"Swamp thing" JBC 510 racecar
Icehouse
Finally, Turbo Tuesday again - this time featuring special guest : Redeye!
large.5a9709113981f_02272018turbotuesday
He was determined to cover up some of that pink firewall
large.5a9709153c7d9_02272018turbotuesday
Jeff was playing with spaghetti again
large.5a9709172acc8_02272018turbotuesday
Sam was running brake lines
large.5a97091aa096b_02272018turbotuesday
Paul was ???
large.5a97091cdcd44_02272018turbotuesday
I was under the car painting POR15 - again...
Time to install the wiring harness.
large.5a970924809f8_02272018turbotuesday
Look at that!  Look at it.  Just look at it!!!
large.5a970928d9289_02272018turbotuesday
large.5a97092ba09c1_02272018turbotuesday
We mated Jeff's R180LSD to Sam's reconditioned trailing arms to my new crossmember
large.5a97092697855_02272018turbotuesday
Half shafts would not bolt into the diff.  Uh oh...  Jeff remembered you have to ditch the dust boots.
large.5a97092d8b396_02272018turbotuesday
Ready to install
large.5a97092fce28b_02272018turbotuesday
Is the car half full or half empty?
large.5a970931a576d_02272018turbotuesday
Jeff says he suddenly likes the big hole in the floor
large.5a9709345b5fc_02272018turbotuesday
Up close and personal
large.5a970936ab66b_02272018turbotuesday
  • Replies 849
We spent a few minutes updating the to do list...
large.5a97091fc3628_02272018turbotuesday
At least 40 hours of work for the three of us (less when we have four).  80 to be safe/realistic.  That's 20 evenings.  Not looking like enough time for the April race but we'll see what happens...
Nice finally putting some faces to screen names/vehicles. :)
Got only a few pics.
I have a question.
When you plumbed the engine bay brake lines, why didn't you delete the brake-fault idiot light switch?
Judging by the overall project, the parts were already there, free and easily plumbed in.
I imagine if the car is fun enough everything will get upgraded as time and $ allow.
Haha chrome paint for the win!!  :)
Speaking of painting things.  Carter decided to do some face painting.  He realized how youthful the POR15 was making our racecar looked so he decided to try some out.
It worked!!!
My goal this week has been to improve our front sump oil pan.  We don't want to oil starve during our 7 hour race.  Here is some progress pics.  Must get it done by tuesday!!!
aansHqv.jpg?1
  • Like 6
Another Turbo Tuesday in the books.
Jeff spent the night finishing the oil pan and pick up.  He can tell you more about that.
Sam spent the night working on the mounting scheme for the drivers seat and lowered floor.
large.5aa0a3be3fe9b_03062018swampthing(2
I spent the night in the trunk - literally.  Time to close off that giant gaping hole of a missing tire well...
Started by making a cardboard mock-up
large.5aa0a3bc0169c_03062018swampthing(1
Cut, deburred, and test fitted the sheet
large.5aa0a3c25a9b2_03062018swampthing(3
Coated back side of sheet and top side of trunk with "weld through primer" and skip welded the perimeter
large.5aa0a3c59ce23_03062018swampthing(4
It's not pretty.  Lots of snap-crackle-pop with the paint in place.
I ground those welds down, went around the perimeter with a wire wheel and then filled in the gaps with nicer welds after a little example/instruction from Jeff.  Much better.  Now ready for seal and paint.
Jeff was leak testing the oil pan in the kitchen sink when I left.  That engine can't wait to get back in the car!
large.5aa0a3c89d99d_03062018swampthing(5
large.5aa0a3cadedde_03062018swampthing(6
Seems like we are making forward progress.....  40 something days...  the weekend before the race there is an autoX we gotta make it to that!
Carter welding more.
Sam figuring out how to fit the seat.
My boy helping me clean the inside of the oil pan.  He loves activities that include water.
Motor is back in!!!!!!
mmmhhhh rack and pinion!!!!
Looking good so far if I don't say so!
The boss says we have to put in extra hours now.
Here are some pics from Thursday night.
Looks brand new from this end
large.5aa2e1f12877c_03082018swampthing(1
Fiddly dial racecar thingys
large.5aa2e1f445eb4_03082018swampthing(2
Note - remember to paint base of steering column
large.5aa2e1f55eae1_03082018swampthing(3
Got this from Bruce years ago when he was a Zero Rust rep.  Thought it was funny that the lid was rusty.
large.5aa2e1f75d6d3_03082018swampthing(4
After all these years though it mixed right up and went on nice and smooth.  A little thicker than POR15.  I like it.
large.5aa2e1f9a2025_03082018swampthing(5
large.5aa2e1fb404fc_03082018swampthing(6
Sam's fitting the new fwd roll hoop.  Thanks again Steve!
large.5aa2e1fdc632a_03082018swampthing(7
Jeff's bleeding the clutch.  (can't believe he didn't use Coke!)
large.5aa2e1ff750fb_03082018swampthing(8
We have one pedal now.  Only two to go!
Added a bung for the fan switch.  For some reason the original one has a step, the new ones don't.  Hopefully it does't leak!
Welded on some mounts for the fan.  I don't care for the zip ties that go through the rad core.
Rad requires spacers....
Of coarse now the rad hits the alternator :(   We moved the motor back about 1/2" after this photo was taken.
Fan worked out though!
We better hurry up!!
Sure did! thanks again for bending it. We ended up fitting it differently than originally planned. We were going to have it rotated forward toward the top of the window frame but, we realized if we moved it back a tad we could have it fit about an inch higher by recessing it up to the roof skin. This translated to more head clearance and therefore being able to mount our seat higher.
Looks like you got that front bar welded in.
Interior looks good in white. :D
  • Icehouse changed the title to "Swamp thing" JBC 510 racecar
