Kenmataya
411 thermostat
Hello all!
1967 411 1.3L.  got a sticky thermostat - looking for a replacement.  everything I find is listed as compatible with th 1.6L....  is it the same?  if not, does anyone have a part number for the J13 motor?
Thanks,
Ken
Share this post
Link to post
OK, 1.6L is the same as the 1.3L, found the thermostat and gasket.  now, i can't find the o-ring!
Thanks,
Ken
Share this post
Link to post
If you mean gasket, Chrysler corporate thermostat gaskets have the proper holes and side width to seal.  Universal gaskets are to thin to properly seal Datsun thermostat housings.
Share this post
Link to post
What happens is previous owners neglect the proper coolant antifreeze mix that also neutralizes and prevents corrosion. The thermostat housing and the thermostat cover tends to become pitted. I've fixed a few by passing it back and forth over sandpaper on a smooth surface. In bad cases a double gasket will work. I've never used RTV. It makes your L series look like a Chev engine.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
