Aaron Datsun Posted August 21, 2018 Author Report Share Posted August 21, 2018 Lots of work on the car in the past week (interior rust repair), not reflected in this post. I did however add ~50 pictures (likely more) to this build thread feel free to click through and see what I have been up to. I need to get back to making detailed notes. I have somewhat stopped since I make a Youtube video of all of the updates it is like having 3 different forms of the information and it gets tiring and distracts from just working on the car. That being said, my videos only get like 100 views, so maybe I should just stick to pictures and words. Any advice on the videos would be helpful Quote Link to comment
The Taterhead Posted August 22, 2018 Report Share Posted August 22, 2018 Well, I enjoy watching the videos. But I also know that it takes a lot of work and time for you to get them done. I can’t speak for anyone else, but I know that at least one of those hundred views is mine. I like the attention to detail and the fact that I can reference your build thread if there something I need to do. Do what you wish as far as the videos are concerned, but I still be keeping an eye on the thread. BTW, where you moving to? Quote Link to comment
Aaron Datsun Posted August 23, 2018 Author Report Share Posted August 23, 2018 Thanks man I do appreciate the kind words Quote Link to comment
Aaron Datsun Posted August 26, 2018 Author Report Share Posted August 26, 2018 Well this happened today. The wife really liked it, the paperwork seemed to be in order. We will take delivery next week if all goes well. I don't have a lot of plans for it other than a very deep clean and a bit of engine cleaning as well. 1 Quote Link to comment
Aaron Datsun Posted September 3, 2018 Author Report Share Posted September 3, 2018 (edited) I also added more text content to the past couple posts because I decided to type out the information that was in my paper garage journal. So if you go are revisiting my thread for the first time in a few months I suggest you go back a couple posts to see the work that has been done. Project Log (12 Aug 18): I have been unsuccessful so far in getting a new stock fan for the car, and like an idiot I pitched the old radiator and fan shroud (I know I am an idiot). Somewhere in the past few weeks i replaced the radiator, but forgot to note the time and date. As I wait to find the fan I decided to replace the driver’s side floorboard and perhaps the rocker panel (as it is completely rusted out in the rear) To Do (Daily): ☑ Remove interior ☑ Start removing sound deadening from drivers floor board 1. The carpet and seats removed easily. I put them in a box to get them out of the way 2. The sound deadening removed with a chisel and a hammer fairly easily Remove the large portions with a hammer first Then use a wirewheel to clean up the last of the remnants if you want my opinion on the best way to do this in an efficient manner Remove the undercoating with a wire wheel CAUTION: You Should always wear eye protection, breathing apparatus, and hearing protection when operating a wire wheel or sander (i have been coughing up some nasty crud, be smarter than me) Note: Looking at the situation it is clear to me that I will have to replace the frame rail as well on the drivers side it has given up the ghost and is not doing its job. Link to Timelapse: -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Project Log (13 Aug 18): Drivers Floorboard removal continues, I have removed ~90% of the drivers floorboard, broke my spot weld drill bit in the first ~5 minutes will have to buy another. I have been using the cut off wheel on the 4.5” angle grinder. I have been attempting to be very careful in how I cut and operate the cut off wheel in these close spaces it would be very easy for me to hurt myself a TON. First Floorboard replacement video: encompasses work through 13 August Edited September 7, 2018 by Aaron Datsun Quote Link to comment
Aaron Datsun Posted September 3, 2018 Author Report Share Posted September 3, 2018 (edited) Project Log (19 Aug 18): Drivers Floorboard rust repair continues, firewall got cut. The frame piece underneath seems solid, just need to sand it down, get the remaining spot welds out, make a new piece. It was a short day today, just was too hot to do much, and we were doing stuff as a family. To Do (Daily): ☑ Cut the chunk of firewall off 1. Cut the firewall piece out of the way so I can fashion the firewall extension piece. The spot welds were a pain in the bum, but it is nice to get the pieces out of the car Notes: I ran out of welding wire on Saturday and didn’t get to Harbor freight before they closed (Sunday) Images: -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Project Log (24 Aug 18): Start Time: 1730 End Time: 2100 Drivers Floorboard rust repair continues To Do (Daily): ☑ Make the firewall extender sheet metal ☑ Finish Welding the frame rail under the seat and to the old rail ☑ Replace the front corner metal on the side (by the outer skin) ☑ Finish welding up small holes from the floorboard patches I made 1. The firewall has metal that extends down under the floorboard. It goes through in about a 90 degree angle. I measure the panel it is ~ 17.5” long and 7” wide. I created the panel with a ~1” overlap with the firewall the purpose is to attach the panel with spot welds, then use seam sealer to ensure I don’t get a bunch of moisture after adding the panel. The floorboard will also overlap this piece and I will use the same process to connect the floorboard to the firewall panel. The panel was created with a harbor freight metal brake, I added two bends to give the panel a more natural curve that I will finish with a hammer and clamps. I wanted to get this whole panel finished tonight, but realized I needed to paint on the rust converter before welding everything together. The piece was originally too long so I had to trim it down a bit I am still using the metal given to me by a buddy I have been making sure to smooth the sides with a snader so I don’t have a ton of jagged edges 2. I am still not a great welder so the frame rail got finished stitch welded together. This was a weld grind weld grind process, but in the end I think it turned out well and is very solid (compared to the old rusted out frame). I finished the spot welds at the back of the frame as well. 3. The panel that is around the door (kick panel?) . The front corner was completely rusted. I cut it out and welded in another piece. I don’t think the repair will last forever, the metal around that area is pretty bad, but this will help keep moisture out of the new panels going into the car. The rocker panel and front fender definitely need replaced, but I will get to those at a later date 4. There were a few small panels that needed the holes finished welding up, I did that today. Notes: 4 ½” wire wheels are very scary to me. I am always afraid it is going to wrap me up One became a needle and flew off and embedded itself in my leg, it hurt I ripped another pair of shorts today. This summer has been rough on my garage clothes I have had most of my pants/shorts the better part of a decade and they are finally giving up the ghost (the wife is not sad) Still not looking forward to changing the rocker panels, hopefully this will be good practice I did a lot of sanding getting the car ready to go back together Edited September 7, 2018 by Aaron Datsun 1 Quote Link to comment
Aaron Datsun Posted September 9, 2018 Author Report Share Posted September 9, 2018 Project Log (1 Sept 18): Start Time: Not Recorded End Time:Not Recorded Tac’d in Firewall and Floorboard today To Do (Daily): ☑ Attached Firewall extender ☑ Tac weld in Floor board 1. I continue to weld in the floorboard, I want to ensure that I get it well secured in the car. I did not have a good way to clamp down the floorboard to the rail I made so the gaps between the rail and the floorboard in a few places is larger than I really want, but it will have to do. I keep burning through the floorboard while welding =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=--=-=-=-=-=-=-=-= Project Log (8 Sept 18): Start Time: 0945 End Time: 1330 Finished the driver’s floorboard welding today, and then moved on to the rocker panel. To Do (Daily): ☑ Finished welding drivers floorboard Removed doors Cleaned up Rocker Panel 1. The drivers floorboard had a bit more welding to do today, I attempted to weld the frame to the floorboard a bit more today, but was largely unsuccessful welding upside down. I tried bending the frame lip to touch the floorboard a little better, but it seemed to warp away when I started welding The floorboard had 5-6 different places where there were still large holes or seams that needed to be welded to each other. I was largely more successful welding today without large burn-throughs or large globs of weld so that is promising. After it was welded up I got out the grinder and ground down the welds. I made sure to put on a breathing mask, eye protection and ear protection so I wouldn’t be coughing up crap for the rest of the day, and could hear what the family says at dinner. 2. I removed the doors to start work on the rocker panels I figure before I start seam sealing and painting I will replace all the metal on this portion of the car (if possible). The doors came off with 5 bolts each. I marked each of the hinge locations so I can hopefully get them close to lining up when I put it all back together 3. Using a wire wheel I started removing the paint on the rocker panel to see the current extent of damage. They aren’t a total loss, but they are very bad so I will be replacing VERY large portions of the rocker panels. .. . 1 Quote Link to comment
Aaron Datsun Posted September 24, 2018 Author Report Share Posted September 24, 2018 (edited) Project Log (8 Sept 18): Start Time: Not Recorded End Time: Not Recorded Finished the driver’s floorboard welding today, and then moved on to the rocker panel. To Do (Daily): ☑ Remove the front fender ☑ Assess the damage to the Rocker Panel 1/2. The front fender had to come off to get to the front of the rocker panel. There are 2 screws and ~8 bolts that hold the fender on. I got about 4 of them to come off without snapping. The rest left half of bolts in them so that is another thing I will have to get out of there. When I took to the rocker panel with the wire wheel it was clear that there was rust throughout the rocker panel and that a patch job likely wouldn’t solve the problem. So a much larger portion of the rocker panel is going to need to be replaced. The rear portion is completely toast. It is so bad that I am now looking up pictures of Datsun 510s on rotisseries to see if I can re-envision what that whole area should look like. Not surprising there was rust around the perimeter. The front of the engine bay will likely need some rust repair. I will likely try and repair the fender myself while I have the fender off. The fender has several rust spots in it that I am going to attempt to fix. Under the fender the front upper frame sections was in good shape. That is good news. I wire wheeled it and put a coat of rust inhibitor on it. Will do another coat tomorrow as well as I was in a hurry and believed I missed some of the surface rust. I also was reminded of another spot of rust I have in the car near the suspension where the crossmember attaches to the frame at the bottom of the fender, will try and fix that rust as well while I have the fender off. September 10th. Removed the 4 bolts that I broke in the fender. Photos: A buddy of mine made these for me. Ohh Yay more rust! Link to Youtube: . . Edited September 24, 2018 by Aaron Datsun 1 Quote Link to comment
Aaron Datsun Posted September 27, 2018 Author Report Share Posted September 27, 2018 Project Log (15 Sept 18): Start Time: Not Recorded End Time: Not Recorded Finished the driver’s floorboard welding today, and then moved on to the rocker panel. To Do (Daily): ☑ Drill out all the spot welds at the bottom of the rocker panel ☑ Cut out the outer rocker panel 1. Removing the spot welds were a pain in the rear to remove, the good news is that I only had to do that until about the rear passengers door as after that the rust was so bad they didn’t exist any more. 2. Looking at the metal I determined that there was enough clean metal on the upper two surfaces for most of the rocker panel are in great shape so I left them. This made me feel comfortable to not add reinforcement today. The piece removed fairly easy, but I did miss several spot welds along the way. The inner sill panel had quite a bit of rot at the rocker panel mounting, so I removed large chunks. Today was really the day that I determined the full extent of the rust in the rocker panel especially around the rear door. Notes: A real fear I have is the car sagging without the support from that area in the car. I wanted to remove small sections one at a time to ensure that I don’t completely wreck my car, but getting access to some of these areas is MUCH easier with certain panels removed, so I am working to do the best of all worlds as I move forward. I ended up making bracing Friday 21 Sept 2018. I made a triangular brace out of square 1” 16 gauge stock. Notes: The order that this needs to happen needs to be thought out in order to give best access to all the different locations. My opinion on the order is: 1. Inner sill 2. Rear Wheel Arch inner (along the inner sill) 3. Floor board 4. Rocker Panel 5. Rear Wheel Arch inner facing rear tire 6. Rear Wheel Arch outer If I repair the rocker panel it is much more difficult to get the floor pan in, the problem is both sides of the car aren’t in that great of shape so I don’t know exactly how it is supposed to look in its final form I have been looking for images for Datsun 510 restorations specifically them on rotisseries as references Pictures [[ Video: . 2 Quote Link to comment
Aaron Datsun Posted October 7, 2018 Author Report Share Posted October 7, 2018 Project Log (16 Sept 18): Start Time: Not Recorded End Time: Not Recorded Finished the driver’s floorboard welding today, and then moved on to the rocker panel. To Do (Daily): ☑ Cut out the front rocker panel holder ☑ Create the Front rocker panel holder panel ☑ Wire wheel the rear wheel arch ☑ Cut out the rear passenger floorboard ☑ Cut Out seat support 1. The front rocker holder is part of the A pillar it has a potion that is spot welded to the front of the rocker panel and a small overlap for the rocker panel as well. It was pretty well rusted out so I decided to cut it off so I could replace it. I attempted to drill out spot welds for the majority of the spot welds, but realized that would be pointless for some of it so I just cut it all out. I have determined it isn’t very difficult 2. I decided to attempt to make this whole section out of one piece of metal. so I made a template out of paper and masking tape. once I had the layout I went ahead and traced it on to my piece of spare metal, cut it out with the cut-off wheel, and used my metal brake to bend a few of the parts then bent the rest by hand and hammer. Once I am satisfied it works well I will be welding the curved pieces into place, but that won’t be until I get the rocker panel test fit into place. 3. The rear wheel arch is going to need to be repaired, the wire wheel told me that a TON of it would need replaced and it will need to be cut out. I wrote yesterday’s notes about the order after knowing this information. It is also the point that drove me to the point of knowing that I will certainly need to add bracing to the car as I need to cut out even more metal 4. When I realized I would need to do more research (which led to bracing, and ordering new parts from futofab) I decided to continue replacing the floorboard. Back out with the chisel and hammer getting rid of the old asphalt type sound deadening so I could determine where the rust ended. This floor board was in better shape than the front towards the middle of the car, but it also extended into the seat riser in the back of the floorboard. These were both cut out and I was able to remake the seat riser portion with my metal brake, and help add a bit of rigidity back to the floor structure at that corner. I also cut out the new floorboard with more overlap so I could easily tac-weld it into the old floorboard. The wire wheel continues to do a fantastic job of getting down to bare metal 5. where the floorboard attaches to the normal floor of the car it was clear there was more rust that extended to the seat brace both upper and lower structure. So I would have to cut that whole portion back. It was about here that I realized I didn’t need to actually make perfect seam welds for all of these panels so I started adding a bit of overlap to all of my panels assuming they won’t be the panels people are looking at when the car is complete Note: as always I have been parking the wife’s Figaro in the garage at the end of the night so I have to ensure I clean and put away my tools daily. Photos https://farm2.staticflickr.com/1908/44877522701_fad9e572c7_k.jpg] . . 1 Quote Link to comment
Aaron Datsun Posted October 15, 2018 Author Report Share Posted October 15, 2018 Rust repair is continuing, videos being taken. Have been kicking around the idea of a fuel injected swap, just thinking not planning. The Ford ecotec engine seems like an amazing newer engine than the KA24DE. I have seen 2 other 510s with the swaps they are amazing and way beyond my skill level. Just so you all know I have the driver's floor boards, rocker panels and rear wheel arch swapped now have to get it all tidied up before putting that side back together. Quote Link to comment
Aaron Datsun Posted October 21, 2018 Author Report Share Posted October 21, 2018 Project Log (17 Sept 18): Test Fit the doors back on the car, then welded in the bottom support brace To Do (Daily): ☑ Put on Doors ☑ Take Off Doors ☑ Put in Door Brace 1. The doors went on very easily. I was able to use a folding chair to help me keep the doors balanced as I placed them back on. I was happy I put the bolts away in a good spot, because this project is taking WAY longer than I originally anticipated. 2. Took the doors back off and put them back over in the corner 3. The bottom horizontal brace is welded to the A, B, and C pillar this will hopefully act to ensure the car does not warp as I keep cutting metal out of it. It required bending the metal to ensure I got the right bow in the metal, I also ended up cutting it long enough to fit in the car, plus a few more inches. I had to angle the rear cut to get it to weld to the inner panel The weld is not great, but I needed to leave the car for a couple days and didn’t want to worry about the sag Project Log (22 Sept 18): Added one more piece to the inner sill To Do (Daily): ☑ Make the new inner sill piece 1. The old seatbelt mount is made up of a large nut welded to an ~14 gauge steel, welded to the inner sill with spot welds. The panel I created was the inner sill. I got to use my metal nibbler for the first time. It works well, and I like it, but you need to make sure your metal is held firm After creating a template with paper, and cutting out the metal my battery died on my camera, but I did not change it. I finished welding in the sill. Video . 2 Quote Link to comment
Aaron Datsun Posted October 28, 2018 Author Report Share Posted October 28, 2018 Project Log (30 Sept 18): Start Time: 1635L End Time:1900L Created the seatbelt bolt mount and filled in holes in the inner sill To Do (Daily): ☑ Clean Inner Sill ☑ Recreate the seat belt mount ☑ Create the inner sill ◻Weld in Floorboards ◻Recreate inner seat brace 1. Using my wire wheel on my angle grinder I got rid of the rest of the surface rust on the front inner sill. Then cleaned up the mess made before starting to work on the seat belt. 2. The old seat belt mount is made up of a large nut welded to an ~14 gauge steel, welded to the inner sill with spot welds. Today i cut out the outer piece and welded it to the outer plate that has the nut on it. I then drilled holes in both so I could plug weld them to the inner sill. I also added a bend to the middle piece of metal like they have on the original car as well. I had to cut the old plate apart with the grinder and smooth it all down prior to welding these parts together. I have a panel of thicker metal (16 or 18 gauge) I cut the new piece out and welded them to each other. 3. I used a brass hammer head as a heat sink and welded in the holes in the front sill. I ended up running out of welding wire and couldn’t find the other rol that I knew I had. Once I welded in as much as I could I sanded the welds down to flush with the panel. . . Quote Link to comment
Aaron Datsun Posted November 10, 2018 Author Report Share Posted November 10, 2018 365 days since I bought her. I still love her, though she has been on jackstands now for over 60 days ? . Though the last 30 days I have not been able to work on the car at all due to work commitments. I have done quite a bit - Repaired the rust in the engine bay. - Repaired some rust in the trunk - Replaced the 15" FWD offset wheels with a stock set of 14" wheels - Replaced both rear wheel brake cylinders - Replaced the Clutch master and slave cylinder - Replaced the brake master cylinder - Swapped in an L20B, with lightened flywheel and new clutch - Upgraded to a Weber Downdraft carb - Aluminum Radiator - 5 Speed transmission - Shortened the driveshaft - Relocated the battery to the trunk, and removed the battery tray - Repaired the fuel filler hose - Repaired driver's side (front and back) floorboards - Replacing Driver's side rocker panel (still in work) - Replairing rear wheel arch rust (still in work) Quote Link to comment
Aaron Datsun Posted November 11, 2018 Author Report Share Posted November 11, 2018 (edited) Project Log (7 Oct 18): Start Time: 2115L End Time:2330L Final inner sill piece added to the car To Do (Daily): ☑ Create the final piece of the inner sill ☑ Weld the Piece on 1. Using paper I created the template for the inner sill. So things to note I needed to follow the upper line up a cure that follows the inner door frame. I also made the piece go down to low, my thought was that I could easily cut it off after I spot welded the rocker panel to it. I got to try out a new tool from Harbor Freight it punches holes and crimps. I like what it did the hole punches are WAY faster than drilling I also used a new tool called a nibbler that cuts the metal using a coordless drill. It worked really well, but the part really needs to be held more secure so it doesn’t try and move around on you. I definitely liked the nibbler 2. Now that I had the piece cut out and the plug weld holes drilled, I had to weld it to the panel I used a new product called Copper Weld that allows a welder to weld around on a product. i coated both sides, I am hoping that this helps keeps the car from rusting in the future The welding process wasn’t to bad so I was glad about that. Once welded I ground down the welds and called it a night Note: I added a bit of extra metal to hopefully add as a fold over. Only time will tell whether that was a good call. Video: . Edited November 11, 2018 by Aaron Datsun 2 Quote Link to comment
Aaron Datsun Posted November 13, 2018 Author Report Share Posted November 13, 2018 (edited) Project Log (7 Oct 18): Start Time: Not Recorded End Time:Not Recorded Welded in the driver’s side rear floorboard. To Do (Daily): ☑ Cleaned up welding surfaces ☑ Prepped Floorboard piece ☑ Weld the floorboard in ☑Cleaned up welds 1. The surfaces were easy enough to clean with the wirewheel on the 4.5” angle grinder. 2. The prep consisted of painting all the welding surfaces with copperweld to retard rust formation in the welded sections. I did two light coats of the copper weld and punched holes for the plug welds in the floorboard When fitting the piece I needed it to be installed with minimal gap I drilled a could holes through my plug welds to allow for some Cleco fasteners that hold the panel in place and used my small hammer to ensure the metal was touching before welding in the panels Something I need to continue to work on is not inducing as much heat into my panels I have the habit of welding a bit to long and getting frustrated with burn through that is clearly my fault The floorboard piece had a small hump added to it via “Hammer Power” to better fit the floorboard that it was being welded to (done in a previous video) 3. Welding the floorboard went fine, I started by welding along the inner sill, when that was complete I move from the inner sill towards the center of the car The center of the car I made the mistake of having no support underneath the car to keep the floorboard level this meant that as I hammered the pieces they bowed downward. I realized this after about 6 plug welds which I had to cut out and do it again I was able to keep the floorboard at the correct level with a 2x4 and a floorjack. and some gentle persuasion (aka Hammer) I then finished welding in the pieces from the top I added some reinforcing welds along the bottom, All of these will need to be seam sealed in the future, but the floorboard is MUCH more sturdy now. 4. Once the floor was welded in I cleaned up the welds with a ~60 grit flap disc on the angle grinder. This makes a huge mess looking back at all of this I wish I would have more completely stripped the interior and put masking around all the stuff I couldn’t/didn’t remove I am writing this now ~1 month after I did this work and will be doing it before I move forward, but did not make this change for the next couple videos. Note: The car is starting to come back together and it is a good feeling stay tuned! Some images are from the last couple days of work as well. Video: . Edited November 13, 2018 by Aaron Datsun 1 Quote Link to comment
Aaron Datsun Posted November 26, 2018 Author Report Share Posted November 26, 2018 (edited) Sorry all, no pictures today! They exist, but I just don't have them uploaded to FLICKR yet Project Log (8 Oct 18): Start Time: Not Recorded End Time: Not Recorded Welded in the driver’s side rocker panel To Do (Daily): ☑ Cleaned up welding surfaces ☑ Cut out the remainder of the rocker panel ☑ Cut the new rocker panel to fit ☑ Spot weld in the new rocker panel 1. The surfaces were easy enough to clean with the wirewheel on the 4.5” angle grinder. 2. I then cut out the last of the rocker panel and rather than drill them out individually it really worked well I made a pretty big mistake and tried to use my angle grinder in a recess, it caught and the grinder got away from me ate up my wrist and left leg. I was definitely an idiot I used a normal cut off wheel and carefully cut through all the parts along the top of the sill, the 60 grit flap disc did a good job of cutting down the spot welds 3. I test fit the rocker several times to ensure that I was cutting the right parts off. I then used a silver sharpie to outline all of the cut off parts and cut them off I had to remove the paint from the rocker panel to have something to weld to I was pretty gun shy for the rest of the day with the angle giver which you can see throughout the video The prep consisted of painting all the welding surfaces with copperweld to retard rust formation in the welded sections. I did two light coats of the copper weld and punched holes for the plug welds in the floorboard 4. WOW Spot welders are AMAZING. I cannot recommend them enough, plug welds are a pain in the butt, and I really enjoyed using this. I lined up the parts and then wrestled the spot welder into place and tacked her in Notes: Getting much closer, but still SO much to do. Some pictures of the process. Video . Edited March 18, 2019 by Aaron Datsun 1 Quote Link to comment
Aaron Datsun Posted December 8, 2018 Author Report Share Posted December 8, 2018 (edited) Project Log (9 Oct 18): Start Time: Not Recorded End Time: Not Recorded Welded in the driver’s side rocker panel. Yes I know that it has been almost two months since I have actually done work. It takes time to make these videos and I worked about 2-3 months worth of hours it seemed in October and November so no time for the car. To Do (Daily): ☑ Continued welding in the rocker panel along the top ☑ Finished spot welding the rocker panel along the bottom 1. The surfaces were easy enough to clean with the wirewheel on the 4.5” angle grinder. I ended up having to drill a small pilot hole along the top to ensure that my plug weld actually attached to the three layers that were sandwhiched there. The front pillar have a weird angle that makes it more difficlt to weld. When I do the other side I will likely try to remove the entire rocker panel rather than cut out portions of it. I think in the long run saving myself time ended up really hurting the time required to do this project. The other thing I will do is move the brace farther up so I can get my spot welder in along the top as well 2. Using a set of vice grips I moved along the bottom of the car and clamped the pieces together, I would used my small hammer to ensure the pieces were very close before using the spot welder. Photos: Video . Edited March 18, 2019 by Aaron Datsun 1 Quote Link to comment
Aaron Datsun Posted December 14, 2018 Author Report Share Posted December 14, 2018 (edited) Project Log (13 Oct 18): Welded in drivers rear wheel arch and did some other clean up work To Do (Daily): ☑ Cut of the old wheel arch ☑ Weld in new wheel arch ☑ Sand down welds ☑Weld in the front rocker cover ☑ Lay some primer down on all the parts 1. To cut off the old wheel arch I first measured to where I wanted to add the new arch by using tape from a specifc point on both the new and rear arch. This I hoped would allow me to cut and weld in the new piece seamlessly, it didn’t work perfectly for sure 2. To weld in the new arch I first tac welded it to the inner surface and rocker panel, then I welded it to the arch itself. The metal was very thin and had surface rust that caused a TON of blow through when I was adding the new part so I ended up with a pretty crappy product that I am going to have to bodo to fix. Some things I think I will do differently next time Cut out the entire arch Cut out the entire rocker panel 3. When I sanded it down it was clear I wasn’t going to get a smooth finish so I just decided then that bondo is going to be how I do it. I am continuing to use the 4.5” angle grinder with the flap disc to do the bulk of the sanding. It has trouble getting into a few of the tight spots, but it sands so quickly 4. I made the front rocker cover a while back, but just finally welded it in place. This piece will be hidden away so I didn’t need it to be perfect, it is also where the captive nut will be for the fender I believe. 5. I just wanted to seal the parts a bit since I knew I wouldn’t be able to really work on the car at all over the next few months. Future Work Fix the front fender Make and Weld in the piece to mount the seats Remove the braces clean and paint the new body parts Clean the wheels (I started this foolishly a while back) Replace the lower rear fender Pictures: Video . Edited March 18, 2019 by Aaron Datsun 1 Quote Link to comment
Aaron Datsun Posted January 4, 2019 Author Report Share Posted January 4, 2019 (edited) The Piece was made very simply by creating a template piece from paper. Once the overall size was determined I was able to cut it out of metal and using a hammer I formed it into the shape it needed to be. I made this out of two separate pieces as I thought it would likely hold on the best that way. I have moved away from keeping copious amounts of notes as I am videoing the entire build and that does a good job of highlighting all the work I have been doing. The gross nasty! Piece bent over and tack'd in! New piece after being bent up and formed with a hammer and 2x4s Tack'd in by a blind guy (sorry if that is not humorous to you) Next piece cut and bent into shape. Sorry I didn't get a photo after welding . Edited March 18, 2019 by Aaron Datsun 3 Quote Link to comment
Aaron Datsun Posted January 26, 2019 Author Report Share Posted January 26, 2019 Not exactly work on my car, but definitely car related, except that I will be using it to film my work in the garage. I built an articulating arm that I can mount my camera onto in the garage I originally envisioned a camera track, but it didn't work very well. This one was my idea, it was not successful, so I reworked it into something usable. It is a long video, but it was very cheap to make, the final build cost much less than $50 and included ~$15 dollars worth of parts. . Quote Link to comment
Aaron Datsun Posted February 12, 2019 Author Report Share Posted February 12, 2019 I finished up the under seat metal reinforcement piece. I am moving forward. I have done some more work past this one, but haven't edited the footage yet. This work was done in January. . 2 Quote Link to comment
Aaron Datsun Posted February 17, 2019 Author Report Share Posted February 17, 2019 (edited) This work was done on 8 Feb. The last rusted panel came out of this section of the car. It was the inner wheel well. Since I had already rebuilt the inner skin on the wheel side it was easy to make. Once again I was grateful to have a spot welder it made the whole process much easier. I used the copper weld to ensure that the welds penetrated well. The piece was a very simple right angle bend that tac'd right into place. The welder is giving me a bit of issue it gets temperamental on the feed, it can get really frustrating because the wire isn't always consistent in its speed. You can also see I removed the door braces. Keeping the movement forward, though slower than I was when I first started this project. Pictures After I grinded it down. . Edited March 18, 2019 by Aaron Datsun 1 Quote Link to comment
Aaron Datsun Posted March 2, 2019 Author Report Share Posted March 2, 2019 (edited) This work was done 11 Feb 2018 I started by cleaning out the car, then I recognized how terrible the welds looked so I ground them down and cleaned up the area. There was only a couple pictures taken of this work. Before After . Edited March 18, 2019 by Aaron Datsun Quote Link to comment
Aaron Datsun Posted March 5, 2019 Author Report Share Posted March 5, 2019 (edited) Alright next video made. A quick update again. I added seam sealer to the panels I put in the car. I also updated my PC, and the editing software isn't crashing every 10 minutes which has been really nice. Because of that I was able to do a bit more overlay graphics. Hope you like it. Before: After: Then I painted real quick . Edited March 18, 2019 by Aaron Datsun 1 Quote Link to comment
