1lo620 Posted October 11, 2017 Report Share Posted October 11, 2017 Ok so I am blowing a fuse that is obviously hooked to charging. Every time it blows charge light goes on. So I looked under hood didn't see any loose wires. It stopped for about a week. Now charge light comes on and fuse is really hot in fuse block. Any ideas. I am not a electrical guy.. Quote Link to comment
datzenmike Posted October 11, 2017 Report Share Posted October 11, 2017 Fuse should not get hot. Clean the brass clips that hold it. If there is resistance it will get hot like a toaster element. If hot enough it will melt the solder inside the fuse glass. Quote Link to comment
1lo620 Posted October 11, 2017 Author Report Share Posted October 11, 2017 It has that is how I found out how it was hot it melted onto my leg as I was driving. I will clean fuse block. See how that goes 1 Quote Link to comment
datzenmike Posted October 11, 2017 Report Share Posted October 11, 2017 You can also unplug it and remove. Soak in a lemon juice and salt solution over night. (vinegar also works) The mild acetic acid will remove the copper oxidation. The only problem might be that the heat has taken the spring out of the clips and they don't grip tightly anymore. Quote Link to comment
banzai510(hainz) Posted October 11, 2017 Report Share Posted October 11, 2017 Ignition fuse I assume. I reseat the connection related to the ignition side of things. Was anything added? Different coil or soemthing added. MY last 521 ignition light comming on was a bad alternator. kept popping fuses when I started the truck. those rebuild alternators are just getting worse. I cant get a year out of them anymore Quote Link to comment
1lo620 Posted October 11, 2017 Author Report Share Posted October 11, 2017 Well in will try to clean fuse block first. See where that takes me.. Alternator next. Thanks Mike and Hainz..between you both and Steve (redeye) you keep my Datsun a rolling...thanks for the help and advice. 1 Quote Link to comment
banzai510(hainz) Posted October 11, 2017 Report Share Posted October 11, 2017 just reseat the connections at alternator also. anothertime my 521 poped fuses it was the instrument cluster connection Quote Link to comment
]2eDeYe Posted October 12, 2017 Report Share Posted October 12, 2017 I totally spaced... sorry about that :) Quote Link to comment
