mainer311 Posted January 9, 2018 Author Report Share Posted January 9, 2018 It’s ridiculous. 3 Quote Link to comment
flatcat19 Posted January 9, 2018 Report Share Posted January 9, 2018 Flatcat, I deleted the diagram that I made, but can easily make a new one and send you a PDF. It’s very simple, and uses the factory headlight relay to trigger two additional relays. The low/high circuits are completely separate of each other, and each one has its own fuse holder. I am not interested in making and selling any more. I'll PM you later. My idea is a bit different than what you made. But...I like your truck and you're really making some good progress on it. 2 Quote Link to comment
mainer311 Posted January 11, 2018 Author Report Share Posted January 11, 2018 For the naysayers. Look of the lights from further away. Low beam cutoff. Nice upsweep to the right for sign illumination. High beam. Nice and high and bright right in the center. Low beam, further out. High beam, further out. Low beam, on the road. High beam, on the road. Notice you can see the tree all the way at the end? 4 Quote Link to comment
greenthumb Posted January 11, 2018 Report Share Posted January 11, 2018 love the headlight mod I'm all for better visibility. Maybe i missed it, but did you have to import those lights? Great progress on your project btw. Thanks for the regular updates. Hopefully some of your motivation rubs off on me :geek: 1 Quote Link to comment
mainer311 Posted January 11, 2018 Author Report Share Posted January 11, 2018 Green thumb, the lights were bought from Susquehanna Motorsports in Pennsylvania. You can buy them with or w/o bulbs. 1 Quote Link to comment
Crashtd420 Posted January 11, 2018 Report Share Posted January 11, 2018 Green thumb, the lights were bought from Susquehanna Motorsports in Pennsylvania. You can buy them with or w/o bulbs. Thanks for that I was curious too... Dont know if I missed it or not but what watt bulbs are you running? And are the lenses in fact glass? I think thats a nice upgrade compared to some of the other stuff on line.. I hate these new lights with plastic lenses... 1 Quote Link to comment
mainer311 Posted January 11, 2018 Author Report Share Posted January 11, 2018 Yup housings are glass, and they come with nice thick rubber boots that seal around the back of the bulbs. The indentation and alignment keys on the back line up perfectly with the stock buckets. For bulbs, I used standard 55/60W 9003's, which are basically the same as H4's. I bought the Philips 9003 Vision Plus. (None of that blue glass bullshit.) If I had to do it again, I'd order the kit with bulbs. I spent almost $50 on just bulbs at Pep Boys. Their prices on lighting are astronomical. http://www.rallylights.com/h5006-hella-5-3-4-round-e-code-hi-lo-conversion-headlamp-kit.html Or w/o. This is for a single light, so you'd need to order 4. http://www.rallylights.com/hella-5-3-4-round-ece-high-low-beam-headlamp-no-bulb-hl79564.html If you wanted the stock setup, you could order 2 of the above, and then 2 of these: (It's actually cheaper if you don't go the stock route.) http://www.rallylights.com/hella-5-3-4-round-h1-high-beam-headlamp-ece-each-hl71157.html 1 Quote Link to comment
Crashtd420 Posted January 11, 2018 Report Share Posted January 11, 2018 Thanks for the info .... ya I checked their web sight good quality stuff... Got all the info saved... that's now on my wish list for after I'm on the road driving mine again... 1 Quote Link to comment
d.p Posted January 11, 2018 Report Share Posted January 11, 2018 Man mainer these guys got you out in the cold dead of night trying to prove your light output. lol 1 Quote Link to comment
Crashtd420 Posted January 11, 2018 Report Share Posted January 11, 2018 Man mainer these guys got you out in the cold dead of night trying to prove your light output. lol I was thinking the same thing... 1 Quote Link to comment
mainer311 Posted January 11, 2018 Author Report Share Posted January 11, 2018 Nah, tinkering on my Datsuns after work is my healthy reprieve. I was out working in the garage anyway. 1 Quote Link to comment
hobospyder Posted January 11, 2018 Report Share Posted January 11, 2018 There's something wrong with your outdoors. It's supposed to be green not white 2 Quote Link to comment
mainer311 Posted January 11, 2018 Author Report Share Posted January 11, 2018 Tell me about it. The Datsuns hybernate until the roads are salt-free. 1 Quote Link to comment
hobospyder Posted January 11, 2018 Report Share Posted January 11, 2018 That's an awful lot of salt 2 Quote Link to comment
mainer311 Posted January 17, 2018 Author Report Share Posted January 17, 2018 FedEx just dropped off a bunch of disc brake parts for my conversion. I decided on a late 620 MC with 13/16” bore, designed for disc/drum. I’ll be keeping my rear drum brakes. Does the Cardone MC come with the residual valves already installed, or do I need to buy those separate? 1 Quote Link to comment
flatcat19 Posted January 17, 2018 Report Share Posted January 17, 2018 It should be plumbed properly already... Buy a spare CENTRIC brand master cylinder as your backup. 1 Quote Link to comment
Crashtd420 Posted January 17, 2018 Report Share Posted January 17, 2018 FedEx just dropped off a bunch of disc brake parts for my conversion. I decided on a late 620 MC with 13/16” bore, designed for disc/drum. I’ll be keeping my rear drum brakes. Does the Cardone MC come with the residual valves already installed, or do I need to buy those separate? I don't think you need to do anything more to the master... I did the same thing got a dual master for front disc/rear drum and things seem to work just fine... 1 Quote Link to comment
Charlie69 Posted January 17, 2018 Report Share Posted January 17, 2018 Here is a good read https://www.truck-lite.com/content/news/sae-vs-dot-truth-about-lighting-regulations Not a fan Cardone parts. Cardone, Cartel!!! LOL Quote Link to comment
mainer311 Posted January 17, 2018 Author Report Share Posted January 17, 2018 Why is that a good read? I’m using neither of those. 1 Quote Link to comment
flatcat19 Posted January 18, 2018 Report Share Posted January 18, 2018 Not a fan Cardone parts. Cardone, Cartel!!! LOL Poorly cleaned "remanufactured," over priced junk. I'd rather rebuild anything with original, used seals than put an iota of trust in anything with a Car done label. 1 Quote Link to comment
mainer311 Posted January 18, 2018 Author Report Share Posted January 18, 2018 It’s a new one, not remanufactured. 1 Quote Link to comment
flatcat19 Posted January 18, 2018 Report Share Posted January 18, 2018 Makes no difference. For a dollar or two more, you could have bought a top shelf part. I work in the automotive field...using cardone is a big no-no. Many, MANY threads around here stating the same. 1 Quote Link to comment
mainer311 Posted January 24, 2018 Author Report Share Posted January 24, 2018 Well, I ordered a 15x8 -19 wheel for test fit. It’ll be wrapped in a 195/60R15, stretched slightly. American Racing notified us that the AR61 wheel is likely going end of life soon. 1 Quote Link to comment
d.p Posted January 24, 2018 Report Share Posted January 24, 2018 Test fit over the stock drums? Cause it will fit, lots of dudes run 15 x 8.5 k5 blazers which are right around that offset as well. Quote Link to comment
flatcat19 Posted January 24, 2018 Report Share Posted January 24, 2018 Well, I ordered a 15x8 -19 wheel for test fit. It’ll be wrapped in a 195/60R15, stretched slightly. American Racing notified us that the AR61 wheel is likely going end of life soon. 55 would have been better. More stretch to avoid fender lip. Lightly roll the rear fenders because you will cut a tire. Only the upper center 6 inches need to be massaged. I think you posted your query about these wheels in the TRUCK WHEELS thread. In that thread I said you'll have a little poke. Test fit over the stock drums? Cause it will fit, lots of dudes run 15 x 8.5 k5 blazers which are right around that offset as well. K5s are 15x8 +10et. Why I posted what I did. My K5s are a perfect fit with 195/65R15s. 3" blocks and a couple of removed leafs. 1 Quote Link to comment
