Sign in to follow this
DatMo
32/36 dgv air filter
Just wanted personal opinion on what you guys thought was the better air filter. I’m ditching my siderafts for a bit because I can tune a weber and get it going better but I have yet to purchase a filter.
I was debating between the ram flo filter or the k&n knock off which would be a thin square filter. I doubt there’s much difference?
Also, has anyone run a 32/36 with a strut bar inside a 510? I was wondering if the t3 strut bar will even clear if I have the filter
Share this post
Link to post
strut bar really needed? I never had them on anymy 510s
weber sells a short 1.75 tall air cleaner. and the standard size also.
webercarbsdirect.com sell them and Piercemanifolds
Share this post
Link to post
The above. Get the Weber filter and skip any strut bar.
Share this post
Link to post
Strut bar? Just get the weber filter, make sure it clears, they have different sizes.
Share this post
Link to post
Yes, I have run an air cleaner on a DGV on a 510 with a strut tower brace. Mine were custom made, so it really depends on the brace.
Share this post
Link to post
Of course I know there’s always the option of not running a strut bar but I already have it so I might as well.
And if I have the option to get the filter to make it work which is practically the same price, I’d do that.
Thanks motorsports! Ill see if the stock one fits fine then. Mine is the t3 bar so it’s just directly across.
Share this post
Link to post
weber sells a short 1.75 tall air cleaners
The taller one rubbed the hood when i had an L20.
Share this post
Link to post
Great to know as I have an L20b. Thanks!
Share this post
Link to post
Having something is the worst reason for using it.
Having something that actually does something is different.
Share this post
Link to post
That's some good wisdom. Regardless, I'm gonna still go with the shorter one because I have an l20b and if the strut bar fits, so be it, it'll be on.
Share this post
Link to post
If the strut bar is already there then leave it.
Share this post
Link to post
That's exactly what I'm saying lol. I just don't have a filter so i wasnt sure the stock one would fit before I purchased one.
Share this post
Link to post
Surely you don't mean the stock Datsun air cleaner. You're speaking about the "stock" Weber air cleaner, right?
Share this post
Link to post
Yes. Sorry. I should have been more clear.
Share this post
Link to post
i ran a weber with filter on an l16 with a t3 strut bar and no issues
if you have the stock hood prop you might have to cut part of the loop that holds the bar that holds the hood up mine is cut for clearence
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
