Home Built by Jeff Posted February 20, 2019 Author Report Share Posted February 20, 2019 In this episode I go back and tidy up a bunch of loose ends on the 680g 1 Quote Link to comment
Lockleaf Posted February 21, 2019 Report Share Posted February 21, 2019 I'm not sure if you have tried this or not, but when I'm wrapping wiring with electrical tape, i wrap it in two layers. I wrap the first layer inside out, sticky side out. Then i wrap the second layer normally, sticking the two sticky sides together. This creates a vinyl tube for the wiring. I prefer this for two reasons. 1) when you need to pull a wire, you can because it's not stuck anywhere. 2)if you ever need to go back in, you don't have that disgusting black tar all over the wiring that makes the whole job super miserable. In reality, i wrap the two at the same time using two rolls of electrical tape. I will start both layers then wrap a few inches of inner, then wrap the outer to catch up. Still loving the videos. 1 Quote Link to comment
Home Built by Jeff Posted February 21, 2019 Author Report Share Posted February 21, 2019 1 hour ago, Lockleaf said: I'm not sure if you have tried this or not, but when I'm wrapping wiring with electrical tape, i wrap it in two layers. I wrap the first layer inside out, sticky side out. Then i wrap the second layer normally, sticking the two sticky sides together. This creates a vinyl tube for the wiring. I prefer this for two reasons. 1) when you need to pull a wire, you can because it's not stuck anywhere. 2)if you ever need to go back in, you don't have that disgusting black tar all over the wiring that makes the whole job super miserable. In reality, i wrap the two at the same time using two rolls of electrical tape. I will start both layers then wrap a few inches of inner, then wrap the outer to catch up. Still loving the videos. I like that idea, I have never heard of it before but it absolutely makes sense. I will give it a go. Quote Link to comment
Home Built by Jeff Posted February 23, 2019 Author Report Share Posted February 23, 2019 In this episode I put a few finishing touches on the exterior of the 680g and some of them may be controversial. 1 Quote Link to comment
Duncan Posted February 23, 2019 Report Share Posted February 23, 2019 On 2/20/2019 at 5:10 PM, Lockleaf said: I'm not sure if you have tried this or not, but when I'm wrapping wiring with electrical tape, i wrap it in two layers. I wrap the first layer inside out, sticky side out. Then i wrap the second layer normally, sticking the two sticky sides together. This creates a vinyl tube for the wiring. Interesting. I use harness tape which is made for wrapping looms. You can unwrap a bundle, then wrap it right back up again. I use a TINY piece of black tape at the very end of the wrap which is easily removed for any service needs. When I did my wagon, the PO used electrical tape on the entire harness which was a disaster to deal with.. Quote Link to comment
Home Built by Jeff Posted February 27, 2019 Author Report Share Posted February 27, 2019 In this episode I have a go at TIG welding a stainless steel exhaust for the 680g with a bit of help from Benny, aka The Mechanical Stig. 2 Quote Link to comment
Tedman Posted February 28, 2019 Report Share Posted February 28, 2019 Hey Jeff, I like the stripes! Scroll to the bottom of this page to see a similar stripe scheme on a 260Z Official Pace Car. Perhaps this was your inspiration? BTW- Yours looks better. ? http://zhome.com/Racing/PaceCars.htm Keep up the great work! Quote Link to comment
Home Built by Jeff Posted February 28, 2019 Author Report Share Posted February 28, 2019 2 hours ago, Tedman said: Hey Jeff, I like the stripes! Scroll to the bottom of this page to see a similar stripe scheme on a 260Z Official Pace Car. Perhaps this was your inspiration? BTW- Yours looks better. ? http://zhome.com/Racing/PaceCars.htm Keep up the great work! That original design was actually done by Peter Brock for his BRE race cars. Quote Link to comment
Home Built by Jeff Posted March 2, 2019 Author Report Share Posted March 2, 2019 (edited) In this episode Benny gives me a hand to bleed the brakes and I finish off the exhaust tips. Edited March 2, 2019 by Home Built by Jeff 2 Quote Link to comment
Home Built by Jeff Posted March 6, 2019 Author Report Share Posted March 6, 2019 In this episode I finally do something about the suspension and ride height of the 680. Quote Link to comment
Farmer Posted March 7, 2019 Report Share Posted March 7, 2019 When is the first start up, coming? Quote Link to comment
Home Built by Jeff Posted March 7, 2019 Author Report Share Posted March 7, 2019 3 hours ago, Farmer said: When is the first start up, coming? Hopefully very soon! 1 Quote Link to comment
Home Built by Jeff Posted March 9, 2019 Author Report Share Posted March 9, 2019 This week I try to burn the whole car to the ground... 1 Quote Link to comment
Lockleaf Posted March 12, 2019 Report Share Posted March 12, 2019 With the key on you should be able to trace power to that oil pressure switch, but not out of it. If that is the case, turn off key, unplug both wires from oil pressure switch and put a jumper wire across them. That should kick the pump on with the key if you wired it all up correctly. Then you can undo the jumper and plug back to pressure switch so it functions how you designed it. Quote Link to comment
Home Built by Jeff Posted March 12, 2019 Author Report Share Posted March 12, 2019 The pressure switch is easy enough to sort out. The issue I am having now is that it appears my dizzy is stuffed 😞 1 Quote Link to comment
Home Built by Jeff Posted March 13, 2019 Author Report Share Posted March 13, 2019 This week I top up all of the fluids and finally try to start the 680g. 1 Quote Link to comment
510revisited Posted March 13, 2019 Report Share Posted March 13, 2019 As i mentioned on youtube, here is a link to my issue. here is my thread 1 Quote Link to comment
Home Built by Jeff Posted March 16, 2019 Author Report Share Posted March 16, 2019 In this episode I finish off painting the last of the bits of the 680g. Quote Link to comment
Home Built by Jeff Posted March 20, 2019 Author Report Share Posted March 20, 2019 I finally get it started!!! Wooo Hooo!. I had to cobble some bits together, but it starts and runs! 3 Quote Link to comment
Farmer Posted March 21, 2019 Report Share Posted March 21, 2019 Congrats on the start up 1 Quote Link to comment
Lockleaf Posted March 21, 2019 Report Share Posted March 21, 2019 (edited) Congrats on the start up man! That feeling of satisfaction you get when a huge project like this comes together is a major part of the reason I love playing with cars. I completely understand your frustration with the wiring. I have a '71 510 (Half Pint in my signature if you're interested) with an 80's nissan truck motor in it, and my wiring was mostly gone when I got the car, so I used the complete wiring harness from the truck as well. Integrating that harness with the factory 510 switches (headlight, wiper, blower motor) and also with the wiring to the back half of the car took FOREVER. All sorts of crazy little things I had to track down. Edited March 21, 2019 by Lockleaf 1 Quote Link to comment
Home Built by Jeff Posted March 23, 2019 Author Report Share Posted March 23, 2019 In this episode I make up a complete carpet kit for the 680g 1 Quote Link to comment
Home Built by Jeff Posted March 27, 2019 Author Report Share Posted March 27, 2019 (edited) In this episode I retrim the seats to match the rest of the trim in the 680g. Edited March 27, 2019 by Home Built by Jeff 1 Quote Link to comment
Lockleaf Posted March 29, 2019 Report Share Posted March 29, 2019 You improved the seats 100 fold! Very nice work. I must admit i was hoping the boot would be diamond stitch as well. But i can also see that being overboard. My 510 had the same headlight switch issue. I rewired mine to use a 70s Chevy floor mounted foot switch for the headlights. I used 2 pins, to connect or disconnect the ground side of the circuit. This is from my thread: My high beam switch doesn't work. The turn signals work fine, but that switch doesn't. So I decided to work around that problem. Chevy style. Floor mount headlight dimmer switch. Cheap and readily available. I don't think I could say either of those things about replacing the factory turn signal/headlight switch (but maybe I'm wrong). Depinned one of the three pins. I only need two. It's all wired in, tested and functional. Just need to mount it to the car. About here seems good. I love these floor mounted switches actually, so I'm ok with doing this mod. However, the way I wired it in, should I ever repair the column switch, I can use either one functionally, so long as the other is set to "open", which in this harness means set to high beams. Progress! 2 Quote Link to comment
Home Built by Jeff Posted March 29, 2019 Author Report Share Posted March 29, 2019 I am not a fan of the floor switch personally, so I am happy to leave the switch on the bottom of the column for the time being, but I do like your solution. 1 Quote Link to comment
