Stoffregen Motorsports Posted October 17, 2017 Report Share Posted October 17, 2017 Is that stuff good for water and or coolant as well? Yes, but bulky for that purpose. I also consider the color of the RTV when choosing one for a specific purpose and I don't love the look of RTV squishing out so I will try to match colors. If used on, let's say, an aluminum Datsun L series t-stat housing, I will use Gray RTV. Quote Link to comment
nissan720 Posted October 20, 2017 Author Report Share Posted October 20, 2017 I found the source of my leak.It is coming from those 2 small o-rings behind the timing cover.My motor is the ka24e.I have change these 2 times already following manufacturers instructions.I am using an aftermarket timing cover made by Dorman.I really think I have a defective cover.Going to get a new one made by ITM anybody got any experience with there products?I found one in the local salvage yard off of a 1997. Quote Link to comment
Tony620 Posted August 28, 2020 Report Share Posted August 28, 2020 On 10/19/2017 at 6:33 PM, nissan720 said: I found the source of my leak.It is coming from those 2 small o-rings behind the timing cover.My motor is the ka24e.I have change these 2 times already following manufacturers instructions.I am using an aftermarket timing cover made by Dorman.I really think I have a defective cover.Going to get a new one made by ITM anybody got any experience with there products?I found one in the local salvage yard off of a 1997. How did your ITM timing cover work out for you? Did you use a gasket or RTV? Quote Link to comment
nissan720 Posted August 28, 2020 Author Report Share Posted August 28, 2020 i went to the alvage yard and got one off of a 1997 and i used rtv where recommended Quote Link to comment
