Sign in to follow this
gene knight
b210 ignition switch
how do i test the ignition switch and removal if bad
Share this post
Link to post
doctor510 do you have 1 to spare
Share this post
Link to post
docto510: my 620s are 1977 and dont have 1 of those
Share this post
Link to post
How and why do you think it's bad?..  Pull the wire plug off yours and turn the ignition switch to on and check to see if there is power.  If you cannot operate a test light, go back to school.
Share this post
Link to post
doctor510: i have 2 degrees in automotive field and 30 +years experience of working on cars, its just a question and it was suggested to me to check the ignition switch by another datsun member
Share this post
Link to post
I guess you could provide 12 volts from the battery with a jumper wire. Drive it and if the problem persists... then the ignition isn't the cause.
If it does fix the problem then the 12v supply is intermittent. Could be anything or loose connection to or from the ignition or even the ignition switch..
Share this post
Link to post
thank you datzenmike, i have will have to try it after xmas
Share this post
Link to post
So check it, at least ONE of your degrees should have told you how to do it!
Share this post
Link to post
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
