280z abandoned in the desert...build
DatsWeird
Ratsun! Finally back after a long period of transitioning into a new career and location. Been working diligently a 280z found all over a 70 year old small town junkyard. Last six months are condensed in a short build thread to catch up to where she's at. Born on 10/1977.. Reborn 10/2017.. On a budget. Sorry 280zx for cannibalizing; you will live again, eventually.. ly.. ly.. ly..
The day she came home, zx lost its wheels and tires
Did manage to score some vintage slotted mags
Dirty but no rust to be found.. more pics on other postings
First things first, must have moar rising sun
Now I need an engine to fill the hole
Somebody torched the trans tunnel mounts so fabbed a new one from old bumper supports off a 40 plymouth. No welder so had to bolt it in for now, has a plate on each side of the tunnel, most of the old support was there, just the ears removed
Head gasket repair.. again. Used ishi stone gaskets, and copper coat to help distribute heat. Blew in same spot as prior(between 3&4 cyl)
Added arp head studs for hopefully better sealing.. head was decked but block was not. Torqued to 65 ft/lbs turbo spec
Back together with fresh su's, and a points distributor so I'll still have spark after the EMP's hit and the zombies come. Fuel lines are temporary
Accelerator bellcrank was missing; Found out if you turn the zx one upside down and make a bracket off the original holes, it works. Pull instead of push
ZX radiator fit with just a few new holes drilled and top hose cut about 2 inches shorter to outlet
Alrighty, onto interior. after removing pounds of sand, buying some cheap material off ebay,and lots of vinyl spray paint, I give you this
ZX donated another part. Used plasti dip on that one so I can eventually give it back.. maybe
Couldn't afford new covers so I stitch some material to the lumpy carcass of a seat I had. Not perfect but works for now. Took about 15 hours a seat to hand stitch and sterilize the old ones
First interior I've done, not as hard as I thought, stitched it into the piping of the old upholstery underneath. Cost about 50 in materials for the entire car.
On to the bodywork
And that's where she is. Getting close to starting for the first time but still have some wiring to do underhood. I'll post in the proper section for those, first build thread so any help/advice is much appreciated. Cheers
  • Replies 9
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
