  The good news was I got the lights to work however I am still trying to get the taillights working properly.  Anyways, while testing it I am not sure why I hooked up the starter but needless to say I did............and then I even turned the key too far and cranked the motor over a bit................ :no:  :bye:  so stupid.  Tried to move it back to TDC and check the chain but it was off so now the front cover and everything has to be redone........
While the cover was off we noticed the belt tensioner was contacting the cover so I trimmed it to fit better upon reassembly.
40927647220_c1a5b383ad_k.jpgUntitled by five1oh2010, on Flickr
28864631738_cf3b581b28_k.jpgUntitled by five1oh2010, on Flickr
28864602668_6ada30047f_k.jpgUntitled by five1oh2010, on Flickr
40927649660_d3c6704647_k.jpgUntitled by five1oh2010, on Flickr
27869072637_95e5163383_k.jpgUntitled by five1oh2010, on Flickr
42738093681_d6ffba1000_k.jpgUntitled by five1oh2010, on Flickr
Prior to removing the front cover I drained the oil and am able to save it.  I also scraped off the old gasket material and prepared the engine for reassembly.  I also bagged and labeled everything nicely along with cleaning off my workspace so reassembly can go smoothly.  Now I am off to get the head checked and surfaced if necessary and get a new gasket.
40927650980_a2a5eadc31_k.jpgUntitled by five1oh2010, on Flickr
42020806684_0b541079e7_k.jpgUntitled by five1oh2010, on Flickr
42738093861_b55c7a7651_k.jpgUntitled by five1oh2010, on Flickr
41838496585_b5aadbffa1_k.jpgUntitled by five1oh2010, on Flickr
So I finally got to try out my new chrome paint pen.  WOW!  Will definitely be doing my pillar vents soon.
Got this sweet plate frame years ago.  Stripped it down and repainted the black.  The letters would not shine up and actually looked kind of black.  The paint pen worked amazing:
40927866800_0f8c98c9a5_k.jpgUntitled by five1oh2010, on Flickr
42020803024_148c0172e5_k.jpg by five1oh2010, on Flickr
And after the paint pen:
42688733872_296f26f66d_k.jpg by five1oh2010, on Flickr
  • Like 3
So yesterday I finished creating the gas tank plate and cut out the speaker tray.  I had picked up two half sheets of MDF a couple months ago and was finally able to complete the project.  I was surprised because I didn't have a template to use but managed to get the speaker tray fitting with ONLY ONE cut!!  I used the C-Pillar finishers to get the angle right and then used a tape measure over a few spots and then free-handed the rest.
Once the speaker tray was cut I used the top of a pizza box (thank you costco) to create a template for the lower section:
41845844805_51187f4ca8_k.jpgUntitled by five1oh2010, on Flickr
41845842965_a8ce4eeda9_k.jpgUntitled by five1oh2010, on Flickr
42028316794_08870de4a6_k.jpgUntitled by five1oh2010, on Flickr
27876601987_35bc31e5cd_k.jpgUntitled by five1oh2010, on Flickr
41845835055_feb5ef8fab_k.jpgUntitled by five1oh2010, on Flickr
41845835215_8e7cae798c_k.jpgUntitled by five1oh2010, on Flickr
41845834515_607cc1b0c3_k.jpgUntitled by five1oh2010, on Flickr
42745894161_a1c5ca7cc8_k.jpgUntitled by five1oh2010, on Flickr
40934948690_4d2eec0670_k.jpgUntitled by five1oh2010, on Flickr
27876598987_31347f79b1_k.jpgUntitled by five1oh2010, on Flickr
42745891811_1f50ffae42_k.jpgUntitled by five1oh2010, on Flickr
42745891951_b95d72e62e_k.jpgUntitled by five1oh2010, on Flickr
Because I have the fold down rear seat I wanted to make the block off plate match the rest of the interior.  While I would love to put a design in like the door panels I am not that talented! I had some black vinyl left over from the section under the rear window.  I was disappointed that I did not have enough to cover both pieces so I decided to cover the backing plate first.  As you can see from the pictures above I cut it to fit in the little pocket around the wheel wells which means the only way I can squeeze it in is by bending it.  Additionally I ran it so low that it is impossible to access the seat belt bolts with it installed.
Because of all this I decided to cover it first since I would have to assemble things in order for them to work and I didn't want to take it in and out a bunch of times.  I have some foam pad left over from the headliner but thought this piece would look better with no padding.  I still haven't figured out if I am going to pad the speaker tray but in order to finish that I need to pick up more vinyl.  To assemble I used 3M spray adhesive and then used a pair of scissors and contact cement for the material that folds over.
SUPER HAPPY with how it turned out and now I can't wait to get more vinyl to finish the speaker tray and lower vertical areas by the carpet.
42696516672_13553b4724_k.jpgUntitled by five1oh2010, on Flickr
42696516572_04e02cfc76_k.jpgUntitled by five1oh2010, on Flickr
42696516542_f0ea550cd1_k.jpgUntitled by five1oh2010, on Flickr
42745904111_4609e0ca0d_k.jpgUntitled by five1oh2010, on Flickr
42028321534_b990114e78_k.jpgUntitled by five1oh2010, on Flickr
42745903761_fa0d2744a0_k.jpgUntitled by five1oh2010, on Flickr
42028320144_ff59d76b16_k.jpgUntitled by five1oh2010, on Flickr
27876608397_91bdb234d8_k.jpgUntitled by five1oh2010, on Flickr
41845844085_8711ad00f9_k.jpgUntitled by five1oh2010, on Flickr
42028312184_6dadc0daab_k.jpgUntitled by five1oh2010, on Flickr
  • Like 4
So I had some time to work on the 510 today. The focus was to clean up the wiring and get the dash finished. I started by shortening the positive battery cable and getting the battery in the battery box. I also sanded down some paint under the negative ground cable and re-secured it. I then got the dome light cables attached and tested it.
I also reinstalled my license plate and frame :)
40974970990_82a16e3c47_k.jpgUntitled by five1oh2010, on Flickr
42068603344_f1c728d369_k.jpgUntitled by five1oh2010, on Flickr
40974971120_30a2817312_k.jpgUntitled by five1oh2010, on Flickr
42786172221_1eecf7cffe_k.jpgUntitled by five1oh2010, on Flickr
41884951135_b0c4711a75_k.jpgUntitled by five1oh2010, on Flickr
42068603334_3ab14434c0_k.jpgUntitled by five1oh2010, on Flickr
