gene knight Posted May 19 Report Share Posted May 19 14 hours ago, Stoffregen Motorsports said: That sucks. My local guy is so good, that I don't even buy new anymore. I just bring the stuff to him. I wonder what makes the inexpensive ones fail so quickly. Is it crap bearings or bad re-machining of the cases? One main reason for failure is high RPM use. Even a brand new OEM Datsun alternator won't stand up to constant high RPMs. The alternator on my race car, a Bosch ALRACE1 alternator, is built specifically for racing. https://www.amazon.com/Bosch-ALRACE1-0124120006-New-Alternator/dp/B00427PMJQ Another reason they give out is wobbly brackets. Luckily for the Datsun guys, the stock brackets are pretty stout, so this isn't usually a problem. is the alternator internally regulated cuz i looked on the link you provided and checked specs but it does not state if internally regulated 1 Quote Link to comment
Stoffregen Motorsports Posted May 19 Report Share Posted May 19 Yes, it is internally regulated. 9 hours ago, gene knight said: is the alternator internally regulated cuz i looked on the link you provided and checked specs but it does not state if internally regulated 1 Quote Link to comment
Stoffregen Motorsports Posted May 19 Report Share Posted May 19 17 hours ago, datzenmike said: I wonder what they really do when they 're manufacture' an alternator? Clean it, paint it and put a sticker on it? I'm sure there are minimum requirements from the retailer. It probably gets disassembled and cleaned, the com maybe cut or polished, new brushes and bearings, and a plastic cover on back. New pulley and either paint or clean blasted case. For us to do that in our home shop would take an hour, but they can probably do ten per hour, or more. They make their money on bulk. When I used to cook for a living, I could break down a whole chicken in 45 seconds. Did that make me a bad cook? Nope. Quote Link to comment
d.p Posted May 19 Report Share Posted May 19 On 5/18/2022 at 12:02 PM, Stoffregen Motorsports said: One main reason for failure is high RPM use. Even a brand new OEM Datsun alternator won't stand up to constant high RPMs. The alternator on my race car, a Bosch ALRACE1 alternator, is built specifically for racing. https://www.amazon.com/Bosch-ALRACE1-0124120006-New-Alternator/dp/B00427PMJQ Is this fucker confirmed fit for a 521 or are you just tickling our fancy with stuff like this? Quote Link to comment
Stoffregen Motorsports Posted May 19 Report Share Posted May 19 No, not a direct bolt in. At least, I haven't tried. Tickling your fancy? I could get some measurements off the one I have and one of you guys could confirm. 1 Quote Link to comment
d.p Posted May 19 Report Share Posted May 19 (edited) I just want a solid reliable alternator and am willing to pay good money for it. I think Troy Ermish was selling them at one point but his website is painful as hell to navigate. And anyone seen this? Oil pan support? Mine still has a slow drip from the back passenger side and wondering if this would help? Tired of your 510 oil pan leaking oil at the rail? Someone over tighten the bolts and pinch the gasket creating an even worse leak? Just finished up a run of pain rail supports. Designed to help support the rear to passenger side of the pan. The lowest points and most likely to leak area. Especially helpful when using the heavier 7qt comp race pan. Only 1 rail is needed per oil pan. ( sold individually ) Edited May 19 by d.p 4 Quote Link to comment
mainer311 Posted May 19 Author Report Share Posted May 19 4 hours ago, Stoffregen Motorsports said: I'm sure there are minimum requirements from the retailer. It probably gets disassembled and cleaned, the com maybe cut or polished, new brushes and bearings, and a plastic cover on back. New pulley and either paint or clean blasted case. For us to do that in our home shop would take an hour, but they can probably do ten per hour, or more. They make their money on bulk. When I used to cook for a living, I could break down a whole chicken in 45 seconds. Did that make me a bad cook? Nope. Whatever it entails, they forgot the woodruff key on the shaft… 1 Quote Link to comment
thisismatt Posted May 20 Report Share Posted May 20 I need some pain rail support Quote Link to comment
Stoffregen Motorsports Posted May 20 Report Share Posted May 20 19 hours ago, mainer311 said: Whatever it entails, they forgot the woodruff key on the shaft… Seriously? Quote Link to comment
mainer311 Posted May 20 Author Report Share Posted May 20 (edited) 1 hour ago, Stoffregen Motorsports said: Seriously? Yup. Only the nut torque was keeping the fan and pulley in place. Once I got the nut loose, I couldn't remove it because the shaft was spinning with the nut, even after I jammed a screwdriver into the fan. Had to reach in from the back and lock the armature in place to get the nut off. Top notch. Edited May 20 by mainer311 1 Quote Link to comment
mainer311 Posted Monday at 06:04 PM Author Report Share Posted Monday at 06:04 PM Picked up a new daily driver over the weekend. 300hp dual injection V6, 8 speed auto, and lower/stiffer suspension. Thing is pretty bad ass for a kid hauler. 2 Quote Link to comment
