emanistan
How do I get to those motherf*cking nuts to get the g*d-d*mned motherf*cking carburetor off?
Because you use Harbor Freight screwdrivers?
Damn right! I should take that screwdriver right back to HF & demand my money back because it's no good at removing bolts!
Share this post
Link to post
When you go to reinstall, get yourself an extendable magnet (bet you can get one at HF), it really helps when putting the nuts back on.
Share this post
Link to post
What I did was set the washers and nuts on the carb base and carefully set the carb in place. When the studs come up through the washers fall down on and the nut sits on top. Then just reach in with fingertip and carefully spin it on. Not for the faint hearted. I also have a dental pick that you can spin them on with.
Had my L20B carb off 6 times last spring chasing a problem. Got pretty good at it.
Share this post
Link to post
If I recall, there are only a couple that need started with the carb a bit elevated for clearance, but of course those are the hardest to see / access.  And while the carb is off is the time to make sure the stud threads are good and the nuts spin down by hand, and swap out any damaged nuts for good ones.  Stuff a rag or yogurt cup cap plug in the intake hole or Murphy's law will bite you in the ass.
Share this post
Link to post
And please let us know what size the carb nuts actually are. I checked the ones on my F10 (with A14 engine) and they are 10mm. L-series are 12mm (or all the ones I've worked on). But maybe some A-series engines used 12mm. I'm curious.
In my opinion doing the nuts on an A-series (at least a smog control version) are much worse than an L-series since there is less room for fingers.. And L-series are really miserable. My hope is I'll never again need to install a carb on an A-series.
Len
Share this post
Link to post
98% sure A motor carb nuts are 10mm. Gonna take a look when I get home.
Share this post
Link to post
I have an A series intake manifold out in the garage, I just checked and it has 10mm bolts holes in it, I suppose it had studs at some point but they have been removed, so I spun a bolt in the hole(bolt with 10mm head on it).
10mm should be way easier to work with as the wrenches are small already, I have a couple really short 10mm wrenches.
Share this post
Link to post
THANK YOU EVERYBODY!!!
26325381449_e8fc3f03be_z.jpg20171101_170756 by emanistan
38070694142_527b10dff0_z.jpg20171101_170544 by emanistan
You guys have now more than earned the right to insult my screwdrivers--and my manhood with them--all you want.  Folks have been wondering about the size of these motherf*cker nuts ever since I posted this topic.  The answer, at least for the ones on my car, is 10mm, though, as I said before, other people have obviously been in this engine compartment before, so there's no guarantee they're factory original.
In the end, the fact that the nuts were so jacked up worked to my advantage: the gouges and spurs enabled me to get them off by placing a flathead screwdriver against them and getting them started by tapping the end with a small hammer, then working them out the rest of the way by hand.  This particular screwdriver didn't come from Harbor Freight; it was a JEGS brand one I bought as part of a set off Ebay last year.  That's probably why it worked.
Share this post
Link to post
10mm! I stand vindicated!
Share this post
Link to post
26325381449_e8fc3f03be_z.jpg20171101_170756 by emanistan,
38070694142_527b10dff0_z.jpg20171101_170544 by emanistan,
You guys have now more than earned the right to insult my boltdrivers--and my manhood with them--all you want. Folks have been wondering about the size of these motherf*cker nuts ever since I posted this topic. The answer, at least for the ones on my car, is 10mm, though, as I said before, other people have obviously been in this engine compartment before, so there's no guarantee they're factory original.
Share this post
Link to post
HF tools are emergency 1 time use.
I use their screwdriver for digging weeds, but they rust after 1 season.
Custom tools rule!
I cut a wrench in 2
so if bending it heat it up first but dont hold it with your bare hands
Safety tip: hot metal and cold metal are the same color.
Safety meeting anyone?
Share this post
Link to post
I bought a set of shorty metric wrenches many years ago that gets these fairly easy. The real answer is a different carb and eliminating all the emissions garbage.
Share this post
Link to post
This may not be important but.....in the picture with the carb removed, you have 4 nuts laying in front of it, they are the wrong type.  Should be a plain nut and a lock washer.
Share this post
Link to post
Not at all surprising.
Share this post
Link to post
Cut a 10mm wrench in half and tie a string to it to prevent losing it if dropped. Putting the nuts back on is just as bad. stuff something in back to catch dropped nuts.
Share this post
Link to post
Thanks everybody, especially the great Datzenmike.  You answered one thing I specifically forgot to ask: what size are those motherf*cking nuts?  since I can't even fit a caliper down there to size them, and the burrs on the edges would throw off the measurement anyway.  I think next week after payday I'll try my luck with a 1/12 box-end ratchet wrench with a flex handle.[/quote
] I know it's been several months since the last post on this, but did you ever figure out a good solution to removing the motherf**king nuts?
I have 3 B210's and ALL of mine have 10mm nuts on them. A 12mm would never fit on those carbs. The 10mm barely fits. I've had a ton of issues with my carbs over the years, so I could take those carbs off in my sleep. There is no need to remove the valve cover, overkill. Rep hoses
Share this post
Link to post
I have 3 B210's and ALL of mine have 10mm nuts on them. A 12mm would never fit on my carbs. The 10mm barely fits. I've had a ton of issues with my carbs over the years, so I could probably take those carbs off in my sleep. There is no need to remove the valve cover, overkill.
Once your air cleaner is off and ALL hoses are out of the way remove the top carb screw closest to firewall that holds the side bracket down. Remove the choke. Then remove the 2 back side screws holding the bracket on. Then remove the f**king screw and slip clip (pic below) at the end of that bracket that holds the throttle cable in place. That fucking screw is the bain of my existence! Grrr! Because, it's so hard to get back on.
Then remove the throttle cable by cranking the throttle lever around and wiggling the cable out and away from the carb body.
Next remove the big flathead screw, 2 tiny washers, and the spring that holds the accelerator pump lever on. Then remove that accelerator pump lever bar.
At this point the goddamned nuts should be as accessible as they are going to get. A bent wrench or flexible head wrench would make things easier, but not at all necessary. If the nut is really rounded needle-nose vice-grip pliers might be your best friend here to get it loosened enough to then unscrew by hand. After you get those off, put on new nuts (obviously) with nylon threading because tightening the new nuts enough without striping them can be a pain in the arse too. The nylon helps keep them from vibrating loose.
Hope this helps anyone having this same problem.
Share this post
Link to post
I use a cut in half 10mm and grind the sides of the wrench to increase the travel of each turn.  I remove the surrounding EGR, air filter and the rest.  I'll be able to access three of the nut fairly easily but the fourth one by the accelerator cable is the most difficul.
I stay patient and turn the nut a half a turn until its semi-tight.  then I'll cross tighten each nut.  BUT BEFORE I do all this I attach the accelerator cable.  I only start each nut 2 turns until they are all started.
I've removed and reinstalled carbs on my B210 maybe 10 times or more.  I muscle up my patience and wrench.
Its great to have the magnetic tool from HF and putting a string on the wrench is an awesome idea.  I lost one and never found it again.  Putting catch towels/rags around the carb is also a great idea.
Share this post
Link to post
Picture of my wrench with the sides ground off to increase travel of wrench. I threaded a piece of green yarn through a hole I drilled.  I lost a similar wrench two carburetors ago.
Share this post
Link to post
I agree with Kelmo about being the wrong type of nuts. Should be a lock washer and non-shouldered or non-cap nut like in the pic. My 79 620 has similar carb nut access issues.
What helps tremendously before removing the carb... take a mini brass wire brush from Harbor freight .79 cents and knock as much crusty/gunky stuff out of the bolt threads you can. &/or use some Goof Off on a rag to wipe them off and loosen any thread-crap build-up, then hit the studs again with the mini-brass-brush. This helps the nuts spin on/off a lot easier, and you can spin them down with your bare fingers vs. having to turn them a 12th of a turn at a time with a wrench! Once the carb is removed, put a rag in the intake holes to prevent anything falling in, and check the bolt threads for gunk build-up again when you have better view and access.
I unsuccessfully tried the balancing act of putting the nuts on the carburetor base before lowering the carb over the studs. I typically bumped the carb and dropped some, if not all nuts and washers all down the into the intake, shrouds, and motor. Sometimes they fell thru to the ground below, often times not.
My latest and fastest method is to use a straight dental pick type tool (awl shaft without a handle, really long nail, etc.) to keep from dropping washers and nuts. After putting gasket and carb on manifold, put the sharp end of the dental pick on the top of the bolt head. Slide the washer down the shaft and over the bolt. Next, slide the nut down so it is balancing on the top of the bolt shaft. Don't remove the pick yet! I spin the nut with one fat finger to start it on the bolt thread. This pic method saves dropping your washer and nut a dozen times for each stud, and saves a hell of a lot of cursing, and hunting for dropped nuts in the motor with a magnet. The yarn method is very innovative for not dropping your wrench, but I'm not coordinated enough to keep from getting wrapped up in it while using. And the one in the pic is too short for me to manipulate easily for my old hands.  I dipped the handle of my wrench in red plastic-dip to make it easier to handle, easier to see, and less slippery.
I was also going to make the suggestion Nicholas did about making the wrench thickness super-thin, but he beat me to it.  The custom carb wrench doesn't need to be beefy at all. Grind it down until it's bolt shaft arms are thin, more like a fork design for easier handling and bigger turns. You can also grind off the shoulders of the bolt arms pretty thin too. The bolt opening arms only needs enough shoulder meat on the bolt sides where it grabs the bolt head (or nut) to spin the nut tight enough to compress the lock washer + a little torque. Cut the wrench handle off so it is only 3- 4" long, or just under nearest obstruction distance.
A year or two ago I was trying to make a motor run in a truck. Took the carb on/off 3-4 times to diagnose it. The first time removing it before learning these tips, it cost me removing the valve cover + cleaning the valve cover + a new gasket, plus an 1 1/2 hours of my time just to get the carb off,  plus  a hell of a lot of frustration.
The last time I R&R'd the carb it only took me 10 minutes and I didn't remove the valve cover. It was late, cold, and dark, and I'd already had a couple beers. I just finished putting the carb and throttle cable on, connected the fuel line, had all the vac lines blocked off because I hadn't yet put the air cleaner back on. Got my head out from under the hood and stepped away from the fender. Turned to reach in the open window to start it up to test my work...noticed the carb gasket  safely leaning on the windshield out of harms way. Doh! I forgot to install the carb gasket!  R&R practice makes perfect. LOL
Share this post
Link to post
I love the wrench with the hole drilled in it, great idea.  I have a tappet wrench I cut down to size and ground the head to narrow it as well.
My contribution is this, before you put the carb back on make sure to get in with a die-grinder or Dremel and open up the recesses where the nuts live as much as you are comfortable with.  Giving you a little more room to work makes the process a whole lot better during the re-installation and future removal.
Share this post
Link to post
