carterb Posted June 11, 2022 Report Share Posted June 11, 2022 On 6/8/2022 at 10:52 AM, docbainey said: ISR Performance 70mm Long Wheel Stud for Nissan 240sx - Enjuku Racing Parts, LLC Purchased! Thank you. --carter Quote Link to comment
carterb Posted June 11, 2022 Report Share Posted June 11, 2022 Here are some more various pics from the weekend Wolfman gettin' jiggy with it on Friday The whole team! Weather when Paul was driving https://datsun510.com/uploads/monthly_2022_06/1187315308_06032022swampthing(11).MOV.8eba0bfa7808a2a16fa2fb35f9cbf4b0.MOV Weather when I was driving https://datsun510.com/uploads/monthly_2022_06/1627314968_06032022swampthing(12).MOV.128a5703c5f5340c1e6ae14fb93f79dc.MOV 🤣 Raceday! Aftermath - Paul making exhaust repairs Me trying to get max adjustment out of trailing arm Toe plates didn't lie. Day over. 😥 I need to look for the Luckydog photos from the race. They had two photographers there for the weekend. 1 Quote Link to comment
carterb Posted June 17, 2022 Report Share Posted June 17, 2022 Back to working on the car. First task - determine just how deep the damage goes... I stripped the back end in preparation for hammer or sawzall work while Jeff and Paul worked on removing the left rear trailing arm. From the top, we could see what looked like a stress/bend mark where the arm meets the hub carrier. (see the cracked paint). A square put on the stub axle flange shows the back of the arm is NOT parallel to the axle centerline. I brought a replacement arm and Jeff grabbed one from his shed. Both showed that cut nice and parallel. We have the culprit! We stripped down the bent arm and rebuilt a replacement Fresh bearings Mounted and ready for a wheel and alignment check. The alignment was almost perfect. This proves that the damage was *at least mostly* limited to the trailing arm. We still can't figure out how this happened without bending the wheel. Still in perfect balance even! Next we spent a little time with some hammers (Jeff says size DOES matter) and coaxed the back end of the car back into shape. *A* shape, anyway... This work did pull the right rear quarter back into alignment within 1/4", but it also showed us that the left rear quarter, trunk floor, and tail light panel are all but beyond repair. Next step is to proceed with replacement. So nice knowing though that we could go racing tomorrow if we wanted! I feel like we dodged a bullet. If only the Miata had dodged our car... 2 Quote Link to comment
iceman510 Posted June 17, 2022 Report Share Posted June 17, 2022 It is interesting the wheel was fine. Chassis design engineers for OEMs that I have worked with view the wheel as sacrificial to save suspension components (generally considered the more catastrophic failure). This impact is quite different than than a pothole or curb hit though. That is the input force they usually plan for. Quote Link to comment
Trophy24 Posted July 5, 2022 Report Share Posted July 5, 2022 Work has been progressing on the car. The next race weekend being our deadline for having it put back together like it never happened... Better get busy! Here is where we started for the night. The bashing back into shape really helped us see what needed to be cut off the car. A sad thing to behold Jeff and I got started with the demo phase of things. Cut and grind things away until we could see how deep things went. Jeff thought it might look good as a hatch back at this point lol Side view now. Getting deeper here so we can plan how to seam the replacement quarter panel into place. Is this thing a 2 door or a 3 door? The pile of bent metal kept getting bigger. It would have been a big weight savings if we didn't have to replace it all Here is Sparky (Jeff) cutting away what's left of the awesome mini tub he fabricated right before the race. Sorry buddy! Here is the replacement quarter panel getting some prep before we weld it into place. A bit rusty, but it has enough good material to use here. Looks like the wheel area has already been enlarged for us. The cut out will get even bigger when we are done. Speaking of larger wheel openings... We were getting tired of all the noise cutting off parts of the car so we decided to do something fun as a break. Jeff wanted to go with a larger tire size for better traction. 245 width should fit right? Installed one on the non damaged side to check. Yes sir it does with room to spare. Yay mini tub! They look pretty beefy on the car we think. 2 Quote Link to comment
slowlearner Posted July 5, 2022 Report Share Posted July 5, 2022 I wish I had half the talent you guys have. Good on you for saving it. Actually, a buddy of mine who used to rally them told me the bum would always fall off 510 shells. I asked, "why didn't you just cut it off? It serves no useful purpose." He looked appalled for some reason. 🤔 1 Quote Link to comment
carterb Posted July 15, 2022 Report Share Posted July 15, 2022 More uppy dates from the last week and a half... I had a trunk floor to donate to the cause. First thing - remove spare tire well: Not required for racing! (plus it interferes with the meth lab) After much cutting and fitting Starting to look race-car shape! Jeff was working on the 1/4 panel rust repair while I continued rear end prep (cue proctology jokes) Trunk floor repair complete! Jeff and Paul finished fitting the tail pan while I got dinner All this and we've crossed almost nothing off the list! We put a dot next to the items that MUST be done before ORP (in two weeks) "REPAIR CRASH DAMAGE" almost done... I worked on the mangled fender flare for a while and finally got it back to a shape resembling the right side. Body is marked out for metal removal. Paul almost completed the "REPLACE BELTS" and the window net is next. Pink returns! And we get 2 1/2 years of racing this time! 2 Quote Link to comment
WAGON JON Posted July 15, 2022 Report Share Posted July 15, 2022 Man, great fix! Keep it going!! Quote Link to comment
carterb Posted August 6, 2022 Report Share Posted August 6, 2022 Covid strikes again! 😥 No work on the car for three weeks and we had to cancel our trip to ORP. So now we begin again - The Ridge is next on the calendar - 2nd weekend in September. Gotta get this thing finished then! I worked on trimming the left rear quarter while Jeff did some more cleaning/grinding/paint prep in the trunk. Then we made an executive decision... We are going to paint the car! So while Jeff finished the inner fender well, I removed the stickers. One last patch panel... Next time we sand 'till our arms fall off! Time to pick a paint scheme... 5 Quote Link to comment
Aaron Datsun Posted August 6, 2022 Report Share Posted August 6, 2022 Great work you guys. It's a great reminder to those of us that dream of racing there are some real consequences to doing that. Glad you all weren't hurt and you have been able to get the car back into racing shape. Excited to see the new color scheme Quote Link to comment
Stoffregen Motorsports Posted August 6, 2022 Report Share Posted August 6, 2022 I just found this thread after five years. Awesome! Quote Link to comment
Stoffregen Motorsports Posted August 6, 2022 Report Share Posted August 6, 2022 On 5/14/2022 at 11:09 AM, carterb said: Made a CAD model of one of the clutch disks in case we need to have some made - if we can't locate any new. Optical comparator was very helpful... The tooth geometry was a little complicated though - not sure I have it exactly right. I'll print one out to compare. Anyone know the exact material of these (or similar) clutches? I measured the hardness at RC45-46. It looks like heat treated 4130/4140 would get us there spec-wise. Have you figured out how to increase the clutch pressure yet? There are a few tricks. Also, are you measuring the pressure? If not, I can tell you how. Quote Link to comment
carterb Posted August 11, 2022 Report Share Posted August 11, 2022 Another step taken towards paint. We are committed now! We stripped the exterior and started sanding and masking. Stay tuned! 1 Quote Link to comment
carterb Posted August 11, 2022 Report Share Posted August 11, 2022 On 8/6/2022 at 9:13 AM, Stoffregen Motorsports said: Have you figured out how to increase the clutch pressure yet? There are a few tricks. Also, are you measuring the pressure? If not, I can tell you how. We were planning to use shims. We weren't measuring pressure - just breakaway torque. 1 Quote Link to comment
Icehouse Posted August 11, 2022 Author Report Share Posted August 11, 2022 On 8/6/2022 at 9:13 AM, Stoffregen Motorsports said: Have you figured out how to increase the clutch pressure yet? There are a few tricks. Also, are you measuring the pressure? If not, I can tell you how. We want to slap in the extra SR 6 speed I have. That will make the current 3.9 gears much much lower. Then it will be in a range we can actually tune the gearing. Quote Link to comment
Stoffregen Motorsports Posted August 11, 2022 Report Share Posted August 11, 2022 1 hour ago, carterb said: We were planning to use shims. We weren't measuring pressure - just breakaway torque. There is another trick. Two actually. Quote Link to comment
DARIN 510 Posted August 13, 2022 Report Share Posted August 13, 2022 Great work guys ! But couldn’t you have used aftermarket panels instead of nice original ones ? Maybe send that spare tire carrier to Klassic Fab? Panels are drying up and more 510s are being pulled from the swamps. Just my thoughts. Keep up the good work Quote Link to comment
Trophy24 Posted August 13, 2022 Report Share Posted August 13, 2022 Don’t worry about us using “nice original” panels. These were sorted out as “good enough for the race car” quality. Quote Link to comment
carterb Posted August 14, 2022 Report Share Posted August 14, 2022 "race car quality" - very much so. We had to replace the bottom of that quarter and there was barely enough metal that wasn't rusted through on rear to even weld the tail light panel to. : ) We would LOVE to be using reproduction panels but if I haven't mentioned it previously, even budget racing is expen$ive! We try to save money where we can because there are so many places where we cant. Friday night was sanding night! Thought the dust made for some cool highlights... I love the shot below! Next step - BONDO! 3 Quote Link to comment
carterb Posted August 18, 2022 Report Share Posted August 18, 2022 (edited) Bondo done - so are our arms... High-build done - so are we - time for bed! Edited August 18, 2022 by carterb 2 Quote Link to comment
iceman510 Posted August 18, 2022 Report Share Posted August 18, 2022 It's gonna be so purdy. No more axy-dents! Quote Link to comment
Icehouse Posted August 18, 2022 Author Report Share Posted August 18, 2022 The guys getting some painting done! Sneak peak at the new color! 3 Quote Link to comment
RyanC Posted August 19, 2022 Report Share Posted August 19, 2022 LOVE IT. Going to look very sleek in blue. Quote Link to comment
iceman510 Posted August 19, 2022 Report Share Posted August 19, 2022 I like it a lot too. I'm a fan of blues, but not too light. This would be a great color for my 620 some day. What's it from? Quote Link to comment
carterb Posted August 19, 2022 Report Share Posted August 19, 2022 3 hours ago, iceman510 said: What's it from? From the color chip. 🤷♂️ 😊 We looked through hundreds of automotive manufacturer specific paint chips and they are ALL metallic. It was difficult to even find just plain colors. This chip was from a paint manufacturer generic chip set - kind of like what you see for house paints. You should have seen us trying to find white. There are 1,000 "whites" in those chips and none of them are white. We also wanted "pink". Forget about it! Quote Link to comment
