ClumsyBird Posted April 24, 2018 Author Report Share Posted April 24, 2018 Here is the culprit in question... Looks to be some sort of ECU Here's the alternator off my grey truck (the one I'm not keeping), as you can see, the plug is different than the one I have on my white frame (the one I am keeping), and since the wiring harness is off the grey one, it has a different plug. Here's the alternator I'm using now Additionally, I am currrently trying to retrofit the white truck with powersteering from the grey truck. However, the steering column wont reach all the way to the powersteering gearbox. And this is the matching powersteering gearbox and steering column from the grey truck (thanks wayno), the only thing that is changed is that it's now on the white frame. I am clueless And since this is the 100th post on this thread, here's a photo I found online, for all I know, it could be my truck 30 years in the past. But super cherry, come onnnn 1 Quote Link to comment
DrvnDrvr Posted April 24, 2018 Report Share Posted April 24, 2018 that culprit is the interior light turnoff delay timer unit. Mine went and kept draining my battery. Just bypass it. http://community.ratsun.net/topic/70994-interior-light-on-720/?hl=%2Binterior+%2Blight 1 Quote Link to comment
ClumsyBird Posted April 24, 2018 Author Report Share Posted April 24, 2018 All while I'm messing with the cab swab, I took the transmission out of the non-running grey truck (fs5w71c) and brought it to the shop to rebuild as a spare or maybe sell. Disassembly was relatively easy as long as you follow the service manual, figured out I needed all new bearings, the center mainshaft bearing lost all of its bearings and they got shredded by the transmission, which explains all the metal shavings I found in the bung. I could probably use new a new first synchro too. Shift forks seem a little worn and I would have replaced them if I was working on somebody else's rig, but they are sufficent for my purposes, probably couldn't find new ones anyway. The only really concerning thing I found besides the bearing was the end of my mainshaft seems very worn, the drive side. I included a photo below, I plan to put it in the lathe and cut it down. Probably replace whatever the shaft seats itself in, I didn't get a chance to check that out, it's likely a brass bushing, no? Any other parts I should replace while I am in there? And any recommendations for a decent rebuild kit would be welcome, I'm wary of buying mine off ebay. 1 Quote Link to comment
Lockleaf Posted April 27, 2018 Report Share Posted April 27, 2018 If your grey truck is a 720, it does not have a 71c trans unless someone swapped that in. All the 720 trans are 71b series. 2 Quote Link to comment
datzenmike Posted April 27, 2018 Report Share Posted April 27, 2018 The end at the bottom in this picture??? Don't touch it. It sits in a pilot bushing in the end of the crankshaft. If you 'turn it down' the fit will be too loose and the clutch disc will wobble. If you have this style of shifter it's a 71B 1 Quote Link to comment
ClumsyBird Posted May 8, 2018 Author Report Share Posted May 8, 2018 Ah it was indeed a b-series, and I ended up not touching the pilot shaft. There's a vendor off of ebay (Vital parts) who is close to me and sells OEM Nachi bearings rebuild kits and I ended up going with him for a very reasonable price of 50$, here's the link- https://www.ebay.com/itm/Fits-Nissan-5SPD-Transmission-Rebuild-Kit-Cars-Trucks-1984-FS5W71H-FS5W71C/282130700624?hash=item41b04cd950:g:bMUAAOSwQItT0ywv&vxp=mtr 1 Quote Link to comment
ClumsyBird Posted May 8, 2018 Author Report Share Posted May 8, 2018 Suprise! The canopy is for a longbed! Which now leaves me with a useless canopy, hooray! 1 Quote Link to comment
redhead Posted May 8, 2018 Report Share Posted May 8, 2018 Your project site looks like mine lol work on a million things at once. You wanting a canopy? 1 Quote Link to comment
captain720 Posted May 8, 2018 Report Share Posted May 8, 2018 Try selling the old canopy? 1 Quote Link to comment
ClumsyBird Posted May 8, 2018 Author Report Share Posted May 8, 2018 I've been following your build closely redhead, and yes I would like a canopy for a shortbed! Just PM me. Looks like I'll have to sell the longbed canopy. All whilst this is going on, I broke some teeth on my counter gear! Does anybody by any chance have a spare I could buy?? They are very expensive online... 1 Quote Link to comment
datzenmike Posted May 8, 2018 Report Share Posted May 8, 2018 There are several ratio sets that are matched to the drive gear above them. As they are in mesh at all times a foreign object must have gotten between them to cause this or maybe dropped? I'll have a look round and see what I might have. I'll be in Canby in a month. 1 Quote Link to comment
ClumsyBird Posted May 18, 2018 Author Report Share Posted May 18, 2018 I actually broke that gear by using a gear puller. I ended up ripping the counter gear for that transmission out of my "working transmission", I put quotations because I found chunks of gear and race in that transmission's oil and said to heck with it, its going to blow out anyways. So I pulled the transmission and of course the main bearing was out, but in this transmission the gears were shot, so I stole the counter gear (great shape oddly enough) and will likely end up throwing the rest away. Reassembled that transmission and I am waiting until I finish my head gasket to put it all back in, so I can put that aside for the moment... So with the engine and transmission out of the truck, I am now able to focus on electrical issues and the interior. I did a little digging and found out that not only is my gray truck a longbed, its a deluxe model. Looks like the deluxe package came with a trip meter built into your odometer, that sweet wood accent in the dash, an extra light on your temperature controls, a tilt steering wheel, a leather shifting boot, oil and volt gauges, locking glovebox, sensors for your doors and seatbelts, and some neat little armrests on your door. There's probably more, but those are the ones I've found so far. So besides the update, I of course have some questions: Is it alright to add in extra light bulbs to the cluster? There's some extra slots for them, but I don't want to cause a short! I've noticed a severe lack of cup holders, does anybody have a good solution for this? Do plastic kicker panels for these trucks exist? Mine were both some sort of vinyl and I want to replace And has anybody on here redone their carpet? What should I use? Mine was trashed so I had to take it all out, I'm thinking some vinyl from rock auto, and some insulation/noise dampening material of some sort? I have the dash completely out of the truck so while I'm in there if you guys have any suggestions, as always they are welcome! 1 Quote Link to comment
datzenmike Posted May 19, 2018 Report Share Posted May 19, 2018 Extra bulbs are OK. Yes there were plastic kick panels. I think.... April '85 build date, and on were two piece plastic. Earlier were vinyl covered cardboard. Use black plastic paint because surely you'll find them but they are Blue or tan. 1 Quote Link to comment
ClumsyBird Posted May 28, 2018 Author Report Share Posted May 28, 2018 Somehow I found black ones, at a junk yard near me for very cheap. Along with a bunch of other little very-hard-to-find stuff, It was the only 720 there and it was in near mint condition. Here's what I got: No clue why it was in a junkyard! And it still has a bunch of mint condition parts on it, so for those of you NW rats here's the row52 listing for it; pick 'n pull south portland, Row 38. Also I decided to paint my engine bay and floorplans while the truck is completely stripped, I used Bill Hirsch Super Black Semi Gloss chasis paint, and while its quite hard to find, I would highly recommend it if you can get it. It cost me 35 bucks (2 pints) to do my entire engine bay and cab, the same amount of POR15 would have cost 70. 2 Quote Link to comment
Charlie69 Posted May 28, 2018 Report Share Posted May 28, 2018 Does the truck in the Pick and Pull have AC? Power door windows and locks? Quote Link to comment
ClumsyBird Posted May 28, 2018 Author Report Share Posted May 28, 2018 No sadly its only a deluxe, not a st 1 Quote Link to comment
ClumsyBird Posted July 20, 2018 Author Report Share Posted July 20, 2018 (edited) Clock time baby https://klamath.craigslist.org/pts/d/1983-datsun-nissan-king-cab/6648081299.html Edited July 20, 2018 by ClumsyBird 1 Quote Link to comment
DrvnDrvr Posted July 20, 2018 Report Share Posted July 20, 2018 It has a/c, rear slider window and a nice rear bumper as well. 2 Quote Link to comment
captain720 Posted July 20, 2018 Report Share Posted July 20, 2018 You will get some really good parts of that for certain 1 Quote Link to comment
ClumsyBird Posted July 20, 2018 Author Report Share Posted July 20, 2018 (edited) As well as that center console, I've never seen one before. As for the AC is there anything else I should pull besides the obvious Edited July 22, 2018 by ClumsyBird Quote Link to comment
DrvnDrvr Posted July 20, 2018 Report Share Posted July 20, 2018 (edited) There is a mounting bracket that goes between the engine and compressor. It has a tensioner pulley on it. Accumalators, expansion valves, evaporators and compressors are available on ebay. there is a idle stepup solenoid on factory hitachi carbs that could be useful as well as the a/c switch on the climate control. there is that cool underhood light by the brake booster. Edited July 20, 2018 by DrvnDrvr Quote Link to comment
ClumsyBird Posted July 29, 2018 Author Report Share Posted July 29, 2018 (edited) Finally a clock! I also was able to snag a whole AC system (besides tensioner), another power steering system (besides gearbox), All the extra ST interior pieces, Nissan mud flaps, arm rests, front and rear bumber, center console and a whole bunch of other small stuff. He basically let me loot the truck for 60 bucks Edited July 29, 2018 by ClumsyBird 1 Quote Link to comment
datzenmike Posted July 29, 2018 Report Share Posted July 29, 2018 Did the ST come with the adjustable pulse delay wiper amplifier? 1 Quote Link to comment
ClumsyBird Posted July 29, 2018 Author Report Share Posted July 29, 2018 I could not tell, I looked but decided against pulling it off. I'm not sure if that truck was an ST 1 Quote Link to comment
datzenmike Posted July 29, 2018 Report Share Posted July 29, 2018 I figured the ST was loaded with option packages. Some things like the variable delay are not an option on some trucks. You would need the headlamp and wiper switch although the wiper part might simply bolt into the place of the old wiper switch. You also need the amplifier beside the steering column over the gas pedal. Last is a wire for the variable resistor. It's a really cool option because the regular wiper switch only has a built in delay that wipes too often or not often enough. 1 Quote Link to comment
