Draker Posted November 10, 2017 Author Report Share Posted November 10, 2017 No pics of the inside.. but this is the rear case. Quote Link to comment
datzenmike Posted November 10, 2017 Report Share Posted November 10, 2017 No. The nut thing flips 1st and reverse. Shit maybe it is 4th 5th. Quote Link to comment
Draker Posted November 11, 2017 Author Report Share Posted November 11, 2017 Yeah, I think it's 4/5 Quote Link to comment
datzenmike Posted November 11, 2017 Report Share Posted November 11, 2017 Yup 4/5. Quote Link to comment
Draker Posted November 11, 2017 Author Report Share Posted November 11, 2017 This was the reason the tranny got stuck in gear the first time around Quote Link to comment
Draker Posted November 11, 2017 Author Report Share Posted November 11, 2017 you can see reverse is pretty wrecked too, but this is probably common I'm guessing Quote Link to comment
Stoffregen Motorsports Posted November 11, 2017 Report Share Posted November 11, 2017 That 5th gear is dinky. Quote Link to comment
datzenmike Posted November 11, 2017 Report Share Posted November 11, 2017 you can see reverse is pretty wrecked too, but this is probably common I'm guessing Reverse is not synchronized so there will always be normal 'grinding' wear. It's not that important being a little used gear anyway. That 5th gear is dinky. Remember that Rev and first are on the same shift fork. That would be reverse counter and reverse idler gear on the rear shaft. With first counter gear on the stubby end of the counter gear driving it AND engaged to the large first gear above it. Reverse is the large gear to the rear with the wear on the leading edge of the teeth. Fifth is at the front of the transmission just behind 'forth' where third would be on a 71B Quote Link to comment
hang_510 Posted November 11, 2017 Report Share Posted November 11, 2017 I went thru 4 of them in 5 years. well they last longer than doglegs. The tranny is the only thing not rebuilt on the sedan. I've had it 10 abusive years and I'm positive the PO was even more abusive. Love the 2-3 shift in the canyons! the worn synchros are getting annoying... I don't have a use for this tranny at the moment. This project was more just for the experience than anything. If you need more experience, I'll take the rebuilt and send mine up. 1 Quote Link to comment
rgjt405 Posted April 22, 2019 Report Share Posted April 22, 2019 Where did you get the rebuild kit for the 63A? Quote Link to comment
