Sign in to follow this
erniestr8mingin
Datsun 620 Rheostat Alternatives
So my dimmer in my '75 620 has been fried due to a ground issue, and I am looking for alternatives. I can't seem to find another. Will another dimmer from another Datsun with a 2-pin dimmer work? If anyone replying to this thread has a spare that would be willing to let go of, that would be great as well.
Thanks!!
Share this post
Link to post
I find that once I set the dimmer on a new car I never readjust it.
Share this post
Link to post
All (I think) are three wire.  The same dimmer is used on the '70s cars also. Earlier are rheostats, around mid '70s they changed to a much slimmer solid state that doesn't heat up.
Share this post
Link to post
Yeah, if only $15 get it.
Ahh I see that the 620 used a 2 wire until '78 when it went to a 3 wire solid state. Don't know if the two can be used for the same thing, but I expect so with some wiring. The two wire just add resistance (which will have to dissipate some lost heat) the solid state is more compact and transistorized.
3 wires. One is ground. One goes to power. One goes to all lamps on the ground side.The other side of all lamps go to power.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
