carterb Posted April 22 Author Report Share Posted April 22 White 1972 1600DX Bluebird 4dr 1,780,000 Yen https://auctions.yahoo.co.jp/jp/auction/p1227222244 510 Bluebird (1971 Model Year) — Late Series — Running Condition — One Owner — 1600DX — Floor-Shift 4-Speed Manual comment From being left untouched and immobile since 1996: Fuel tank cleaned and internally coated; mechanical pump replaced with a new Nismo electromagnetic pump ; new fuel float ; new fuel hoses ; new fuel regulator (Holey) ; DR30 struts ; DR30 calipers (disc brakes, vented rotors) ; new ZSS full-tap adjustable coilovers ; new Cusco adjustable upper mounts ; new ball joints and tie rod assembly ; carburetor refreshed (all gaskets new) ; new spark plugs and spark plug wires ; intake manifold cleaned; new insulators ; four new headlights ; new radiator hoses ; all heater hoses new; new thermostat housing and thermostat; new water pump; new pulley ; Hayashi Mag 14-inch wheels; 175/65 tires (2021 model). Grooved wheels, new left and right side turn signals, repainted front turn signals , new brake master cylinder , new clutch master cylinder, repainted air filter case , new air filter , 1.2mm clutch tread remaining, cleaned transmission housing , rust removal, rustproofing, and repainting of floor and wheel wells have been completed. Most of the removed parts are still there . I have prepared the DR struts separately, so I also have the original drum brake set and struts . The rocker panel moldings are also there , they have just been removed. Missing items : Battery , muffler ( removed because it was corroded and partially fallen off ) , mirrors (DX mirrors were installed, but the right one has a broken bolt and the left one is broken at the base) , window washer tank , speedometer cable (the cable is there but has been removed because it is prone to coming loose). The engine currently starts. It starts easily. The transmission shifts smoothly. Idling is rough, so carb adjustment will probably be necessary (maybe it will be fine after warming up?). This is an older car, so please only contact me if you understand this. The documents are "Deregistration Certificate". There should be no problem with re-registration. On-site inspection is required. No claims, no returns will be accepted. Quote Link to comment
carterb Posted May 1 Author Report Share Posted May 1 White 1970 1400 Okinawa Spec Bluebird 4dr 2,200,000 Yen https://auctions.yahoo.co.jp/jp/auction/d1227905192 Okinawa specification left-hand drive "Oki 5" license plate Nissan 510 Bluebird 3-speed column-shift transmission/air conditioning comment ◆An extremely rare left-hand drive vehicle registered in 1970 (Showa 45), with an Okinawa 5 single-digit license plate from after Okinawa's return to Japan. These are becoming increasingly rare even in Okinawa. ◆L-type 1300cc engine, rare column-mounted 3-speed gearbox/stick-type handbrake. Currently, the engine, transmission, and air conditioning are in good working order. The odometer shows 98,902 miles. As it is a classic car, details are unknown. ◆I've cherished this item, but I'm selling it as I'm downsizing my collection. I'm not considering trading it for another vehicle. ◆Currently fitted are 14-inch gold mesh wheels (Dunlop Enasave: 155/65/14) of an unknown manufacturer. Center caps are missing. A genuine wheel with Bridgestone tires (145/80/13) is also included as a service, but it has been used very little. ◆How about a left-hand drive Okinawa-spec 510 Bluebird, which is hard to find? Once restored, it will become a very valuable classic car. ◆Currently stored in an air-conditioned indoor garage. ◆Please refer to the photos. There is a lot of rust and scratches. Please bid with the understanding that restoration will be required. We will not be held responsible for any defects after the auction ends. No claims, no returns. Please only bid if you have read and understood this description carefully. By bidding, you are considered to have understood the terms. Please do not bid if you are overly sensitive or prone to making complaints. ◆Both front and rear brake drums have been replaced with new ones. Brake points have been replaced with new ones. Spark plugs and spark plug wires have been replaced. Since it is left-hand drive, an ETC onboard unit has been installed. ◆All the parts I've collected will be given to the winning bidder. Please see the photos. Shipping costs are high, so I will ship them in my car. New left front fender / new brake / new clutch master cylinder, new gaskets, and other items. ◆I would like to keep the "Oki 5" license plate in Okinawa if possible. We cannot provide assistance or advice regarding the retention of the "Oki 5" license plate after the auction. Please ask an acquaintance living in Okinawa. ◆Although it's a shame, we can also deregister the vehicle before handing it over. In that case, we will not charge this year's automobile tax. ◆Last time I listed this item, I received many frivolous inquiries from people who couldn't actually buy it. Please do not bid if you cannot clear the initial hurdles such as "family objections," "cannot obtain a parking permit," "will wait until I have the money," or "bid by mistake." ◆Please transfer ownership promptly after winning the auction. Please also pay the prorated automobile tax. Please complete the ownership transfer within two weeks of receiving the ownership transfer documents. A deposit of 50,000 yen will be required. The deposit will be transferred to your designated account after confirmation of the ownership transfer. ◆Shipping costs include freight to Naha Port, Okinawa. Since it is an older vehicle, it will be shipped on a pallet. Fukuoka Hakata Port: 100,000 yen Osaka South Port: 110,000 yen Tokyo Ariake: 120,000 yen. ◆If you have any questions, please contact tasamo888@yahoo.co.jp. Quote Link to comment
carterb Posted May 1 Author Report Share Posted May 1 Safari Gold 1970 1600SSS Bluebird Coupe 2,000,000 Yen https://auctions.yahoo.co.jp/jp/auction/x1228198912 510 Bluebird 1600SSS Coupe, actual mileage in the 40,000 km range. comment 510 SSS1600 Coupe Bluebird, 1970 model year ★ Exterior, completely repainted? ★ Engine room interior in the same color ★ Aftermarket wheels 13AW Speed Star MK2 ★ Original optional HITACHI air conditioning unit ★ New battery ★ Engine starts on the first try * The interior is as it was at the time, so there are tears and rips. * The door panels are missing from the beginning. * Although an air conditioning unit is installed, the compressor of this era is prone to gas leaks, so no cold air comes out. * This is a 54-year-old classic car, so please inspect the actual vehicle. * We are also selling on other platforms, so we apologize if it is sold. * To prevent pranks, we may delete bids from users with no feedback at our discretion, so please understand. If you are serious about purchasing feedback, please inquire through the questions section. * The buyer is generally responsible for arranging transportation. We can also arrange it, but it will be more expensive for classic cars. * People have different opinions on used items. Also, there are limits to conveying the condition 100 percent accurately. There may be oversights, insufficient explanations, or insufficient images. In the unlikely event of any oversights, the actual vehicle will take precedence. Please refrain from bidding if you are overly particular or do not understand the nature of auctions. We recommend inspecting the actual item to avoid any problems. * As this is a used item, there may be scratches, dirt, rust, dents, etc. We welcome bids from those who understand the nature of used items. Please note that there are no claims, no returns, no cancellations, and no after-sales service. * We welcome bids from those who can contact us within 24 hours and make payment within 3 business days. (If we do not receive contact after 24 hours, the transaction will be canceled due to "buyer's circumstances." In that case, the buyer will automatically receive a "very bad" rating, so please be aware of this.) * We do not accept cancellations or returns after the auction ends. Please consider carefully before bidding to avoid cancellations. * Receipts will only be issued for cash payments. [Payment Method] ★ Bank transfer (cash payment is also possible if you pick up the item directly.) For other inquiries or to apply for immediate purchase , please contact myhood40@icloud.com . (Added April 30, 2026, 11:38 AM) *As this is an older car, please assume it has a repair history. Quote Link to comment
carterb Posted May 16 Author Report Share Posted May 16 Silver 1969 1600dx Bluebird 4dr 798,000 Yen https://auctions.yahoo.co.jp/jp/auction/h1229868088 Datsun 510 Bluebird ・ Datsun Bluebird ・ Year: Estimated to be manufactured in 1969 (Showa 44) ・ Chassis number: P510-112*** ・ Grade: 1600 Deluxe ・ Model: P510 ・ Transmission: 4-speed manual ・ Body color: Silver This car, owned by a relative, has expired inspection and has been stored in a garage, but has rust, dents, scratches, etc. ・ Some paint has been applied . * Not drivable * Rear drum brake shoes have been removed due to seizure (stored inside the car) * One brake cable is broken * Right turn signal lens is missing It has been stored outdoors for 5 months now. Battery is not installed. It has not been washed or cleaned. There are no documents. The original registration number is known. Sold as is. How about using it for parts? Please ask any questions you may have as soon as possible. [Payment Method] To ensure a fair transaction, please use Yahoo! Easy Payment. Direct transactions and payment consultations after winning the auction are strictly prohibited. [Important Notice] For security reasons and to share information with the management, if you wish to inspect the vehicle in person, please include your name, address, phone number, and email address in the system's question section, along with your preferred date and time for inspection. We will contact you using the email address you provide, not the question and answer section. Also, when you win the auction, please provide your name, address, phone number, and email address in the transaction contact section. [Important Notice] We are having difficulty responding to inquiries other than vehicle inspections, and inquiries that include personal information (such as email addresses) for which we wish to contact you directly. We will not respond to inquiries other than vehicle inspections that include personal information. This is a sale as is. We will not accept any claims without a vehicle inspection. The location is accessible by transport truck. (Storage location: Northern Nagano Prefecture) Please only bid if you can be contacted within 48 hours of winning the auction, can make payment within 7 days, and can arrange for pickup yourself. If we do not receive contact, the transaction will be canceled due to the buyer's circumstances. Please note in advance that we may cancel bids from those with many negative ratings or those with few Yahoo! Auctions transactions at our discretion. Please do not bid if you cannot be contacted or if you refuse to accept a bid from the next highest bidder. You will be blacklisted and reported to Yahoo! as a fraudulent bidder. Please also do not bid if you are overly concerned with minor details. Bidding is only possible on a no-claims, no-returns, no-cancellation basis. Thank you for your understanding. Quote Link to comment
carterb Posted May 16 Author Report Share Posted May 16 Orange 1971 1600 SSS Bluebird 4dr 1,551,000 Yen https://auctions.yahoo.co.jp/jp/auction/h1229600372 ★ 510 ★ Bluebird Sedan ★ 1600SSS ★ L16 ★ Solex Carburetor ★ Documents Included ★ 510 ★ Bluebird Sedan ★ 1600SSS ★ L16 ★ Solex Carburetor ★ Documents Included ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ Product Description ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ Thank you for watching. Please read the following carefully to the end. We look forward to receiving many bids. As stated in the notes, please ensure that you can contact us within 24 hours of winning the auction (including the day of the auction), pick up the item within 7 days, and make payment within 7 days. ★Today I am listing a 510 Bluebird Sedan 1600SSS. ★I drove a car, and there were no problems with driving. ★All necessary documents are included. ★Solex carburetor ★ Engine L16 ★ Record book (H12, 14, 16, 17, 18, 20, 22) ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ Others ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ △ ▼ Payment Details Amount to pay Auction price for the winning vehicle Please strictly adhere to the 3N policy (no claims, no returns, no cancellations). *We will not accept any complaints after the auction ends.* Additionally, a cancellation fee of 50,000 yen will be charged regardless of the circumstances. To avoid any problems after the auction, we request that you inspect the vehicle in person. If you win the auction without inspecting the vehicle in person, we will not accept any claims, even if there are oversights or errors in the description on our part. Therefore, we strongly recommend that you inspect the vehicle in person. Vehicle inspections are only available during the daytime, but please understand that scheduling conflicts may arise. Please be sure to inquire via the questions section. To avoid any problems after the auction ends, we require you to sign the automobile sales contract and provide a copy of your driver's license. If you have any questions or requests, please ask them through the question section. Thank you for watching until the end. We look forward to your participation. Quote Link to comment
carterb Posted May 18 Author Report Share Posted May 18 White 1970 1600SSS Bluebird Coupe 4,350,000 Yen https://auctions.yahoo.co.jp/jp/auction/l1224089274 1970 Bluebird 1600SSS Coupe comment [Specifications and Condition] Genuine original style, no vehicle inspection, fully repainted (interior repainting done after arrival), 4MT , original steering wheel, original FM radio (operation confirmed) + new pillar antenna installed (antenna wire distribution line wiring), Hayashi Street aluminum wheels (flat black touch-up paint) 6J-14inch + 175/60/14 new , front ride height adjustable camber adjustment. SU twin carburetors & manifold / linkage / blasted + repainted genuine air cleaner, blow-by power filter installed, master back check valve & routing pipe replaced with new , aftermarket bucket seats & seat rails new (driver and passenger seats only flip up), rear pillar & lower rear window surface repaired, dashboard replaced with new reproduction, door inner panel repaired, main key cylinder replaced with new , rear speaker board repaired, rear taillight chrome painted & rubber gasket replaced with new , back panel repaired and painted, side pillar air vent panel chrome painted and restored, radiator cleaned, front chassis panel area repaired and painted, fuel line rerouted and filter replaced The diaphragm pump and other parts were blast-blasted, the washer tank was replaced with a new aftermarket part and the water lines were re -routed, the interior floor butyl sheet finish was repainted, the headlight bezels were blast-blasted and then rustproofed and the stainless steel rings were repaired, the battery hold was repaired, the thermostat and housing were cleaned and the gaskets were replaced, the dashboard was replaced with a new one and the front dashboard air vent plate was repaired and painted, the harness lines were inspected and serviced, the front turn signal base was replaced with a new late-model one, the side marker lenses were replaced with new ones , the console box was fitted with a genuine 510 original part, the halogen lights were replaced with new Hi-Lo lights, the headlight relay and headlight switch were overhauled and cleaned and the SW plate was repainted, the wipers were blast-blasted and painted and the pivot rubber was replaced with a new one , the covers around the lights were painted, the master back connection valve and pipes were replaced with new ones , the driver's and passenger's footwell side plates were fabricated and replaced, the floor carpet was cleaned, the step inner sheets were fabricated and attached, the roof lining was re-dyed black, and the rearview mirrors, hand grips and sun visors were repaired. New installation of Bluetooth speaker integrated deck , fabrication and installation of rear seat backboard, rear drum brake overhaul and adjustment, console box lamp rewiring and lighting check, fabrication and re-installation of side step molding mounting brackets, matte black paint repair and application to trunk board, trunk seat mat cleaning, new DATSUN rubber mats (passenger and driver sides). Vehicle inspection fee: 166,000 yen (separate charge) (Added March 25, 2026, 08:24) Transactions are on an "as is" basis, with no claims or returns accepted. Vehicles are generally picked up at the store; delivery fees and other charges will be charged separately. For inquiries, please contact Kawamura at 0532-55-5530. (Added April 16, 2026 05:51) I've uploaded detailed photos to the photo gallery, so please check them out. Click below https://30d.jp/stuff/177 Quote Link to comment
carterb Posted May 18 Author Report Share Posted May 18 White 1800sss bluebird coupe 1,500,000 to start with a 2,500,000 Yen BIN https://auctions.yahoo.co.jp/jp/auction/q1230337225 Datsun Bluebird KH510 Coupe 1800sss 5-speed, engine running, with documents. comment Bluebird 510 1800sss KH510 Coupe Engine running Transmission 71B short 5-speed Solex 40mm Cleaned, gasket and diaphragm replaced K&N power filter Exhaust manifold Trust muffler Fujitsubo repaired Differential R180 LSD Front coilover R30 strut Nagai Denshi full transistor kit Electromagnetic pump Bride bucket seat (original seat not included) Nardi steering wheel Monomag Spark plug wires Clutch release replaced with new pillow ball upper wheels Watanabe BOSCH headlights Front spoiler Moon Eyes chipped Front and rear brake seals replaced Brake master cylinder and seal kit replaced Clutch master cylinder and seal kit replaced Tachometer not working (wiring?) Fuel gauge not working (wiring?) Radiator leak Fuel tank, fuel gauge O-ring seepage? Left taillight and small light do not work. Turn signals and brake lights work. Taillight lens cracked and has been repaired Reverse lights do not work. Is the switch faulty? There is some leakage near the brake P valve. The brakes work, but not very effectively. The right-side door cannot be locked. The tires are old and leak air slightly. There are two keys. The photos make it look nice, but there is paint peeling, cracks, peeling, scratches, etc. Wheels will be included only for those who make an immediate purchase. For those who do not make an immediate purchase, wheels for rolling will be included, so please understand. Normal bumper (quite rusty), normal mirrors (left and right), glass molding ( shown in photo 10), unused parts (over 30 years old), will also be included. Although not shown in the photos, a parts list is included, although it is in poor condition. For those who pick it up, a heated rear window (in poor condition) will be included if needed. The engine is running and all documents are available (certificate of deregistration). As it is an old vehicle, there may be parts that need repair, so it would be best to finish it as a restoration base. There may be some things I have forgotten to mention. Please ask any questions you may have. This is a sale as is. There may be oversights or things I forgot to mention. As this is a used vehicle, there will naturally be scratches, rust, fading, paint cracks, etc., so please understand this in advance. We recommend inspecting the vehicle in person. Those who come to inspect the vehicle will be required to show identification. We refuse bids from those who have no intention of purchasing or are just browsing. We do not allow inspections by multiple people. Occasionally, some people ask for a discount during the inspection because they think there is something wrong with the vehicle, but we refuse such requests. We will explain as much as possible, but we cannot accept cancellations, so please understand this in advance. If you have any questions, please feel free to contact us. Please only bid if you can complete the payment procedure within 2 days of winning the auction. If we do not receive contact or payment is not completed within 2 days of winning the auction, we will cancel the transaction due to the buyer's circumstances under any circumstances, so please be aware of this. We cannot accept any cancellations, after-sales service, questions, or complaints after the auction ends. For vehicle handover, the winning bidder must either pick up the vehicle directly or arrange for a delivery company. Please check the photos carefully. If you have any questions or concerns, please feel free to ask. Quote Link to comment
carterb Posted May 20 Author Report Share Posted May 20 On 5/18/2026 at 11:20 AM, carterb said: White 1800sss bluebird coupe 1,500,000 to start with a 2,500,000 Yen BIN https://auctions.yahoo.co.jp/jp/auction/q1230337225 Datsun Bluebird KH510 Coupe 1800sss 5-speed, engine running, with documents. comment Bluebird 510 1800sss KH510 Coupe Engine running Transmission 71B short 5-speed Solex 40mm Cleaned, gasket and diaphragm replaced K&N power filter Exhaust manifold Trust muffler Fujitsubo repaired Differential R180 LSD Front coilover R30 strut Nagai Denshi full transistor kit Electromagnetic pump Bride bucket seat (original seat not included) Nardi steering wheel Monomag Spark plug wires Clutch release replaced with new pillow ball upper wheels Watanabe BOSCH headlights Front spoiler Moon Eyes chipped Front and rear brake seals replaced Brake master cylinder and seal kit replaced Clutch master cylinder and seal kit replaced Tachometer not working (wiring?) Fuel gauge not working (wiring?) Radiator leak Fuel tank, fuel gauge O-ring seepage? Left taillight and small light do not work. Turn signals and brake lights work. Taillight lens cracked and has been repaired Reverse lights do not work. Is the switch faulty? There is some leakage near the brake P valve. The brakes work, but not very effectively. The right-side door cannot be locked. The tires are old and leak air slightly. There are two keys. The photos make it look nice, but there is paint peeling, cracks, peeling, scratches, etc. Wheels will be included only for those who make an immediate purchase. For those who do not make an immediate purchase, wheels for rolling will be included, so please understand. Normal bumper (quite rusty), normal mirrors (left and right), glass molding ( shown in photo 10), unused parts (over 30 years old), will also be included. Although not shown in the photos, a parts list is included, although it is in poor condition. For those who pick it up, a heated rear window (in poor condition) will be included if needed. The engine is running and all documents are available (certificate of deregistration). As it is an old vehicle, there may be parts that need repair, so it would be best to finish it as a restoration base. There may be some things I have forgotten to mention. Please ask any questions you may have. This is a sale as is. There may be oversights or things I forgot to mention. As this is a used vehicle, there will naturally be scratches, rust, fading, paint cracks, etc., so please understand this in advance. We recommend inspecting the vehicle in person. Those who come to inspect the vehicle will be required to show identification. We refuse bids from those who have no intention of purchasing or are just browsing. We do not allow inspections by multiple people. Occasionally, some people ask for a discount during the inspection because they think there is something wrong with the vehicle, but we refuse such requests. We will explain as much as possible, but we cannot accept cancellations, so please understand this in advance. If you have any questions, please feel free to contact us. Please only bid if you can complete the payment procedure within 2 days of winning the auction. If we do not receive contact or payment is not completed within 2 days of winning the auction, we will cancel the transaction due to the buyer's circumstances under any circumstances, so please be aware of this. We cannot accept any cancellations, after-sales service, questions, or complaints after the auction ends. For vehicle handover, the winning bidder must either pick up the vehicle directly or arrange for a delivery company. Please check the photos carefully. If you have any questions or concerns, please feel free to ask. What in the heck is going on with this head gasket?! Quote Link to comment
carterb Posted May 20 Author Report Share Posted May 20 Safari Gold 1970 1600SSS Bluebird Coupe 1,251,000 Yen https://auctions.yahoo.co.jp/jp/auction/n1230505889 [Classic Car][Rare Car] Nissan Datsun Bluebird 1600SSS, 1970 Model (KP510), 4-speed manual transmission, with documents [Pre-inspection included] comment Thank you for viewing this auction. Please read the following before bidding. I am offering a Datsun Bluebird 1600SSS, model KP510, from 1970. This is a car that enjoys enduring popularity among classic car enthusiasts. The engine starts easily and on the first try. Idling is stable, and there are no particular problems with driving. The body is in relatively good condition considering its age, and there is no history of accidents or major repairs. The interior is also clean, as is appropriate for its age, and is in a comfortable condition for driving. Furthermore, a preliminary inspection has been obtained and is valid until July 31, 1996, so registration after winning the auction will be smooth. As this is a classic car, we recommend inspecting the vehicle in person. It is also ideal as a collection or base vehicle. If you are looking for one, please consider this opportunity. Quote Link to comment
datzenmike Posted May 20 Report Share Posted May 20 Michael Spreadbury's article says the hood louvres were '71 option. http://datsun510.com/photopost/data/3842/medium/SSS_Options1.jpg Quote Link to comment
carterb Posted Friday at 06:42 PM Author Report Share Posted Friday at 06:42 PM Silver 1972 1600SSS bluebird 4dr 1,000,000 Yen https://auctions.yahoo.co.jp/jp/auction/x1232452168 510 Bluebird 1600, Solex carburetor, exhaust manifold, front disc brakes, complete with documents, working condition, base vehicle. comment ◇Product details This is a 510 Bluebird 1600 with Solex carburetors, exhaust manifold, aftermarket muffler, front disc brakes, and comes with all necessary documents. It is in working order and is a base vehicle for sale. Brake master cylinder replaced with a new one, tank duct replaced with a new one, clutch master cylinder replaced, line mesh hose, The engine is running and the vehicle can drive, turn, and stop, but since it is an older vehicle, we would appreciate it if you could arrange for pickup by a transport truck. ◆Please feel free to ask any questions you may have. ◆We welcome bids from those who understand and appreciate older cars. ◆As the actual vehicle takes precedence, please understand that there will be no claims or returns. ◇Payment Details ◆Yahoo! Easy Payment ◆Bank Transfer ◇Shipping Details ◆Direct handover ◇Notes Please understand that the condition of the car is subjective and based on individual judgment, and bid accordingly. Please note that there will be an additional charge if we arrange land transport. To avoid any trouble, please judge the condition from the photos or the actual car. On-site inspection is possible, but it will be difficult to schedule as the auction ends, so please ask early if you wish to inspect the car. If you are in a hurry, please provide your phone number or email address. We will respond privately. Please note that we will not be able to contact you if you enter the information incorrectly. To prevent prank bids, we may cancel bids from new users, users with low or negative feedback ratings. If you are seriously considering bidding, please ask questions beforehand. As this is an old car, please refrain from bidding if you are overly concerned or expect perfection. Please understand that there may be minor scratches, dents, repairs, torn seats, dirt, rust, and corrosion on the interior and exterior due to the age of the car. Even if a malfunction or repair needs are found after delivery, the actual car will take precedence, so please understand. We assume no liability for defects. If you do not contact us within 24 hours of winning the auction, the transaction will be canceled. Please make payment within 3 days of winning the auction. As the vehicle is sold as-is, there will be no claims or returns. TEL 090-700-4166 (Added June 5, 2026, 5:53 PM) Thank you for the many visits. We are also reaching out to other people, so please understand that we may withdraw this offer. Quote Link to comment
