the510keeper
Datsunville Da Bird Story
Trunk lid is in DTM hibuild primer surfacer
Once you glue frame to skin changes exterior sheet metal and adds work, but you get less flexing. even though it is premature  (like my ejaculation)
Works out in the long run just more masking
Bare naked surface rusted hood is next. Been stripped and sitting for years
Instead of sanding the rust off decided to metal prep the rust off then sand
Here is what it looks like after its bath with metal ech. I used metal prep socked 80 grit used paper to sand out the rust areas by hand
And 30 mins DA 80gt sanding done and ready for body work
Share this post
Link to post
Here is the money shot, or more or less what she will look like.
  • Like 8
Share this post
Link to post
Floor repair pics, just found them on my old phone.
This phase went great and quickly
Used Chris' repop floors with great success and ease
Front right
Left front
Rear right
Donor for all rear pans
Rear left
Under rear seat
Rebuilt the hinges, found a great kit on facebook
  • Like 5
Share this post
Link to post
Back on this one, finally
Roof
Had some rust and the inner structure was bend and hanging down
Cleaned the rust off with a purple wheel, been sitting for months after sanding with 80gt DA. Then realized I needed to glue that
sub frame.
I let that set up for 48 hours
now minimal flexing in the skin
Once cleaned pulled a few deep spots, however I will be floating the roof completely to make the next step quicker
left her alone for a few days and wanted to take care of some rust
Used a stud gun and welded pins to help move the patch where needed
I chose to spot weld the lower area to keep heat down
patched other areas that are questionable
Share this post
Link to post
Another week goes by and I realize at even 68 degrees in the shop surface rust came back, what a bitch.
So I figured I would metal prep, sand then grind the metal before filler
Metal prep kills rust but also does not allow bondo filler to stick. So kill rust sand off the coating it leaves and grind for filler.
I used an 8inch sheetrock knife and made cake out of it
Rock and Roll
ready for primer
  • Like 7
Share this post
Link to post
Quest for glory
Roof primed and pulled all rear suspension
Aligning panels before we do more fine filler work
The left door was fucked but want to make sure the edges are cool, chipping fresh paint sucks
A nice way to get them to line up
Hammer, dolly, pulling oh my
  • Like 4
Share this post
Link to post
Rotisserie time
Rance seamsealed and Zero rusted the 1st coat no more worrying about flash rust, fucking hate flash rusting
Let it dry 24 hours then applied a 2nd coat
Rance is Datsunvilles blacksmith
Cut these out to fit the 8inch wheels
He made these panels to do a mini tub to the outer quarter
Share this post
Link to post
Hard to believe this is the same car you started with.  Doing great James!
Save the Datsuns!
Share this post
Link to post
Looking good James.
Share this post
Link to post
Wow holy troll bomb. Hasn't been seen around here then BOOM!
Share this post
Link to post
MORE!!!!
That's what she said
Blasted and sealed the rust out, then took a couple chucks of another rocker and fun begins
Finally off the rotisserie
While on the rotisserie i was able to seal one side of this coupe
Melted the lead out seam sealed the whole bit
Share this post
Link to post
The last of the sheet metal got roughed also
Should of used a better door
Hood and door roughed fuck yeah
Share this post
Link to post
James got a question for you.  So you've never had an issue with the seam sealer pealing off over time.  We had issues in the engine bay where the inner fenders meet the firewall so we (me and frank) switched to using bondo (after expoxy of coarse) and haven't had any issues.   We used the fancy seam sealer from Westco to, the kind you have to take a loan out to afford it.
Share this post
Link to post
I was just fucking with James, there’s no bad blood between us. Hell, I was at his place for a party a couple weeks ago. You’d probably blush if you heard some of the shit we say to each other on a regular basis.
Share this post
Link to post
I was just fucking with James, there’s no bad blood between us. Hell, I was at his place for a party a couple weeks ago. You’d probably blush if you heard some of the shit we do to each other on a regular basis.
LOL we missed the party
to damn busy to party right now
Share this post
Link to post
Ive been using SEM for years with no problems
It's a 2 part, $25 a kit
Usually drip it on the ground and when i scrap it up it takes concrete with it. And thats old dusty dirty concrete
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
