INDY510 3,126 Posted December 19, 2020 Report Share Posted December 19, 2020 This is how I fixed that spot: I used one piece of cold rolled 16 gauge, instead of overlapping thin metal on top of thicker metal: 1 Quote Link to post
Lockleaf 5,012 Posted December 19, 2020 Report Share Posted December 19, 2020 It's only a flesh wound! 1 Quote Link to post
DARIN 510 38 Posted December 24, 2020 Report Share Posted December 24, 2020 Do you know of kfjdm? https://kfvintagejdm.com/ they are making reproduction panels for 510s. You should check them out Quote Link to post
Aaron Datsun 178 Posted December 27, 2020 Author Report Share Posted December 27, 2020 On 12/19/2020 at 1:06 PM, INDY510 said: This is how I fixed that spot: I used one piece of cold rolled 16 gauge, instead of overlapping thin metal on top of thicker metal: Very similar to the way that I am repairing it. On 12/19/2020 at 5:18 PM, Lockleaf said: It's only a flesh wound! One of many. On 12/24/2020 at 12:44 PM, DARIN 510 said: Do you know of kfjdm? https://kfvintagejdm.com/ they are making reproduction panels for 510s. You should check them out I am pretty much done with panels on this car. I have seen the great work they are doing, it is great to have another source of parts. Most of the parts were purchased from FutoFab before I even picked up this project ( Previous owner had grand plans that didn't work out) I actually only bought the trunk drop panels and rear arches. The fender panels and rockers came with the car. The floor boards were made by a guy that is here on this site. Quote Link to post
Aaron Datsun 178 Posted December 27, 2020 Author Report Share Posted December 27, 2020 Definitely making progress on this thing. I got quite a bit more cut out then my angle grinder died 😞 Quote Link to post
Aaron Datsun 178 Posted January 10 Author Report Share Posted January 10 I am a couple weeks behind I have the passenger's side complete, and now I have moved on to the driver's side! 1 Quote Link to post
Aaron Datsun 178 Posted January 10 Author Report Share Posted January 10 (edited) The front piece is in now, and The car can literally fly in the air*! I cut the metal out, bent it into shape, cut out some plug weld holds and slapped it into place and fused two metal together using the hot stick better known as a MIG welder. *Disclaimer: It cannot literally fly in the air. . Edited January 10 by Aaron Datsun 1 Quote Link to post
