Apollo77
Z20 build
I have had an '80 and an '81 200sx. Sold or gave away the piston/rods long ago. They were the 6" or 152.5mm long rods.
Only the California emissions equipped 200sx got the 8 plug head in '80. For '81, all engines were 8 plug. In Canada they were all 4 plug till the engine changed to the Z22E in '82.
Share this post
Link to post
The more I talk to people that know about engines the more I am thinking that building mine was a waste of time.
It is sounding like I will not have any more power than an L20b, but I really don't have much money into the engine, just time.
The machinist wasn't really impressed about it being a longrod block when I talked to him, he said the race guys build a chassis, then they put the largest block that will fit into the chassis, then they put the guts into the block that will give them the most power, basically I walked away with the age old saying, "there is no substitute for displacement", more CCs mean more power, all I really have is a Z20b.
Share this post
Link to post
A long rod may move the torque range around a bit but really? it doesn't mean much. Long rods allow the piston to decelerate approaching TDC and accelerate away faster but travel past TDC more slowly taking some of the stress off the parts. A slower moving piston right after TDC might capture more of the expanding pressure of the burning fuel/air when it's at it's highest. But this is no real gain for the average guy who expects it to be 'faster' or 'more powerful'. It might be worth more than a few hp if you raced.
With an L head you do have built in compression increase. The fuel burns faster and the explosion more intense. For every point of compression increase maybe 5% more power extracted form the fuel.
Share this post
Link to post
With that thinking my 10.9 compression ratio LZ20 with flat top pistons should have 10 percent more power than my 8.9 compression ratio L20b block had with dished pistons and the same head, but I have a feeling it is not going to turn out that way.
Share this post
Link to post
Long rods are less prone to vibration.
Vs. an L20B? Minimal, I'd bet. But it is still what it is.
Higher comp, even if slightly, is still more efficient. Except you may be using a fractional amount more of gasoline.
Share this post
Link to post
Higher compression extracts more usable work from the stronger 'explosion' of the fuel air as it burns. Peak cylinder pressures are much higher and push down on the piston more. But you have to be on the ragged  edge of pre ignition. Gas is gas... but higher octane allows you to compress it more without it self igniting. That 5% is considered as being 'on a good day' and under ideal conditions. As you get closer and closer to perfect that 5% becomes 4% and then 3% and so on.
Long rods also reduce frictional side loading on the piston. All these are small but actual gains that added together total significant amounts..... for a race engine, where any advantage can get you into the winner's circle. For a street engine? it's hard to justify for a 5% gain you can barely feel on the ass dyno. You know it's there but it doesn't show like bolting on SUs.
Share this post
Link to post
Why install a modern stereo when my original AM radio works fine?
Why upgrade to modern radials tires when the old bias ply tires still hold air?
If long rods are only good for racing engines, then why did Nissan make the switch in the 80's?
Share this post
Link to post
I'm not aware they did but it was likely pollution related to lower emissions than the blinding amounts of horse power released. In the same decade they had to switch over to EFI and crank angle sensors to refine the combustion process even more. Next would be better economy through reduced friction. Remember these were car and truck engines used for town and highway driving not driven much above 3-4 K. Actual power gains, if any, would be very small.
As the Z20 and the L20B block and crank shaft are identical it would be interesting to see a Z20 long rod compared to an L20B with flattops using the same head and cam.
Share this post
Link to post
I for a fact will be able to tell if it is different, but different than what it was before when it was on the L20b block, not sure as it has an RV cam in it, and the cam was likely timed wrong, that fact alone throws a wrench in the gears, when I removed the head I now have on the LZ20 and then I put a 219 head on it, it didn't seem like there was that much difference, then I went out later after I seen them photos of a properly timed cam and timed the cam properly, it did have more power, but the engine might have had more power with the head/cam that was on it before if the cam had been timed properly.
I did this LZ20 because I thought the longrod/RV cam might be a good combo/revver, when the issue likely was the cam being timed wrong.
What I planned to do was start the engine in my future work truck frame/chassis using this engine to sort out the motor mounts, ect. to get it ready for the LZ23, but it appears that I will need to drive the LZ20 to know anything, that will slow things down and make them harder, I planned on dropping the cab onto the chassis while the engine/transmission were in place, now I will have to remove the LZ20 engine to put in the LZ23 that it has in it now as I need the grunt/torque it has.
This LZ20 was just a build for fun engine to see what would happen as I had every part needed for the most part already, even the headgasket.
Share this post
Link to post
Wayne, you have a great recipe, but like any recipe if you don't follow through with ALL the ingredients, its not going too turn out well.  This is one that won't work if you put a stock worn distributor in it.  A heavy stock flywheel also won't allow it to perform as it should.  Shave that flywheel down to 16 lbs and have it balanced.  Then you need a distributor set up to run at 14-16 degrees BTDC at idle with an advance curve that won't ping like crazy at 2700 rpm.  Unshroud the valves in the head so they can breathe clear out to the cylinder walls.  Remove anything remotely close to a sharp edge on the valves, in the chamber, and lightly bevel the edge of the bore.  Make the edge/head of the exhaust valve round.  Then time the cam to 107/108 Intake CL and you'll have a strong puller without needing race fuel.  You will likely need premium or at least non-oxy real fuel.
Share this post
Link to post
You're not aware they did? The Z20 came with long rods, proof that even the economy minded, middle of the road, pencil pushing engineers thought it was a good idea.
Long rods themselves are not the answer for every engine, but when taken in context of rod to stroke ratio, sometimes longer results in better cylinder filling and more horsepower, and, as you say, better economy.
I've said it before, but I guess I'll say it again, long rods in most L motors make more horsepower across a broader RPM range than otherwise identical engines. It's the flattening out of the curve that makes them worth it.
And this term "race engine". What does that mean? I bet a third of the guys here on Ratsun have what you might call a race engine in their street cars. The 2200 in my last 510 street car made more than double the original horsepower, and almost triple what the 510 came with, but that didn't make it a race engine. It was very well mannered around town and ran well on pump gas.
Share this post
Link to post
The head on it has less than a couple thousand miles on it, the block has unknown miles but I listened to it run in a shop, it sounded alright as a Z20 with a carb, the guy had nice cars in that shop, one was a 1970ish GT 6 cylinder Triumph as I recall.
I am just going to see if it will run, I will be out some gaskets and time, the rest was just sitting around here taking up space, now it is all in one spot as the engine is fully assembled and has been for a few weeks now.
I didn't understand half of what you said above, I believe that having the distributor advance less than stock is likely a good idea, but how to do that is rocket science to me, likely it has something to do with stronger springs(a guess), I will not lighten a flywheel unless I know it is going to work, then I might spend money on that.
As for the un-shrouding of things, well that's more rocket science to me, it has the stock valves with hardened seats, it has a brand new RV cam in it, my machinist told me not to do it, but I thought it might breath better, he was right, I lost torque which I needed, so I had him rebuild my first super head(big valves/stock cam/port matched to SU manifold) and I put together my first LZ23, this head stayed on the L20b engine and that was installed in my 520 ute project, didn't like the cam in that either, so I had the shop rebuild the 219 head I had and I installed that on the L20b, it then was slightly better off the line, but then DMike posted that photo of a properly timed cam, so I went out and re-timed that cam and the engine has more power now, and it drives better all around, I also re-timed the cam on the work truck, it has slightly more power, but it uses WAY LESS GAS, that is what I have noticed the most, way better mileage.
When you start throwing numbers at me about cam timing, well that is French to me, I don't speak French, if I can get it to run at all I then will start changing things, if it will run and move the vehicle down the block and back, I will then think about doing more to it, I have no idea what timing the cam to 107/108 intake CL is.
This is the engine.
Share this post
Link to post
Nissan switched? or they tried a few?
Because the Z24 and the KA series has the same rod/stroke ratio of the old L18.
The L20B is 1.7 and the 'long rod' Z20E (same crank shaft) is 1.77.... hardly anything to write home about.
The 'long rod' Z22E rod/stroke ratio is lower than the much much older L18. It only 'looks' like a longer rod, but they used the L20B rod first when they should have gone with the longer to begin with. All they did was put the correct length rod on it.
Only the L16 has a rod/stroke of 1.8 with the Z20 and L20B next closest.
Everyone says that long rod stroke ratios make more top end power but fail to say how much. This is probably true of 'racing engines' that are quite modified and at high RPMs but Nissan does not build them for that. They build car and truck engines that run around 3K. Just how much extra does a long rod engine make at these levels 3 HP?
A third of Ratsun members have 'race engines'? If you mean a Weber and a closed chamber head, then yes. Far and away the majority of members have close to stock engines, they run the best. If there are 'race engines' out there (other than a swap) it's more like 3% (we have, and have had, lots of members)
Share this post
Link to post
I'm not going to win this argument.
I won't claim that long rods are the answer to world hunger, but when building an engine package that dots all the i's and crosses all the t's, everything needs to be addressed. A Ford exec famously said about the K-code 289, something to the effect that these are for people who want no stone left un-turned in the hunt for power.
Don't knock it til you've tried it. More importantly, don't discourage others.
Share this post
Link to post
This mod is probably the most important to ensure a long engine life. It's very easily accomplished by shortening the slots in the distributor cam so the mechanical advance is limited. You can weld the holes a tiny bit and file them smooth to get the proper total advance.
Springs should not be the only thing that limits total advance.
I don't know what Jeff charges to go through a distributor, but I bet it wouldn't cost more than a hundred bucks to get the advance limited.  If you can find a SSS distributor cam, that's a bolt in operation. When I was at Rebello, we charged about $150 for a full distributor recurve and rebuild.
Share this post
Link to post
Share this post
Link to post
Not discouraging anyone. Want to know if this theoretical gain is worth chasing for a few HP. Racing engine builders do some crazy stuff for a few HP that most would easily say is 'not worth the trouble'. If you look up the rod/stroke controversy it's certainly unclear. They say anywhere between 1.5 and 1.8 is fine. The pros have lots of esoteric theory but not much fact about it. So we're back to 'racing engine' vs what most people build. In the real world if you were rebuilding your L20B with a Weber, an L16 exhaust, a ported closed chamber head and a mild cam head just how much gain would you see by finding 6" rods and pistons from a 200sx? I'm guessing not much unless you go multiple carbs, header, cam bla bla bla and turn it up above 7K. So in a way I would be discouraging some from the bother and expense if the end does not justify it. I'm not building a 'racing engine' just to take advantage of a longer rod is all.
Share this post
Link to post
When you have less than 90hp to start...only a few extra hp is a huge gain.
Anything that helps the dick swell, amiright?
Share this post
Link to post
Mila Kunis makes everything alright. Thanks Mike.
If you think they might not be worth the trouble, consider the trouble. At the worst, you're looking into a set of custom pistons. A lot of guys do that anyway as OEM's or good aftermarket pistons become hard to source. It boils down to pennies when taking into account the whole engine package. A good set of aftermarket pistons will cost you $200 to $300. A custom off-the-shelf piston (which is the case for long rod L4 pistons, since so many engine builders have paved the way with their own R&D, and many piston MFG's have those designs on hand) will run about $400 to $500 for the set. For the extra $250, it's worth it. As I said multiple times in the past, it smooths out the power curve, so your actual gains are not unsubstantial (double negative).
A set of used N85 rods (making a long rod L20B, Z20, 2200, 2300, etc) can be had for pennies if you score at the wrecking yard.
Flatcat said it better than I would have, any swelling of the dick is a good thing. Amiright, amiright or amiright?
Share this post
Link to post
I could likely do something like this, and then test it on one of my drivers engines till I got the advance where I wanted it, i will have to go back thru all these posts to find out what the total advance should be as I think I read that somewhere.
I expect it would be better guess rather than do nothing at all, I can always pull it apart and weld more or file what I did down till I get it where I need it.
Share this post
Link to post
Your total ignition should be about 32 degrees. Initial about 12 degrees. I simply remove one of the springs that hold the centrifugal weights, but then you have to make sure there is enough tension on the one that's left so the distributor cam doesn't flutter at low engine speeds (When the centrifugal force is low).
Doing it the way you described is totally fine, a little bit at a time, but if you wanted to get it right the first time, simply print out a paper degree wheel from something you find online. Slip it over the distributor cam and move the mechanical advance then look at the paper degree wheel to check how much movement you get. Should be about 20-25 degrees of travel. Maybe less.
Share this post
Link to post
OK, so how I seen it in my head was welding the end of some slots(never had one apart), but then you say to just remove a spring which at first totally confused me, then I realized that if one was already out then the other one would only let it advance half as much, is this correct?
Is there a way to either tack weld it or a way to make the one without a spring solid where it cannot move at all maybe half way out so the balance is not as messed up?
Is the balance more important at low or high RPMs in this situation, in my head I see it being balanced at high RPMs as better as I suspect it spends most of its time there anyway.
Are all Nissan distributors basically the same, I have a couple junk distributors I don't care about I could pull apart, also is the napZ distributor the same as the Matchbox or is it advanced electronically by the ECU?
Share this post
Link to post
No. The way it's laid out inside, there is a distributor cam, which has two wings on the bottom. Each wing has a slot to guide the pin connected to the two weights (one weight per one slot). Then there are two springs, one connected to each weight. The springs don't limit the travel, they set the speed at which the travel occurs, so if you remove one spring, the advance happens more quickly.
The reason there are two springs is to allow the timing to creep up on total advance instead of having it come in early. This was undoubtedly a way to control emissions. The balance, as you call it, from the factory does not take full advantage of the engine's desire to have more timing at lower RPM's. It's too limiting, or stiff.
I suggest you take one apart and have a peek for yourself. All you need to do is remove a breaker plate and have a look. Once you see for yourself, it will make sense.
I forgot you had a matchbox distributor, and I can't remember ever using one, so I'm just guessing that the mechanicals inside are the same.
Share this post
Link to post
The Z series NAPS have vacuum and mechanical advance identical to the L series. Only the later '86 Z24i got the CAS.
Above this is the magnetic rotor and single piece dual output module.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
